Question about Mitsubishi Diamond Plus 73 17" CRT Monitor
Monitor shows equally spaced rectangles
I have a Mitsubishi Daimond Plus 73 CRT monitor. Upon turning it on it sequences between white and black screens with evenly spaced 1-1/4" x 1-1/2 inch rectangles. If the screen is white the outlining rectangle lines are black, if the screen is black, the lines are white. It doesn't matter if it is plugged into the computer or not, it still shows the same thing. Is there anything I can do to get an input, or do I need a new monitor? I would appreciate any help. Thanks....Alan
5 Suggested Answers
MikeMaierTV
  • 206 Answers
SOURCE: 62' Mitsubishi WD-62525 little black and white squares instead of picture but I have sound
Mitsubishi list this problem and has a solution of replacing several small surface mounted caps and diodes. we have tried this repair 5 times and only successfully done it once. so replacing what is called the formatter board part # 930B924002 for around $ 350.00 usually repairs this type of failure, However changing this board is a time consuming thing and takes a lot of Patience. It is buried deep in the set and several other board have to be removed just to get to it
Posted on Apr 02, 2008
benwabnick
  • 2404 Answers
SOURCE: Vertical white line near the left end of the screen.
Usually when there are colored lines on the LCD its because the screen is going bad. Quick way to verify this, try a different monitor on your computer and if the line goes away then you know for sure the monitor is bad.
If you try a different monitor and the line remains then you know that the video card is bad.
Posted on Jun 03, 2009
  • 4 Answers
SOURCE: My Mitsubishi WD-52525 is only showing black and
Check the white rectangular ceramic fuses on the FMT board. You blew one of them so there's power missing to some of the circuitry.
Posted on Jun 25, 2009
texasdan
  • 60 Answers
SOURCE: Mitsubishi tv; black & wht rectangles only on screen.
Bad capacitors and probably a surface-mount fuse on the Formatter board.
There will probably be bad caps on all five boards within the chassis.
Posted on Oct 04, 2009
Sony CPD 200SX 17" CRT Monitor: Upon resuimng
Monitor has gone to monitor heaven. time to do some shopping since repair not cost effective.
Apr 04, 2017 | Sony CPD Computers & Internet
Sep 14, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Starlogic 19 inch monitor gets unreadable screen
Is this monitor a CRT-type? Chances are your picture tube is malfunctioning. This is a common error among CRT monitors. I advise you to replace the monitor with an LCD, as the power consumption is far less than CRT. Plus, it takes less space.
If you prefer a repair option. have someone "flush" the tube. This may fix the problem.
Mar 15, 2009 | Computers & Internet
Monitor problem
The reason I had asked if you had tried a different monitor was to determine if it was the monitor or the computer that actually had the problem. That wasn't clear in the first question.
A computer that is having issues will cause the same symptoms you described.
Repairing CRT's is beyond my level of expertise. When I get into a situation like this, I would just replace the monitor. Sorry I couldn't have been more help.
I stopped using CRT's when the price of LCD's dropped.
Aug 04, 2008 | Mitsubishi Diamond Plus 73 17" CRT Monitor
Monitor
Check relay in power section for fault.To degaus the monitor.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Jan 10, 2008 | Samsung 793S 17" CRT Monitor
Oct 17, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi monitor is distorting the picture
well first af all ,you never find this "loose wire" because it is a mith. what you have is a "cold solder" in the vertical IC, if you have a solder iron , and the ability to open it (without scratching), and then take off all the shields (without cutting your fingers), and get the solder area (without breaking the Tube). at this time ,it take you 1 minute to solve...!!! iF not... leave it to the repairman!!!.
Sep 15, 2007 | Mitsubishi Diamond Plus 73 17" CRT Monitor
Black and White rectangles, no picture just sound
Need a little more info on your problem. My crystal ball is not working at the present. You need to tell us more about where these rectangles are, how are they spaced, when they are there. Do they move around or change colors. Give as more to work with here.
Aug 28, 2007 | Mitsubishi WD-52525 52" Rear Projection...
NEC 77F CRT monitor - displays alternating black \ white crosses
Sounds like its stuck in test mode. Make sure that none of the buttons are stuck in place and does it make any noise while its turned on?
Jul 19, 2007 | NEC MultiSync 77F 17 in.CRT Conventional...
Mitsubishi Diamond Plus 73 17" CRT Monitor Logo
Top Mitsubishi Computers & Internet Experts
Shaukat Bhutto
Level 1 Expert
Alun Cox
Are you a Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
