Question about Polaroid 8" Portable DVD Player, PDV-0813A
Black screen with sound
Hi, The screen on my dvd player is black...i've checked the mode the connections are good...I can barely see the picture 98% black...I've tried adjusting the brightness also...any way to help me thanks
4 Suggested Answers
SOURCE:
  • 1153 Answers
SOURCE: No video - just a white screen
So I am guessing you have audio and no video, your monitor has went out. you can check and see if ribbon cable is slightly uplugged, but maybe just a bad monitor. These happen usually from a drop or hard hit to the unit.
Posted on Aug 14, 2007
CompuGuy44
  • 432 Answers
SOURCE: Brightness hidden
Press and hold the MODE button for a couple of seconds, Use the arrow keys to adjust. You can view the manual here.
http://www.polaroid.com/service/userguides/ce/portable_dvds/pdm0822bd_ugl.pdf
Posted on Feb 14, 2008
maxx_22
  • 8 Answers
SOURCE: my protable dvd player has a dark screen. I can
there should be a menu button on the controler u can access the brighten button simply turn up the brightness
Posted on Dec 17, 2009
Dvd, sound, no picture
If your DVD is external, I'd check TVs input settings: if your DVD on "progressive scan" mode, it delivers video signal via "component" connections: green, blue, red plus 2 separate red/white for the sound. If you trying to use 3 wires: yellow, red, white( composite), good chance, that the only sound is delivered. Try to switch DVD off 'progressive", if you only have 3 wires. It will deliver "picture". Or, verso-visa: using "component", 5 wires, but DVD set off "progressive scan". I've seen that confusion many times! Unless you have 'built in" DVD player. no matter what, it's must be broken! Use external DVD player, instead! $30 and trip to the store, will solve your problem. Don't want to fix TV, if everything else is alright. Myself, I never liked those "combo" units. You got stuck with mediocre TV and lousy DVD player. Better: separate them!
Good luck,
Alex.
Dec 25, 2011 | Toshiba Televison & Video
PORTBLE DVD PLAYER THE SCREEN IS BLACK ''NO PICTURE''
if the lcd screen is attached to another small printed circuit board, you may need to replace that, otherwise you may need to have to replace the lcd panel. Good Luck :)
Sep 08, 2009 | Televison & Video
My sony portable dvd player stopped working. The
If the DVD is connected to the TV properly using the yellow, white & red AV cable and the TV is switched to AV and there is still no picture, plug the yellow lead from the back of the DVD player into the green socket. If you see a black and white picture now the DVD output is on Progressive Scan mode. See user manual to turn off Progressive Scan mode.
Aug 31, 2009 | Sony DVP-FX810 Portable DVD Player
Blank screen no picture
connection between the dvd output and screen has broke link somewere. pull it apart and check it out
Jun 05, 2009 | Philips Magnavox DVD/VCR Dual Player
DVD is hook up and no picture on the TV.
You have to make sure that the RCA cables are properly connected to the TV. Check the TV/Mode if it's set to AV1 (Audio/Video1) or AV2. You may check the TV remote to set it to AV1 or AV2.
From the DVD, the cable should be connected to OUT. And on the TV...video and audio should be connected to IN.
Apr 05, 2009 | JVC XV-S300 DVD Player
Kawasaki PVS 10921 lines in screen
unplug the device from the main power cord.remove all the external wires connected from the player.then again reconnect it properly.also check out the disc in another player.or another disc in the same player.
Nov 27, 2008 | kawasaki PVS-10921 Portable DVD Player
Barely visible picture and no sound
2 things the easy fix would be the screen switch is jammed a little circle next to where the door close you will need to pry the switch out and the second fix (your backlight (inverter) is out (better off buying a new unit)
Aug 15, 2008 | Insignia IS-PDVD10 Portable DVD Player
Split screen picture
Your DVD player is set to the 480p (progressive) scan mode. Place it back to the 480i (interlaced) mode and it should work normal.
May 14, 2008 | Disney D7500PDD Portable DVD Player
No picture but has sound
Hi If your t.v.has built-in blue screen when there is no signal, then the DVD may have been accidentally switched to progressive scan mode, or defaults to that setting if new. If your T.V. is not capable of displaying in progressive scan mode, you will just get a blue screen. If you have an older tv, without blue screen, then connect it to that, and if you get a black and white split screen when you turn on the DVD, then progressive scan is the problem. Check the manual for the DVD player for the procedure to get out of that mode, and it should then work. If you still have no video, and you are using the yellow composite video jack on the back of your DVD player, then it must be brought in for service. Good Luck!
Aug 14, 2006 | Zenith DVB312 DVD Player
White screen no picture but sound
First thing to check is the ribbon cables for chaffing, or the connection seating. This can cause this symptom. As well as a failing LCD video deciphering circuit and/or motherboard problems. not a bad chance that you'll need to replace the screen/unit. any warranty? Good luck
Jun 06, 2006 | Durabrand DUR7 Portable DVD Player
Televison & Video Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
