Question about HTC Touch P3452 Smartphone
HTC P3452 dead but hard reset showing smart mobility but lot of time for show smaart mobitlty is only
SOURCE:
  • 8 Answers
SOURCE: How to activate vodafone live india in HTC touch P3452?
vodafone live setting for windows based mobiles version 6::::
select "start" ---->>> select "settings" ------->> select "connection"----->>> select "connections"
Now Select "Add a new modem connection"
Connection name::"Give any name"
Moden:: select "Cellular line (gprs)"
Select "Next"
Access point name:: "portalnmms"
select "Next"
Username:: (blank)
Password:: (blank)
Domain:: (blank)
Select "Finish"
Now Select "Setup/Edit my proxy server" below that "Add a new modem connection"
Select the two check boxes
1.) This network connects to the internet
2.) This network uses a proxy server to connect to the internet
Now you ll have proxy server box below that you will have "advanced"
Select "advanced"
Select "HTTP" --->> Server:: "10.10.1.100" port:: "9401" select "ok"
Select "Wap" ---->> Server:: "10.10.1.100" port:: "9201" select "ok"
Give ok to all options.
Now select "start" select "internet explorer" and try it for the connection...
When internet is connecting it ll show "Connecting to GPRS"
You ll be getting "locating" and "opening" and the webpage
Posted on Apr 29, 2009
zohail
  • 1223 Answers
SOURCE: i have external GPS button in my HTC touch p3452 pda . . how to get get gps data from this ??
u need an external gps device bought separately and then trhu bluetooth u can communicate with this software in ur HTC , u have external bluetooth device or not
nowdays GPS is coming builtin so there is no need to purchase separate reciever but in ur PDA it is not built in
pls rate me WELL for info !
Posted on May 21, 2009
SOURCE: AIRTEL GPRS settings for HTC Touch P3452
THIS SHOULD HELP U......
On Windows Mobile 6.x, the steps to configure are as follows:
1. Activate Airtel Live by sending the following SMS to 121: MASALA ACTIVE.
2. The service takes atleast 3-4 hours to get active. Restart the phone and resume configuring.
3. Tap Start -> Settings.
4. Select Connections Tab and tap Connections.
5. Select Advanced Tab, tap Select Networks button to bring up Network Management.
6. Under "Programs that automatically connect to the Internet should connect using:" drop down, tap the New button.
7. In the General Tab, type the name of the settings as Airtel Live
8. Select Modem tab, tap New...
9. Type the name of connection as Airtel Live, select the modem as Cellular Line (GPRS) and tap Next.
10. Type Access Point Name as airtelfun.com and tap next.
11. Leave username, password and domain blank and tap finish.
12. Select Proxy Settings tab. Tap "This network connects to the Internet". This should enable the next check box option.
13. Tap "This network uses a proxy server to connect to the Internet".
14. Type the proxy server as: 100.1.200.99 and then tap Advanced...
15. Tap HTTP, leave the server as 100.1.200.99 and change the port to 8080
16. Similarly tap WAP, Secure WAP and Socks, type the server as 100.1.200.99 but leave the port to defaults. These are optional settings.
17. Tap OK to close the Advanced proxy setup screen.
18. Tap OK to close the New connection screen.
19. The network management screen should now list the new connection you have created in the drop-down. Tap OK to close this screen
20. Tap OK to close the connection screen.
Now you are ready to fire your favourite browser. I have tested this on PIE as well as Opera 9.5 and it works for me.
If PIE reports "Request not authorized by the WAP Gateway", you will need to change the user-agent to anything you can think of using "Advanced Config" tool (thanks to dsixda for suggesting this). I had set it to HTCP3452_Mozilla/4.0 under Advanced Config -> Internet Explorer -> User Agent Custom Base.
I think Airtel has intentionally blocked Mozilla/4.0 user-agent on WM phones. It may be that they cannot restrict Windows Mobile based phones from accessing websites on standard HTTP. On other phones I had tried, I could not get other sites to work with the same settings.
Enjoy Airtel Live for free.
Posted on Jun 06, 2009
SOURCE: Problem with phone volume with HTC P3452
Yes, there is a setting where you can tell the phone not to automatically adjust the volume, this is set so that if you are in a very quiet place nobody else listens to your phone conversation. Check the settings under PHONE and UN-CHECK the automatically set volume box.
Have fun
Posted on Aug 04, 2009
  • 42 Answers
SOURCE: forgot password htc p3452 how to open mobile
just switch off phone and then hold on green and red button and switch it on problem solved
caution phone memory erased so do back up before this
regards
aniruddh
Posted on May 25, 2010
Am charging my mobile but when i keep it in the mobile it is showing that the battery is low or empty
Many cell phone used for a long time will met this kind of problems, it seems full charged, but once you are calling someone, the battery power will show empty.
1, mobile phone motherboard leakage lead the current too large.
2, the battery itself is aging.
Try to find out the problems and maybe an external battery can help you a lot
Apr 03, 2013 | HTC Touch P3452 Smartphone
Sir my htc p3452 got dead. give me solutiins
hi friend,please conect ur device to pc with box and apply a new softwere on your mobile.and also try to change mobile i.c for start up ur mobile....
Feb 13, 2012 | HTC Touch P3450 Smartphone
Forgot password in htc p3452
i used htc p3452 - When connect the Pc with data cable shown Pc suite Wndows Mobile - But show the box of " Personal Folders for OutLook " and ask Passwod in one box . what is this ?? Pl clarifications & Solve
Dec 19, 2010 | HTC Touch P3452 Smartphone
How to format HTC P3452
For soft reset type *#7780# For hard reset type *#7370# and if it ask passcode enter the passcode as 12345 as default.Please backup all your data if you performing hard reset because hard reset deletes all data on your phone like contacts,messages,music,videos and photos
Sep 26, 2010 | HTC Touch P3452 Smartphone
I have a HTC Touch GSM, after an error pop up it´s been resetted and now it shows only the first image (the black backgroung saying Smart Mobility in white) and stay freezed there.
Oct 08, 2009 | HTC Touch P3450 Smartphone
My HTC touch is dead after WM6.1 upgrade from XDA developers
Hi. Have you tried reflashing your device (Assuming you have done before with the instructions from the xda-developers) with another ROM from xda-developers? If it doesn't work, you can try to reflash your device with an official ROM from the HTC website. Hope this helps.
Jun 26, 2009 | HTC S620 Smartphone
Windows mobile unable to see the screen
ASDFGSDFGGSFGGHGFGHGHJKYYYYYYYYYYYYYYYYYYYYYY
Dec 12, 2008 | HTC Touch P3452 Smartphone
HTC Touch P3452 Smartphone Logo
202 people viewed this question
Top HTC Computers & Internet Experts
robert roberts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
