Question about Hotpoint Aquarius WMA56 Front Load Washer
Will not finish the cycle
I changed the bearing on my machine ive put everything back together, now the machine will not let enough water in and will not flush the powder from the dispencer,then the machine will start as normal for about 1/4 hour then 2 lights come on at the front of the machine witch are the rinse&spin and final spin lights adding to the wash light that was on already,then the machine will not do anything else. if anyone could help me please?
  • colinroberts Nov 10, 2008
    if anyon could help me that would be great.
    Scholar:
  • 86 Answers
Do you still need help?
Posted on Dec 30, 2008
Testimonial: "thank you"
My F&P GW601 stops during final rinse, and beeps an error condition.
  • I just fixed a F&P GW612. There was a darning needle stuck in the drain motor pump stopping the propeller from spinning around. I fixed it for my mum by watching a couple of You Tube videos. Easy job to do. Took me about 1.5 hours including drawing out the water from the drum with a bucket & jug first. Lay the machine on a soft mat, remove the motor pump from underneath, clean it out. (You could find a foreign object such as a coin, cloth, rubber band etc.)
    Put it back together & test if it's pumping out water at the rince cycle by doing a low water wash cycle. So happy, job done & I saved my mum some money!!
Aug 29, 2015 | Fisher and Paykel Washing Machines
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Fisher & Paykel GW611 Not filling with water
Hi just read your posting.Did you remove any wires to the control module which is located under the top panel when you replaced the bearings.Now did you put the cold inlet hose to the water valve marked with the letter C and the hot to H ?These letters are next to the valves.Have you got the Efficiency option button?Can you select a manual water level instead of just an auto fill?Have you tried to put the machine throe a spin cycle?Do you hear any water coming into the machine at all?Please with additional information to these questions and I am sure we can rectify this problem for you.
Jun 28, 2010 | Fisher and Paykel Fisher & Paykel Washer
I can't open the door of my washing machine it is a front loader lg intellowasher 7 kg wd8013c please help asap
FOR ANY REASON THE WASHER MACHINE DIDNT FINISH ITS CYCLE!!! AND IT IS A SAFETY THAT IF DOESNT FINISH ITS CYCLE THE DOOR WONT OPEN!!!!
I HAD ONE LIKE THAT AND I BROKE IT APART!! AND I SAW THE WATER PUMP WAS THE PROBLEM SO I CHANGED IT AND PUT IT BACK TOGETHER AND LET FINISH ITS CYCLE AND OPEN THE DOOR!!! AND STILLS RUNNING!!!
Oct 05, 2009 | Washing Machines
Machine will not do the whole cycle
Your machine is not gettjng water through the hot water valve.resolve this and it will work ok.
Nov 10, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Hoover optima AAA1600 hntf 6167 washing machine
Most washers have a drain hose that is mouted high to keep the water in. If you drop the hose to floor level it will drain with out help. Be sure you have a floor drain or bucket. Then check the belt on the motor if there is slack it will not engage the pump for drain to operate. Need to tighten the belt.
Mar 25, 2008 | Indesit W 123 Front Load Washer
GE ADORA model WHDVH626FWW
you have to clean out the filter on the bottom by removing the lower panel and twisting the cap... careful lots of water comes out but will work great after
Nov 24, 2007 | GE WSXH208A Front Load Washer
Hotpoint wma54 washing machine
Being fairly mechanically adept - I tried this on my old Hotpoint WMA31 -- it took around 90 mins to get the drum out (virtually everything had to come out) and 1- mins to split it in two - then another 30 mins to knock the bearings out. I then ruined one new bearing trying to knock rather than pull it in and had to order a second set - then whatever I tried I could not get the drum fully back on the spindle (which was rather pitted) so ended up scrapping it !
As an aid to putting it back together I took 32 digital photos of different stages of getting the drum out so that is a measure of complexity...
Nov 07, 2007 | Washing Machines
Hotpoint Aquarius WMA56 Front Load Washer Logo
51 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
