Question about IBM Wheelwriter 30 Typewriter
Beeping problem I have a Wheelwriter 1000 that is single beeping at the 20 spot on the pica/margin scale. The manual gives help for multiple beeps, but not on a single beep, always at the same spot. Any ideas??
  • Jerry Bloomer Nov 12, 2008
    THAT WAS IT!! Guess I forgot to change the narrow right margin.
    MUCHO GRACIAS!!!
    jb89
    Scholar:
  • 183 Answers
I would suspect that the right margin is set at that spot.
try moving the printhead to where you would like the right margin to be set, or all the way to the right if you don't need a r. mar., and hit 'R MAR'.
Posted on Nov 12, 2008
IBM 1500 Typewriter has started beeping once when I reach 35 on the 10 pitch scale. I have reset my margins and cleared all tabs but it still does it. It just started do it.
Have you replaced the batteries in the machine? Lift the cover and you should see a holder that usually has 3 AA batteries. You can replace them with the machine turned on. Once they are replaced, turn the machine off for a few seconds and then turn it back on. Change the margins and see if that works.
Jan 07, 2016 | IBM Wheelwriter 1500 by Lexmark Electronic...
Beeping when I type
If it beeps on every key depression try code s. If it beeps at the end of a word code 1. if it beeps at the same spot space to the right end and press R. MAR key.
DickyO
Nov 01, 2012 | IBM Wheelwriter 3500
We have ibm wheelwriter 3000. When typing it makes a beeping noise. Tried to release margins, but still beeps
If it beeps on every key stroke try code "S" If it beeps once in a while it may be the spell check code "1" will turn that off. If it always beebs at the same place the R. margin is probably set there. Space all the way to the R. and press R. mar key.
DickyO
Aug 16, 2011 | Lexmark Wheelwriter 3000 Typewriter
How to change the pitch?
Here ya go...
Margins and Tabs
Margins and tabs for both Type Mode and Mem Mode are set in Type
Mode, but can be changed in Mem Mode when text is recalled for
editing. Margins and tabs are set using the typing scale which appears
on the display in Type Mode. A blinking cursor indicates the typing
position. The letter “L” indicates your left margin setting. The letter “R”
indicates your right margin setting.
NOTE: In Mem Mode, the margins and tabs used when the text
is created will be saved with the text and recalled with it,
even if they have been changed.
Margins
In Type Mode, to signal that you are near the right margin, the
typewriter will beep 5 spaces before the margin. In Mem Mode, the text
will wrap automatically when you print.
Margins are preset depending on the pitch setting, which is the number
of characters per inch. They are:
10 Pitch 12 Pitch 15 Pitch
(Pica) (Elite) (Micro)
Left Margin 12 14 18
Right Margin 72 86 108
New margin settings remain until changed again.
1. Move the Mode Selector to Type. A typing scale appears on
the display.
2. Move the cursor using the Spacebar or Back Space to the desired left
margin setting on the scale.
3. Press Margin.
4. Move the cursor using the Spacebar to the desired right margin
setting on the typing scale.
5. Press Code + Margin. A beep confirms each new margin setting.
6. You can change to Mem Mode, if desired.
Take care,
Duane ONeil
www.fjaproducts.com
800-982-9989
Jun 02, 2009 | Office Equipment & Supplies
Types a few characters then stops typing and just beeps...
Perhaps you have the R. margin set at that point. Try resetting it at the R. end.
DickyO
Mar 18, 2009 | Lexmark Wheelwriter 1000 Typewriter
Beeping IBM personal wheelwriter
It could be that the right hand margin is set very close to the left margin. Try spacing way over to the right side of the typewriter and resetting the right margin there.
Mar 09, 2009 | Office Equipment & Supplies
Wheelwriter 5 --cant set the right margin
A beep 5 spaces before the margin is all you are suposed to get, no lock or stop just a beep
Dec 07, 2008 | IBM Wheelwriter 30 Typewriter
Typewriter is beeping at me
Probably needs a keyboard. See my tip under ww1000.
DickyO
Jul 11, 2008 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 1000 by Lexmark
Make sure the Lang feature is off. Use the code key witrh the lang key to turn off. also take all caps feature off.. Lawrence
May 07, 2008 | Lexmark Wheelwriter 1000 Typewriter
Wheelwriter 1000 (IBM) beeping
You may have the R. margin there. Space all the way to the right, press R MAR key. You also could have spellcheck on code 1 will turn it off
Jan 28, 2008 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 30 Typewriter Logo
176 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
