Question about Vivitar ViviCam 5150s Digital Camera
Format error message then memory card full message
Receive format error message , so then we format and then it will give us a memory card full message and card is empty? How do I fix this, camera wont take any pictures?
    Genius:
  • 1,234 Answers
  1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  2. 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. 3 Check its contents first to make sure that you have the right drive.
  4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Posted on Aug 29, 2010
How do I format a memory card without erasing pictures already on it?
No, format will erase all data. Try doing chkdsk <drive letter> /f in the command prompt.
Dec 22, 2012 | SanDisk 4GB Secure Digital High Capacity...
N77. it says it says memory is full, i may not be able to receive any messages. After reformatting the memory card ( which is why i lose my favorite games in the application), it still tells me the same...
The memory full error comes not because of memory card. It comes because the internal memory is full. There was no need to format memory card. you have to format the internal memory.
Here is the procedure: 1. Take backup of your contacts and messages because they will be DELETED after formatting 2. Dial *#7370# from your phone. It will ask to format. Press yes 3. It will also ask the pin or password. The default password is 12345. The phone will restart and the memory full message will disappear.
Jun 02, 2011 | Nokia N77 Cellular Phone
When I turn on my camera, in the middle of the screen in a black box it says " DCF full error" what does this mean and how do I get it to go away? I have tried resetting my camera and formatting...
Hello
Thank you for using FIXYA!!!
OK, firstly let me state what exactly the error message you are receiving concludes to:
"The "DCF full error" occurs when you use memory card in your camera which is formatted in another camera. The error is the result of improper formatting of the memory card which leads to incompatibility of the card with the Samsung camera."
Now, i the resolution for this specific problem is to format the memory card in the Samsung camera.
I know you stated that you have already formatted the card, but you did not state if you formatted the card in your camera, or on your computer.
Try the above solution and let me know if the problem still persists.
Please do not hesitate to let me know if you have any further questions.
Kind regards
lock123
May 24, 2011 | Samsung S860 Digital Camera
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
My Samsung ES30 camera gives me the DCF Full Error message. I tried other solutions, such as formatting the memory card, I even tried a new memory card. I also tried drying the inside, with the batteries...
try to remove the memory card and then format the unit without memory card.,after formatting the unit.,reset it and then format the mmc to the pc.,after 10 seconds.,insert the mmc and then power on again.,
Jan 16, 2011 | Samsung Cameras
I have Nokia N-72 cell phone. Now i m facing problem of memory full while i m trying to open any message. also i cant see any missed call, received calls and dialed call also. i have deleted some data...
There are several reasons related to this problem, like virus, message memory storage, phone memory full, etc..
First remove your memory card and check whether the error is still there or not. If so, try to delete files from your phone memory, like sms, songs, bluetooth received files, photos etc..
If there's not error, after the memory card is removed, then check your memory card, if possible scan it and try again. I would suggest you to format it after backing up the files, contacts, etc...
Set the message storage to your memory card directory not your phone memory. If you have problem doing this, please let me know so that I can assist you.
Good luck..
Thanks for using FixYa.
Jun 14, 2010 | Nokia N72 Cellular Phone
My nokia 6233 phone memory was lost.it have no files but showing full.plzzz help me
This problem is mostly caused by memory corruption or insufficient memory. Check your call logs, sms, bluetooth receive sms or files, outbox, sent items, received files and delete or move if there are some which you suspect the cause of the occupied memory. Reset you phone to full factory (Reset Factory). Then restart and see the problem whether it is gone or not. If not Try backing up your files (contacts, messages) using PC suite to your PC. Remove your memory card, scan the memory card with updated antivirus, or format if necessary. Still you are getting the same error message? Remove your sim card, memory card and reset you phone using the code*#7370#. Sometimes, even updating firmware is effective. To do this, you need to go to the repairing shop. Good luck..
May 06, 2010 | Nokia 6233 Cellular Phone
Hello, my camerca is giving me a memory card error
You probably just need to format the card in the camera. This will erase it so download any pics first.
Mar 14, 2010 | Canon PowerShot S3 IS Digital Camera
Error message Built in memory full. Also won't read memory card.
You need to format the internal memory with no card in the camera. Then, you need to format the memory card in the camera.
Feb 17, 2010 | Pentax Optio S5i Digital Camera
Memory card error - E50
Try formatting the memory card via a card reader connected to your PC. Use FAT32.
May 24, 2008 | Canon PowerShot A75 Digital Camera
Vivitar ViviCam 5150s Digital Camera Logo
74 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
