Question about Denon AVR-2803 Receiver
Denon AVR-2803 : No sound from Zone 2 Speakers
After working great for 3 years when I tried to turn on Zone 2 (lately) the whole AVR unit shut off. I reinitialized the microprocessor (per the manual) and now I can select Zone 2 with the unit remaining on. However, I still can't get any sound from any of my Zone 2 speakers (Zone 2 volume is up enough) from any source. Thanks.
  • Gary Schellhas May 11, 2010
    Are you running the system in 5.1 surround or 7.1 surround? If you are running it in 7.1 surround, the unit will allocate the power for the second zone to the 2 extra speakers for 7.1. You man need to change the settings in the menu to allow this.
  • 93 Answers
SOURCE: Denon Avr 2803
Could be bad connection. Try to tight connection cables on receiver and TV.
Posted on Oct 15, 2007
tech48
  • 624 Answers
SOURCE: Denon AVR-1907 blinking red power button
It sounds like you have a bad speaker on the zone 2, or you have the speakers connected improperly.
When you engage the zone 2 a relay clicks and the speakers then become part of the amplifiers circuit.
If the problem was in the amplifier, it would go into protect mode without even having speakers connected to it.
If the speakers all check good, you most likely have the wrong type of speakers, meaning the impeadance is too low, or you have too many speakers connected to it.
On the back of the Denon, you will see right around the speaker output jacks, what ratings the speakers should be. If I remember correctly, it says 6 ohms or more when using only "A" or "B", and it says 12ohms or more for "A" + "B".
If you have two 8 ohm speakers on the same speaker jack you now have a 4 ohm load. That is below the ratings and can cause the amp to shut down (go into protect). Since your amp shuts down right away, I think you have a bad speaker or way too many speakers connected.
I have seen many times when people will connect 2 or 4 speakers to the one of the outputs that are designed for only 1 speakers.
If you are using too many speakers you will need a speaker distribution box. It has a resistor network built into it so the amp never sees a lower impeadance than what it is designed for.
You can connect 4, 6 or 8 speakers to one set of outputs designed for 2 speakers. You do loose a lot of power to the speakers, but it is better than blowing up your amplifier.
If I can be of any further help, let me know.
Posted on Jun 22, 2008
  • 33 Answers
SOURCE: Denon AVR-2803 Zone 2 sound source
You have to switch your remote into Zone 2 Mode. It will be an option on your remote. Once you put it in that mode, you can change the source just as you would Zone one.
Posted on Jan 25, 2009
  • 336 Answers
SOURCE: i reset the microprocessor that
One or the output channels is probably bad you can check for a short on the output transistors using an ohm meter. Make sure that the receiver is un-pluged. The ouput transistors will be on a large heat sink.
Posted on Feb 01, 2009
smarthome2
  • 1114 Answers
SOURCE: Denon AVR-2106 - Zone 2 shuts down system
Check your speaker wires on zone 2 and look inthe manual for speaker configurations with zone 2. you may have a speaker conflict. If you still have an issue, post a comment with your speaker setup and I'll help some more. Hope this helps
Posted on Jul 01, 2009
Using Denon AVR 2803 as an FM receiver
• Insure that the speaker system is working.
try it on other receiver.
• Check to see if there are headphones connected.
• Check if tuned is lit
Aug 12, 2012 | Audio Players & Recorders
AVR-2803/983: Had recent 24hr Power Outage. When power restored, I receive no video/sound from TV thru COMCAST HD box, no video from CD but do get sound, lost partial use of Zone 2. Zone 2 works if I...
Extended power loss might lose memorized settings. Pretend the unit is brand new and verify all of them. No video from CD??? Really? Good luck with that.
Jul 16, 2011 | Denon AVR-2803 Receiver
Denon AVR 1609 volume Zone 2
Logitech recommends that zone 2 is controlled using device mode on your Harmony remote. Controlling zone 1 and zone 2 simultaneously within activities may lead to the AV Receiver turning on and off unexpectedly as you switch between activities. For example, if you try to turn on zone 2 within an activity, it may turn on or off zone 1 and vice versa. Controlling zone 2 in device mode will prevent this from happening.
Aug 07, 2009 | Denon AVR588 Receiver
Jan 25, 2009 | Denon AVR-2803 Receiver
Can't get the MultiZone to work on my Denon AVR 3805 Reciever
No as there is no volume control on the zone outputs
Aug 18, 2017 | Denon AVR-3805 Receiver
Denon AVR-3805 zone 2 no longer working
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Dec 29, 2008 | Denon AVR-3805 Receiver
Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
Dec 18, 2008 | Denon AVR588 Receiver
Jun 22, 2008 | Denon AVR-1907 Receiver
Audio Problems with AVR-2803
Hmmmmm Sounds like one of 2 things....
1 Your DSP board is toast. ( not much hope, it must be sent to Denon as they do not have anymore entire circuit boards for swap-out replacement.
2. Heres the hope part......Inside your denon is like a computer.....there is a main board, separated by the big silver heatsink, and then there another main board. On the main board closest to the volume control, the DSP boards and Video boards plug into the main board . The DSP and video boards are up and down ( when the receiver is laying flat, like normally ), and they plug into the main board from the top.
Denon is NOTORIOUS for bad solder joints and the little white connectors that connect the "motherboard" to the DSP and Video boards are of suspect quality ( the rest of the unit is great )....So it COULD be that you have a bad solder joint on one of the connectors or the connector itself. There is also another set of connectors that joins the front panel display to this "motherboard".....these colder connections are also suspect.
I would have a denon repair shop look at it as I GUARANTEE they have seen this before.......best of luck...Rob
Mar 13, 2008 | Denon AVR-2803 Receiver
Denon AVR-2803 Receiver Logo
242 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
