Question about Cannon Office Equipment & Supplies
Getting a black line on the back of printed pages
  • 685 Answers
Check your ink and make sure its not leaking
Posted on Nov 10, 2008
SOURCE: HP 3050 Black Line
did you copy or print from computer? if on copy time only, you must clean scanner bail, if for both ( copy and printing)your toner is damaged maybe.
Posted on Mar 18, 2008
jay-jay-g
  • 48 Answers
SOURCE: When printing, a black ink
try running the print head cleaning utility
most printers have these utility on their printer drivers, some have it on the printer itself..
refer to your user's manual for print head cleaning..
Posted on Aug 22, 2008
SOURCE: Black Line on back of pages
Your problem is not isolated; I read of two others on this site in mid-August 2008 and added my own post.
I contacted Canon Support and tried their solution (which you've already tried); it did not work. Given the choice of repairing a printer that I've had (and babied) for less than 2 years or buying a new Canon at a discount under their Loyalty Program, I chose to take my MP530 to a Canon Authorized Repair Facility.
According to the repair tech, there is a problem with the waste ink tank and ink absorber pads. The repair facility ordered and installed a rebuild kit; it took about 2 weeks. The printer now works beautifully again.
If your printer is still under warranty, you're in luck. If not, ask that it be handled as a warranty repair. In my opinion, Canon should recalling and offering to fix this problem free of charge.
Posted on Sep 09, 2008
SOURCE: MP830 prints a black stripe down the back of the paper
the waste ink pads are full ..when the black line appears it is an indicator that the waste ink pads are full it is usualy because the printer has reached its life expectancy the solution is either buy a new printer or pay a tech about 170 dollars to repair it
Posted on Jul 19, 2009
  • 4090 Answers
SOURCE: HOW DO I FIX A BLACK LINE ON BACK OF PAPER WHEN PRINTING
ink on one of the guide rollers will cause this
Posted on Sep 14, 2009
Getting a black line on paper when printer warms up...
Black lines on copy come from toner cartridge, or drum unit, or fuser unit which is in the back. check drum and see if you can see line, back of machine with flash light you may be able to see line on fuser roller. Be carefull Fuser is hot.
A copy that is good and then starts to get lines usually the drum unit...
Mar 26, 2017 | Brother MFC-9840CDW Laser Printer
Getting a black line on the back of the pages.
I am also getting a black line on the back of everything I print. I have gone through all the steps to clean the ink heads. I even had, (by chance) more black ink in the house and tried replacing the cartridges.
The black line came out bolder. This problem is a expensive because it uses up ink, and doubles the printing.
Oct 23, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I keep getting a black line on the back of most printed pages
Hi there
This is a leak from the ink or it is your waste ink pads full, you will have to clean all the inside out, the ink getting on to the rollers.
All the best Pineworks
Apr 26, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Xerox Phaser 7700 printing Black line across bottom of every page
The line could be caused by contamination on the black laser lens. Try using the cleaning wand located in the front door to clean the lens. You will need to remove the waste toner container to access the wand slots. If that does not solve the problem, the black developer housing may need to be replaced. Refurbished parts at: http://www.lpscomputer.com/p-3064-116-1111-00-black-developer.aspx
Apr 23, 2010 | Xerox Phaser 7700 Laser Printer
Black lines down on printed page
This is caused by dirt/debrise on the ADF (automatic document feeder) scanner glass. You need to open up the feeder where your originals are fed in and look for a strip of glass that runs from front to back. It is about an inch or so wide. You need to clean this glass to get rid of the lines. Some models have this glass just to the left of the large main glass, but in your case I beleive it is in the feeder itself.
Good Luck.
Apr 23, 2010 | Brother MFC-7820N Printer
Problem for print by photo copier
sounds like the charge grid is not set properly in the drum unit..did you et up the drum unit properly and run the new dev and drum set up..if youy are getting black the charge is not working correct as the charge of the drum help to keep the toner from adhering to the drum surface when copying .. I would take the drum chrge unit out again and check it is set in the right way when you put it back on also check the contacts arent put out of line.
Aug 05, 2009 | Kyocera Copystar CS-1820 Black and White...
Black ink cartridge is leaking and black line is running down back of page
if you do your own refill the ink u are using is of the wrong density, get the right ink
May 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
Hp laserjet 4 plus - keep getting a horizontal black line
yes you have to catch printer making the line and then as a page is being printed you need to open door to stop paper after green cylinder(drum) as it is entering fuser, then you need to remove paper from printer without pulling through the fuser, if you see the line then rub your finger across line up and down page, if it smears at all then its the cartridge if not then the fuser
Apr 27, 2009 | HP LaserJet 4 plus Printer
Jan 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
67 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Victorman
Victorman
Greg Cann
Greg Cann
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
