Question about Dryers
LDE412 MODEL MAYTAG DRYER, LOUD SQUEEK
REPLACED BELT BUT IT STILL HAS A VERY LOUD SQUEEK
  • Anonymous Mar 14, 2014
    my dryer is squeeking very loudly
    Scholar:
  • 66 Answers
Are you sure that is the model number? I can`t find that model number anywhere. Please check the tag on the machine. This tag should also have the serial number on it.
Posted on Nov 13, 2008
The dryer has a loud, high pitched squeek
Hello Robin, thank you for your post!
From the information you have provided your Frigidaire dryer is making a loud high pitched squeaking noise. This noise could be coming from your belt, motor, or spider arm. In order to find out which component might need to be replaced you would need to disassemble the dryer. We would recommend having a professional technician out to perform a proper repair. Improper disassembly of the dryer could result in personal injury or a problem with the dryer later in its life cycle. I hope that this information is helpful to you. -Matt
Feb 07, 2016 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Loud squeeking noise when dryer starts and continues while it is drying
Greetings,
the belt pulley needs some lubricating..they squeek and the rollers thump...of coarse, its possible a stuck roller can squeek...The front needs to be removed..UNPLUG machine and if you have a removable lower access panel..this can be removed and lube the belt pulley.
if no bottom front., remove filter screws and raise top. there are two screws inside of front.Remove the front and you can lube or change parts as needed...
Jan 25, 2011 | Kenmore 66832 Dryer
My Maytag LDE412 dryer makes a loud rumbling noise when drying clothes. I have changed the idler pulley but this did not fix the problem. Will I need to change the drum rollers or could I just oil them?
You could try oiling them. I recommend Zoomspout oil. It is used in the HVAC community. It is heat resistance and non-flammable, will not dissipate easily. themobilian_419.jpgGet it at Ace hardware.
Dec 12, 2010 | Maytag Dryers
Dryer has loud squeek when turned on
Must be the belt is rubbing inside the pulley or the motor itself is squeaking . It is important that the noise is located at first hand to have the fault detected than to speculate on a whole list of problems. So check within to see these two factors, if so replace or lubricate.
Aug 30, 2010 | Maytag PYE2300AY Electric Dryer
Rumbling noise when dryer first starts up. I can rotate the drum by hand and the noise is the same. Have also rotated by pulling on the drum belt and the noise is the same as well. Dryer Maytag Model...
Your problem sounds like drum rollers have flat spots on them or in need of lubrication
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Nov 03, 2009 | Maytag Dryers
Maytag LDE412 dryer.
Here is a link to the internal diagrams of your model.you can choose among the parts just in case.Good luck.Please do post comments and rate my answer.Thank you for contacting fixya.
LDE412 internal diagrams
Jan 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer model # LDE5005ADE has a squeaky noise when starting up to dry clothes
thanks for the question. If your dryer squeeks just a short squeek just as you start it thats not a big problem If the noise is there all the way through the cycle it could be the drum rollers locatedat back wall of dryer ,the drum rides on 2 of these they could be worn if its a short sqeek could be a slightly worn belt . thanks for the question The appliance doc
Sep 10, 2008 | Maytag Dryers
I believe the belt on my maytag electric dryer model LDE412 is going out. How to I get to the belt to remove it for replacement? Through the front of the dryer or the back?
Remove the front panel(s). and you will be able to remove the top panel, which will give you access to the top of the drum and be able to replace the belt. There should be a small pulley at the bottom of the dryer where the belt attaches to, as well as around the entire drum.
Jul 03, 2008 | Maytag Dryers
Replacing maytag dryer belt
looking at the back of the motor where the belt pulley is you would grasp belt coming down from the left side of drum then come across the top of belt pulley that is on motor shaft going clockwise around that pulley then continue back to your left and over the top of belt tension pulley going counterclockwise around that pulley this is when you will have to raise pulley against spring pressure to get belt on then release belt tension pulley make sure that belt is still in belt groove on the drum hope this helps ed
Feb 28, 2008 | Dryers
Dryers Logo
365 people viewed this question
Top Dryers Experts
