Question about Sanyo Televison & Video
Time to time I get only a horizontal line on picture tube of my 26" Sanyo TV
    New Friend:
  • 74 Answers
Take it apart, there will be a chip like la7835 (then number might be different) it will be an upright chip. 7-15 pins. solder it. if you cant find the chip take it apart and turn it on and tap on all the heatsinks and the line should appear when you tap the vertical chip. then resolder it, and if you want it to last longer replace the 100@25-50v capacitor next to it
Posted on Nov 10, 2008
How can I fix a problem with my Sanyo standard CRT TV?
well,the last of the dinosaurs is in its death throws,a new picture tube is 500 bucks,a flat screen is 400,its up to you,do you replace the tube and pay to install it or buy a flat screen and not worry about it for a few years and save electricity
Jun 11, 2015 | Sanyo Televison & Video
My sanyo tv screen keeps disappearing with green lines on thris
Green retrace lines could me two things, the green gun in the CRT is shorting out and that is the picture tube, and it is not worth fixing. Another thing that it could be is a bad neck board and the green driver transistor is shorting, but that would be green all the time, I would say it is the picture tube, and buy a new TV.
Feb 23, 2011 | Sanyo DS32920 32" TV
Steady vertical lines in picture Sanyo viZon DP26647 LCD HDTV
I have a Sanyo DP42746 model, 42". From my research I believe the lines in the picture are letting you know your Buffer Board is about to go out. Mine recently cut out, and it caused horizontal lines to appear. Hope this helps : /
Dec 17, 2010 | Sanyo DP26746 26 in. LCD Television
Picture go into a thin line.
You have a thin horizontal line in the center of the TV. You, in this case have vertical IC that has bad grounds. Resolder the vertical IC pins and check the capacitors in the immediate area and replace these caps as necessary. If you still have a horizontal line, you will have to replace the vertical IC. Find a TV tech or someone with electronic experience to do this for you. Should be reasonable to fix. Thanks for asking and Good Luck!
May 30, 2010 | Sanyo AVM-3659S 36" TV
Tv beginning to flash green with horizontal white lines
From your description it sounds like a bad picture tube. The lines are called retrace lines. There is a small chance that a component on the small board that connects to the neck of the tube may be bad. Without model number information it is very difficult so say further. Some picture tubes can be re-jeuvenated with the appropriate machine ( at a TV repar shop)
If you feel adventurous and are careful you might try GENTLY tapping the neck of the tube and see if picture improves/goes out. If the tapping does change the picture it is definitely the tube
Mar 12, 2009 | Loewe ARC332 32" TV
Line across picture tube
Had the same problem with mine. The vertical hold chip broke loose from the solder,Resoldered it works fine. You will need a magnifying glass to see this on the bottom of the board.
Jan 13, 2009 | Sanyo DS31590 31" TV
25 inch sanyo tv
If the horizontal lines going through the picture are fine white lines, then I would suspect the picture tube as having a heater to cathode short or some other problem. Since some sets have had a 3 year warranty on the picture tube, you may be lucky unless the labor to replace the tube is more than the set is worth. Sanyo is usually not a good name in consumer electronics anymore, so if you're looking for a replacement I would look elsewhere.
Mar 31, 2008 | JVC AV-32F704 32" TV
Sanyo ds 25500 Television
No, you have either a bad solder connection on or near your vertical output IC, or a defective IC itself. Don't leave the set on for long with the line across the screen or your pic tube will be toast.
Mar 05, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Sanyo television
Susie, you either have a shorted green drive transistor or more likely a shorted cathode inside your picture tube, transistor repair is a cheap fix, picture tube means set is not worth cost of repair, hope this helps
Nov 27, 2007 | Sanyo DS25390 TV
Televison & Video Logo
46 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
