Question about HP Compaq nx6310 Notebook
My HP laptop tx1138ea has power but not booting in, no bios
I was using my laptop when it hang, then i reboot it but it didn't boot, even the bios was out, just nothing , the screen was blank but the power is turning on. so from there on i could not use my laptop anymore. I didn't know what happened.. can you please help me?thanks.
  • jnartpadilla Nov 11, 2008
    Tnx marksarchive, it was not giving out any beeping sound, when turn on the only thing you will notice was the power lights on and the fan which was running, it didnt boot up the bios, screen was totally blank..
  • 3 Answers
If the laptop is coming on but no video that is a most like chance that it could be the memory. but u did not say if it was giving out any beeping sounds.
Posted on Nov 11, 2008
My Acer Aspire 5732Z laptop hangs up on the Acer logo starup screen every thing stopped even cant enter the the bios hitting f2 or many other i tried
Remove ALL media, DVD, CD, USB. Unplug, remove battery, plug in, reboot. Try a system restore/recovery. At boot tap ALT+F-10 repeatedly.
Jan 25, 2013 | Acer Aspire Computers & Internet
What's your prothe laptop didn't even boot up, the fans were whirring but not the BIOS screen came up. The CAPS lock button is blinking in intervals of two, the wireless button is orange and t
With out the mode number can't really help. Remove battery and plug in AC Charger. Push and hold Power on button for 30secs. Then try powering up again.
If unit still fails most likely to be a System/Motherboard fault. If under warranty contact HP.
Aug 31, 2012 | HP Computers & Internet
I just added Toshiba 1TB USB drive to my Sony RZ44G desktop. Sometimes when powering off and back on, the reboot hangs at the 'SONY' screen and gets no further. If I disconnect the Toshiba drive, power off...
Check your bios/cmos settings (press DEL button while booting), and make sure no USB device is set to boot frome.
(some bios's recognise large USB's as harddisk's drives, and when booting it check's the drive boot sector, and hang, since no boot sector is located in it)
gd luck.
Dec 31, 2009 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
HP DV6110us: 4 beeps, no boot
besides the beeps which indicate a motherboard timing issue. There should be LED blinking codes given on the front LEDs. I will include the blink codes below, but lets try to at least get the system up and running. First, I would like you to remove the RAM sticks from the laptop and just reseat one stick back in the machine. Try to boot with that one stick, if it does not, try the other alone. There have been issues when reseating the ram or re-installing it have temp. fixed the issue. If it does reboot, go to the HP support site, put in your model number of your laptop and download and install an updated BIOS. Below are the blink codes that may narrow down the problem.....
HP DV6000 LED Blink Codes
LED Component Error Condition
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock System board General system board failure
Blink: 6 - Caps Lock/Num Lock BIOS BIOS authentication failure
Oct 22, 2009 | HP Compaq Pavilion dv6110us Notebook
G620 boot problem
When you power up press F8 key then ente rin enable vga mdoe.
Then go to contro lpanel and then open dispaly property then change screen resolution to 1024*768 then apply and ok.
Then restart it.
Jun 23, 2009 | Computers & Internet
G620 boot problem
after ur long question the problem is the faulty RAM ... ur RAM is causing all this remove and replace your RAM . ur problem will get solved..
Jun 23, 2009 | E-Machines (308714) Motherboard
My wifes hp dv9000 laptop will boot up and go to the desktop, 30 sec. later it shuts off, then reboots. It started doing this after we used a hp recovery disk. Her computer crashed on her overnight and hp...
You will need to do more trouble shooting. If you can, boot into safe mode and see if system reboots. If it does boot into the bios and see if it reboots there.
If system reboots in all modes then you have a hardware problem and will need to be serviced. However if it does not reboot in the bios then there is a good chance that some part of your windows system is corrupted.
If you find this helpful please rate so.
Thanks
May 06, 2009 | HP Pavilion dv9000t Notebook
While booting hang , only showing f10 boot screen .
Here it is.
1. When asked to press F10, do it! It will take you into bios setup, then load "bios defaults", then "save and exit"
You should also try to update you bios and all your drivers. Come back here for instructions if #1 do not solve your problem.
If you find my solution usefull, please rate it at FixYa.com
Thank you ;)
Mar 28, 2009 | HP Compaq nx6110 PC Laptop
Acer aspire 5315 can't boot BIOS menu
Keep trying F8 Key during the Boot up process, may be you will get the system in Safe Mode to work on.
Then run a Checkdisk command and restart your PC. Hope this will resolve the problem.
Let me know the result and status to work further.
Happy Holidays!
Scott
Dec 29, 2008 | Computers & Internet
Laptop is not booting
go back into the bios and reset the bios to defaults, hit F10 to save changes and reboot
let me know what happends
regards
Nov 24, 2008 | Lenovo 3000 Y410 Notebook
HP Compaq nx6310 Notebook Logo
215 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
