Question about Polaroid 8" Portable DVD Player, PDV-0813A
Black screen Hi, The screen on my dvd player is black...i've checked the mode the connections are good...I can barely see the picture 98% black...I've tried adjusting the brightness also...any way to help me thanks
3 Suggested Answers
  • 1153 Answers
SOURCE: No video - just a white screen
So I am guessing you have audio and no video, your monitor has went out. you can check and see if ribbon cable is slightly uplugged, but maybe just a bad monitor. These happen usually from a drop or hard hit to the unit.
Posted on Aug 14, 2007
CompuGuy44
  • 432 Answers
SOURCE: Brightness hidden
Press and hold the MODE button for a couple of seconds, Use the arrow keys to adjust. You can view the manual here.
http://www.polaroid.com/service/userguides/ce/portable_dvds/pdm0822bd_ugl.pdf
Posted on Feb 14, 2008
Hi. We have a Sony dvd player dvp-sr200p and have a wide screen tv, when we play a dvd we get a small square picture with black sides. We would like the have a full picture like we had before. Could...
With the player in STOP mode, or without a disc inserted, press DISPLAY on the remote. Then press either the UP or DOWN arrow keys (on remote) to scroll down from LANGUAGE setup to SCREEN SETUP, then highlight the aspect ratio which best suits the connected TV, in this case 16:9 widescreen (according to the manual the default aspect is 4:3 letterbox). Once you have made the change, exit the setup. It should remember the setting you have made.
Pages 26 to 27 of the owner's manual illustrate the setup procedure for this model DVD player.
NOTE: some DVDs may be encoded as 4:3 titles, hence you will see black borders at the left and right sides of a widescreen TV. Not all DVD movies are encoded in the 16:9 aspect ratio.
However, you can check your player's setup menu just to be sure.
Apr 08, 2011 | Sony DVP-SR200P DVD Player
PORTBLE DVD PLAYER THE SCREEN IS BLACK ''NO PICTURE''
if the lcd screen is attached to another small printed circuit board, you may need to replace that, otherwise you may need to have to replace the lcd panel. Good Luck :)
Sep 08, 2009 | Televison & Video
My sony portable dvd player stopped working. The
If the DVD is connected to the TV properly using the yellow, white & red AV cable and the TV is switched to AV and there is still no picture, plug the yellow lead from the back of the DVD player into the green socket. If you see a black and white picture now the DVD output is on Progressive Scan mode. See user manual to turn off Progressive Scan mode.
Aug 31, 2009 | Sony DVP-FX810 Portable DVD Player
No Picture or audio...NOTHING!!!!
You must use the remote to toggle the player OUT of HDMI output mode to use the s-video output. The device displays black screen by default, so not possible to see the menu if using s-video. The manual states to press the 'Progressive' button to change modes. Unfortunately, you can't see what mode you're toggling through until you hit the right one (Toshiba blew it here!!). Power on the device WITHOUT a disk in (you can't change modes during DVD playback mode). There are four output modes, so press the 'Progressive' button on the remote and wait for 3 to 5 seconds for the player to switch output modes. Repeat this up to four times to cycle through the available modes. During one of the modes, you should see output to your screen through the cable hookup you've physically attached. You will also notice the led's on the front panel go on and off during the process at times. Good luck ~ and don't bother calling Toshiba support ... friggin waste of time talking to a recording that's dumber than Sh#@!!
Jun 11, 2009 | Toshiba SD6100 DVD Player
DVD is hook up and no picture on the TV.
You have to make sure that the RCA cables are properly connected to the TV. Check the TV/Mode if it's set to AV1 (Audio/Video1) or AV2. You may check the TV remote to set it to AV1 or AV2.
From the DVD, the cable should be connected to OUT. And on the TV...video and audio should be connected to IN.
Apr 05, 2009 | JVC XV-S300 DVD Player
Kawasaki PVS 10921 lines in screen
unplug the device from the main power cord.remove all the external wires connected from the player.then again reconnect it properly.also check out the disc in another player.or another disc in the same player.
Nov 27, 2008 | kawasaki PVS-10921 Portable DVD Player
I,ve touch a function and my dvd plays but it is Black and White and the image rotate, I know that I went into picture ...i believe and set it to something else cannot bring it back to normal function DVD...
yes , i can help,> open dvd tray, your player will go to menu but it will be jumping so look to bottom of screen to tell what function you are in. scroll down till you see "display lets you display picture etc." when you see this at bottom of screen hit enter and and hit bottom arrow you will see pal/ntsc option hit enter again and your picture will return to normal good luck.
Nov 26, 2008 | Koss KS3112 DVD Player
My DVD player, stopped playing in color!
check to see if the coding is set to PAL or NTSC, when watching in PAL, NTSC shows up in black and white. ( NTSC is normal for the USA and a hand full of other countries... PAL is used in ASIA, EUROPE, and most everywhwere else).
Oct 18, 2007 | Panasonic DVD-S29 DVD Player
No picture but has sound
Hi If your t.v.has built-in blue screen when there is no signal, then the DVD may have been accidentally switched to progressive scan mode, or defaults to that setting if new. If your T.V. is not capable of displaying in progressive scan mode, you will just get a blue screen. If you have an older tv, without blue screen, then connect it to that, and if you get a black and white split screen when you turn on the DVD, then progressive scan is the problem. Check the manual for the DVD player for the procedure to get out of that mode, and it should then work. If you still have no video, and you are using the yellow composite video jack on the back of your DVD player, then it must be brought in for service. Good Luck!
Aug 14, 2006 | Zenith DVB312 DVD Player
White screen no picture but sound
First thing to check is the ribbon cables for chaffing, or the connection seating. This can cause this symptom. As well as a failing LCD video deciphering circuit and/or motherboard problems. not a bad chance that you'll need to replace the screen/unit. any warranty? Good luck
Jun 06, 2006 | Durabrand DUR7 Portable DVD Player
Televison & Video Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
