Gateway 7322GZ's TSST corpCDW/DVD TS-L462A won't recognize disks
Our TSST corpCDW/DVD TS-L462A will not recognize some disks; they're described as not being formatted.
It was working alright until about 4 months ago but now won't play newer DVDs and CDs. The drive shows up in my computer but it doesn't show a disk. Attempts to access the disk (like by attempting to play) will result in a message that the disk in unformatted or in an unknown format.
When inserted, the disk spins, and the little orange light blinks for awhile.
It has Win XP home edition SP3. I've tried to update the firmware but all links to the firmware are dead, Samsung doesn't list it, and Samsung's live update won't work.
Is this is even a DVD issue? Or is some other part of the computer (HD for example) not working right?
I'm wondering if there's some driver conflict (DVD programs, thumbdrive drivers, etc.) and if so, if a full system restore will help?
  • Anonymous May 13, 2009
    same as last one
    Scholar:
  • 121 Answers
It looks like its your CD Rom itself.....have you tried cleaning the head with a head cleaning disc .....if this doesn't help replace the Rom
Posted on Nov 10, 2008
Basically we need to find a driver to update TSST Corp CD/DVD TS-L632M ATA Device because it won't recognizing the dvd for this program "KAISER BASS Hybrid TV stick" and nothing will burn across...
go here
Your CD drive or DVD drive is missing or is not recognized by ...
(982116) - This article describes a problem with CD or DVD drives not work, or is missing, or not ... This section, method, or task contains steps that tell you how to modify the registry.
http://support.microsoft.com/kb/982116
Jan 18, 2011 | Computers & Internet
Suddenly DVD drive (TSST corp CD/DVDW TS-L532M) has some malfunction. It won't burn DVD until end if file size is more than 2,5GB. It stops first around 96% if I have another try it will stop 86% and so...
what can it be lets make a list.
first off
Toshiba/samsung TSST when bankrupt in 2016
so no drivers now from them.
HP does not support this PC now, ended long ago.
MS XP is a dead OS, and does not send you drivers for this XP, MS shut the drivers services off called PnP.
1: XP is infected, as all are now.
2: the drive is bad. as many are now this old
3: the driver is missing or wrong own or it is infected.
4: the XP, DVD filters are wrong in the registry,
google that, see 1 millions hits, all the same.
5: your unstated BURN app is infected or corrupted.
try imgburn (free)
6: bad media DVD-R? your drive is lightscribe version , my guess is yours is OK.
7 burn at a slower speed?, use image burn
your spec is here. 8x
8x maximum write speed (DVD±R)!
* 2.4x maximum write speed (DL DVD+R)
* 4x maximum rewrite speed (DVD+RW)
* 24x maximum write speed (CD-R)
* 10x maximum rewrite speed (CD-RW)
* 24x maximum read speed (CD)
8: the unstated file is too big. ?
but if it really is 2.7GB then it is not.
Nov 20, 2017 | HP Pavilion dv8000t Notebook
Tsst corp cdrw/dvd tsl 462d does not recognize a blank dvd+r
sounds like you need to reinstall the drivers for this device if it came with a disk you can reinstall from there
Jul 23, 2010 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
Error with a TSST CD/DVDW TS-L532U.
Try uninstalling the device using device manager. Shutdown computer and restart. If the problem persists then you have a faulty DVD/CD drive.
Go to My Computer and right click, select the Device Manager, search for the drive on the right side. Right click and choose Uninstall. then restart. Hope this helps.
Jun 13, 2010 | Computers & Internet
Can I burn dvd movies with dvd r disk on my TSST corp CDW/DVD TS-H492A
You can only burn DVD's with a dvd-rw.
A CD-RW DVD will only play a dvd and write CD's
Mar 14, 2010 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
My TSST corp TS-H653R CD/DVD does not recognize that a
HP uses a method to determine if an optical drive has failed. Basically in a nutshell, if the drive will not read a disc, or if it will not write to one, then the drive is defective.
When the diag tool asked you to insert a "data disk" it's not asking for any particular disk, just one with data on it so that it can test itself.
if it does not recognize the disk in the machine, then try another disk. if the issues persist, the drive is definately failed.
hope this helps!
Aug 31, 2009 | HP Pavilion Elite e9180t PC - 3.00 GHz;...
TSST Corp CD/DVD W TS-L632D ATA Device not working properly
The laser maybe out of focus. Some movies will play and some won't. I had the same problem. Had it fix @ my local shope around 50 bucks. If this helps
Aug 21, 2009 | Computers & Internet
Tsst-h652d not working after upgrade, thinks its a cdrom not combo
Well, I'm sorry it didn't work out for you. It was still worth a try. I have to agree with you. Since it isn't being recognized properly it probably isn't worth the trouble getting it repaired since typically that costs more than buying a new one. If you need to find some good prices on CD/DVD readers & burners you can look online here:
Newegg
Simply navigate to Computer Hardware > CD / DVD Burners & Media. After the page loads simply click, "CD / DVD Burners" located in the menu on the left.
Let me know if I can do anything else for you (posted as a solution so you could rate the responses above).
May 27, 2009 | Gateway GT5408 PC Desktop
Computers & Internet Logo
428 people viewed this question
David Payne
David Payne
