Question about Amana PTH123B25AJ Heat Pump Air Conditioner
MY HEAT PUMP SYSTEM WILL NOT WORK IN EMERGENCY MODE
I have a Goodman heat pump split system with a HKR 15kw heat kit. I have a White Rogers(1F82-261) 1 stage cool and 2 stage thermostat. My system works great except when in emergency mode. For some reason the emergency coils will not energize, but they run correct in the normal heat cycle. I've tried calling goodman and local HVAC supposed experts and none have an answer. I've checked the wiring diagrams and Goodman shows an ''optional'' emergency heat relay that is not on my unit. How should the unit be wired without the heat realy as i know this is my issue. I also use an outdoor thermostat between the compressor and thermostat that connects on temp fall to 32.
  • bw05 Nov 10, 2008
    any possible solutions would be great i've tried just about everything
    Thanks
  • stonecldwils Dec 26, 2008
    I have a goodman hk15-1 packaged heatpump. I wired in my inside thermostat and it works great. There is a red ,g ,o,y,b for c,br for w-2,and a w for w-1.there is a e terminal inside new indoor thermostat.Wondering if i need to use it ? The outside thermostat has a bl,w,r,br and a green.Not sure what to do.
    Novelist:
  • 124 Answers
The thermostat sub base has a place to connect a wire usually white to energize the heat strips when you push the stat way hotter than the house temp. that is why the strips come on in normal heat. it also has a terminal that is only energized in emergency heat and it also should have a wire connected to it so that terminal can supply power to the strips when the stat is switched into emerg heat . you can identify the terminal from the wiring diagram and if need be jumper w2 wire over to the aux terminal and it will work. they both go back into the airhandler and power the same strips. w2..................................................................................................w2 in airhandler to strips or w2...jumper to aux......................................................................................................................w2 in airhandler to strips.
Posted on Nov 10, 2008
  • 26 Answers
On your coil pack there should be two relays ohm them out if they are bad replace them
Posted on Nov 25, 2008
Where are the heat strips on a rheem classic 10 seer heat pump
3 Ton Heat Pump Split System ' eBay
www.ebay.com/bhp/3-ton-heat-pump-split-system
eBayGoodman 3 Ton 14 SEER Heat Pump Split System GSZ140361 with Installation Kit.10k Heat Strip,Thermostat,Wiring, Disconnect Box,Pad. $1,912.00; Buy It ...
Jul 28, 2015 | Heating & Cooling
Heat Pump / Furnace Issue (Emergency)
Hi David. I'm Roger. For some reason your picture is blocking half of your message from sight. Could you please send me all you can in information but no picture. Your message is blocked from " I put in 20L of diesel for emerg, and now it works," -----That's all I can see. Tell me what you can and we will get started on for you.
Mar 16, 2014 | Heating & Cooling
Installing a honeywell thermostat with a goodman cpke24-1ab heat pump
r is red c is blue w is white y is yellow g is green o is orange w2 is w2 is also white e is brown but some installers dont follow that pattern so maybe this helps red is 24voltpositive c is 24voltnegative yellow is compressor white or w2 is heat brown is emergency heat orange is reversing valve green is fan
Mar 31, 2013 | Goodman CKL30AR30 Air Conditioner
HKR-10C FURNACE BLOWER WONT KICK ON
if you have change the thermostat it has to have the option for electric heat the thermostat has o turn the fan on in heat mode on air handlers
Jan 07, 2013 | Goodman Manufacturing Goodman HKR-10C 10kW...
Hi I would likt to replace Honeywell LR95329 with White-Rodgers 1F85. Would you please work me through on how to remove LR95329 and then how to wire 1F85? Thank.
http://www.emersonclimate.com/Documents/White-Rodgers/0037-6488.pdf
Here is a site you can visit with the installation manual for the W/R 1F85.
What type of system are you operating? Is it a Heat Pump? Do you have a heat strip or heating coil for emergency heat? How many stages of heat and cooling? I am sorry for all these questions but they really are necessary. Roger
Apr 02, 2011 | Heating & Cooling
Goodman Heat Pump E.Heat mode kicks in by itself (unit in A/C).
you have a white and yellow crossed up in the low voltage circuit
Jan 24, 2010 | Goodman CLQ36AR49 Air Conditioner
I HAVE A GOODMAN CPL E30-1 , HOW DO YOU CHECK THE HEAT STRIPS ARE WORKING ? WERE WOULD CHECK THE TEMP AT ?HOW CAN YOU TELL IF THE HEAT PUMP IS WORKING RIGHT .WHAT IS THE COMMON THINGS A TECH SOULD CHECK...
First, you need to get the spec sheet for that unit from www.goodmanmfg.com, go to bottom, click on Partner link, then put in goodman for id, dealer for pass, go to InfoFinder in the Toolkit. under model, put CPLE, under lit type dropdown put spec sheet. Click on the RED SS number in the fourth column. In the spec sheet, print out the Expanded Heating Data sheet for your CPLE30. It shows the outdoor ambient temp, follow that column to the bottom and it shows the pressures you should have. They are very very close it unit is working correctly. It also has a DeltaT for airflow. So, now you can put stat at 1 degree differential so only heat pump comes on and check temp rise and pressures. If both pressures are low, you have lost some charge. As for heat strips, turn stat up 2 or more degrees or put it in Emergency heat. Then the strips should come on....sequencer may delay stages. Then you need to use amp clamp to see if individual heat elements are pulling amps. In E heat, you need to go online and get a CFM/Kw temp rise chart. It will show you what your temp rise from return to supply should be at your cfm with the amount of heat you have..i.e. 10kw, 15kw, etc. If it is cold out and your heat pump is running with no aux heat, the temp rise will get lower as the outdoor temp falls, so alone it will not be able to keep up.
Jan 11, 2010 | Goodman PHKJ048-1 Air Conditioner
Abbreviation definitions.
Economy Mode = EM
Auxelary Mode = AUX
in em mode heat pump does most of the work in aux either an electric heating element is used or gas depending on if it is gas or all electric
Oct 16, 2009 | Ruud Central System Air Conditioner
Runs on emergency mode
By emergency mode I am assuming that you have a heat pump connected to the furnace. If so your heat pump is not functioning properly. For this I recommend a service man. To many possible problems in a heat pump to diagnos over the computer
Mar 02, 2009 | Goodman GMS90703BXA Heater
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
3,547 people viewed this question
Top Amana Heating & Cooling Experts
Donni Steen
Colin Stickland
Colin Stickland
John Tripp
John Tripp
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
