Question about Samsung WEP200 Headset
I have a gn 6210 headset bluetooth which appears that the battery will not charge. Can anyone help? Where can I get a replacement battery for the headset? Are they simple to replace? Where can I get it repaired? Also I understand that there is a replacement (BT 500V) Is that correct? It is brand new and never been used although a couple of years old.
  • Wolfgang19 Dec 02, 2008
    I have _exactly_ the same problem for _exactly_ the same reason! I had this very nice BT headset for several years without using it because my Treo 650's bluetooth seemed about useless. Now I have an HTC Touch Pro, and so of course want to use this nice GN 6210, but the battery's life is very short (rather than the initial 8 hours). A replacement battery would be great!
I actually took my GN 6210 apart (not recommended)--the battery is _not_ easily user-replaceable, as it appears to be directly wired to other components. I think when the battery is dead, it's the better part of valor to move on to a newer model.
I suggest http://www.amazon.com/Samsung-WEP200-Bluetooth-Wireless-Black/dp/B000GAO9T2/ which, at the time I write, is very highly rated and is only $25, $5 after rebate. But long after that deal goes, there will be other good headsets cheap, though few with the cool mobile/landline joint compatibility. (I'm mobile-oriented, myself.)
Posted on Dec 02, 2008
Is a replacement battery available for 9120 I've used for a number of years?
GN Netcom probably would know. If you can identify the battery type, you can try obtaining a replacement from some other source.
Jul 07, 2014 | GN Netcom GN 9120 Professional Headset
No dial tone
Headset might need re pairing with the base. If this is anew set up you might need to change the compatibility dial.
Jan 23, 2013 | GN Netcom GN-6210 Consumer Headset
No pin number
You must put in pairing mode first. Starting with it powered off, press and hold the Multi Function Button (MFB) for some 8 seconds (i.e. much longer than the time required to turn it on), until the indicator light is solidly lit. Then, make your phone (generically speaking, the bluetiooth device you want to pair your headset with) search for new devices. After a while your headset should appear on its screen. Select it make it connect. If a pairing code is requested ,enter '0000' (four zeros). If the pairing process is successful, the headset should enter the stand-by mode (its light blinks periodically). The pairing procedure between any two bluetooth enabled devices should be performed just once. All subsequent connections should be achieved simply by bringing both devices within reach. If a bluetooth link is not established, a simple press on the MFB should get the job done.
Hope it works for you.
Regards, Carlos
Jun 07, 2010 | GN Netcom GN-6210 Consumer Headset
Instuctions for set up...no instuctions
You can download the complete instruction manual in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Apr 22, 2010 | GN Netcom GN-6210 Consumer Headset
Battery for GN9120 is not staying charged; what can I do?
Hi
The battery is no longer charging just like your car battery only lasts for so long and then dead no matter how long its been on charge
try and get replacement if not should think about a new headset
Steve
Aug 28, 2009 | GN Netcom GN 9120 Professional Headset
Hi, We have a GN 6210 wireless headset and it doesn't seem to want to hold a charge anymore. It's good for about 1 hour and then starts beeping and goes out. Is there a battery or something that I need to...
When I used this model in the past, it appears that the battery wasn't holding a charge after a year of use. I called them about it and told me that the battery wouldn't hold a charge anymore, there wasn't a battery replacement for it, and that I would have to replace it.
I believe Jabra is currently doing the support for GN. Support can be reached at this link:
http://www.jabra.com/Sites/Jabra/na-us/pages/Support.aspx
Dec 02, 2008 | GN Netcom GN-6210 Consumer Headset
GN Netcom GN 6210 - headset, no worky
Not sure what you mean by won't turn on.
If you mean no dial tone when you take it out of the cradle, I have run into this. The solution is to unplug the power cord and then plug it back in which resets the unit.
May 27, 2008 | GN Netcom GN-6210 Consumer Headset
Pairing GN Netcom GN 6210 with my iphone
Press the talk button on the 6210 Device and hold it until you here (2) faint beeps. Walla! (poor design and documentation?)
Mar 08, 2008 | GN Netcom GN-6210 Consumer Headset
Samsung WEP200 Headset Logo
366 people viewed this question
Top Samsung Radio Communications Experts
sonic boom...
sonic boom...
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
