Question about Panasonic Workio DP-4530 Copier
Panasonic 4530 copy machine
How can I delete a name and number from a memorized fax list
Enter to program f9 coo then yes u can reset all parameter of ur machine
Posted on Nov 10, 2008
Panasonic 4530 e03-40
try to clean the copy density sensor near drum unit
Jan 01, 2014 | Panasonic Workio DP-4530 Copier
How to register number has been delete. How do you put them back in a Pansonic Panafax UF-55o machine. The fax machine work just the long distance number that was register are going. Need to know how to...
press
function 72
set
press 01 on the soft key pad enter fax number
set
enter name with the letters on the soft key pad
set
continue with 02 as above or press stop
press
function
62 set to print diectory
Mar 24, 2010 | Panasonic Panafax UF-550 Plain Paper Laser...
Speed dial
NEW Number
Function
72
set
press destination like 01 the yellow part of the keyboard
enter fax number
set
enter name
set
stop
Delete a number?
press as above like 02
press clear
set
press clear
press set
stop
Apr 30, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Memorize tel number
I believe there is a clear memory function on this machine.
Otherwise try to reinitialize the main board.
Try : holding menu + * + # , with other hand turn on machine.
The machine should do a cycle, then come to a ready.
This resets the main board. If this function does not work, I need to find the right code process.
Feb 09, 2009 | Xerox WorkCentre Pro 785 Plain Paper Laser...
Add and delete names and numbers from broadcast
How do I change the name and phone # on my fax machine. Sharp UX-510
Nov 25, 2008 | Sharp UX 510 Plain Paper Thermal transfer...
Cannot save/change one-touch edits
Function
7
monitor key slowly 4 times
6
scroll down to ALL JOB CLEAR
set
wait for machine to reboot
Sep 05, 2008 | Panasonic UF-895 Fax Machines
Delete memories
Have a technician do a RAM INITIALIZE on your machine.
Jul 21, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Broadcast fax
How to delete the memories of one-touch number and name?
Jul 10, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Canon jx200 fax machine
The fax automatically turns off Auto Print and stores faxes in memory when either ink or paper is low. The memory will store up to 30 transmissions or 60 pages maximum, so it is important not to leave this too long if you have heavy transmission volume.
Faxes can be retrieved as follows.
If you want to choose only certain faxes to print:
1. Print a list of documents in memory for reference:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Doc Memory List, and again press Start/Copy.
2. Print a document from memory (using the list printed in #1):
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print Document, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to print, and press Start/Copy. The LCD will then toggle between "1st page only?" and "Yes=(*) No=(#)". Press * to print only the first page, or # to print all pages.
3. Delete selected document(s) from memory:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Doc, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to delete, and press Start/Copy. [Note - if the arrows do not result in another number displaying, there is only one document in memory.] The LCD will show "Yes=(*) No=(#)". Press * to delete the document. Continue to select documents until each document you want to delete has been handled.
If you want to print all unprinted documents in memory:
1. If you want to have a list of documents in memory for reference before performing this procedure, to be sure you have them all, follow step 1 from the above procedure for printing selected documents.]
2. Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print All New RX, and again press Start/Copy.
3. Delete all printed docs from memory:
Immediately after printing all documents, you will have the choice of deleting all documents. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory.
To delete all documents at a later time:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Printed RX, and again press Start/Copy. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory. To finish then, press Stop.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 06, 2008 | Canon FAX-JX200
Adding and deleting into and out of group phone list
Group setting where? In the driver? In the menu in the machine? In some piece of software?
Are you refering to the name and phone number people see when you fax them?
Please be more specific.
Changing the name and phone number for faxing operations is covered in the owners manual. If you can't find the manual, there should be a copy on Brother's Web Site at www.brother.com
Dec 28, 2007 | Brother IntelliFAX 4100 Laser Fax
Panasonic Workio DP-4530 Copier Logo
95 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
