Question about Hotpoint Aquarius WMA56 Front Load Washer
Machine will not do the whole cycle
I changed the bearing on my machine ive put everything back together, now the machine will not let enough water in and will not flush the powder from the dispencer,then the machine will start as normal for about 1/4 hour then 2 lights come on at the front of the machine witch are the rinse&spin and final spin lights adding to the wash light that was on already,then the machine will not do anything else. if anyone could help me please?
  • colinroberts Nov 10, 2008
    spot on mate. thank you.
    hi mate, could you tell me if i can feed the hot and cold water valves with cold water mains?will the machine warm up the water?
  • 135 Answers
Your machine is not gettjng water through the hot water valve.resolve this and it will work ok.
Posted on Nov 10, 2008
  • pedropony2 Nov 11, 2008
    Yes it will. happy to help
2 Suggested Answers
  • 86 Answers
SOURCE: will not finish the cycle
Do you still need help?
Posted on Dec 30, 2008
Testimonial: "thank you"
Its a 450 mah hoshizaki, it keeps jumping from freeze cycle to harvest cycle without giving it enough time to make a load of ice
usually, if it does not stay in the freeze cycle long enough to make ice or it just makes slivers of ice, it is loosing water. during the freeze cycle, look to see if water is draining down the drain from the machine. If not, I would look at the float position. it should be almost completely in the lower, down position. give that a shot.
May 31, 2014 | Hoshizaki Cubelet Ice MakerDispenser Water...
Fisher & Paykel GW611 Not filling with water
Hi just read your posting.Did you remove any wires to the control module which is located under the top panel when you replaced the bearings.Now did you put the cold inlet hose to the water valve marked with the letter C and the hot to H ?These letters are next to the valves.Have you got the Efficiency option button?Can you select a manual water level instead of just an auto fill?Have you tried to put the machine throe a spin cycle?Do you hear any water coming into the machine at all?Please with additional information to these questions and I am sure we can rectify this problem for you.
Jun 28, 2010 | Fisher and Paykel Fisher & Paykel Washer
Panasonic SD-250 not mixing. Pan was submerged in water.
Hello LT,
There is a sealed bearing and shaft on the bottom of the bread pan that the paddle sits on. Submerging the whole pan in water may have caused water to seep into the bearing on the bottom of the pan, or the whole pan might be worn. Slight resistant in 2 places on 360 degree is not bad. Let everything dry out and we will try a few things. First, put the paddle in the empty pan and place it in the machine. Start a kneading cycle and look trough the lid to see if the paddle is spinning freely and with smooth motion 360 degrees. Watch it until you are sure it will run freely for the entire cycle. If it does not run freely, stop the machine and take the pan out. Now start the kneading cycle again with the pan out and look at the motor shaft at the bottom of the machine to see it it is running freely. If it is running freely, then the problem is with the pan, and the pan needs replacement. If the motor shaft is not turning freely, then the belt is slipping in the machine and needs to be replaced. If everything runs smoothly check the kneading time to make sure your mix has enough time to knead correctly. Hank
Nov 14, 2009 | Panasonic Kitchen Appliances - Others
How to change wheel bearings on a 96 cavalier
The wheel bearings on your car is contained in a sealed wheel hub. You have to change the whole hub to change the bearing. Remove the wheel, the brake caliper, the rotor. There will be three bolts holding the hub on from the back. You will need to remove these bolts and slide the hub off of the spindle. then grease the spindle slide on your new hub and bolt everything back together.
Sep 27, 2009 | 1996 Chevrolet Cavalier
Has a squeek when it is in the spin cycle
mostly the motor problem  and other possible problem can be  that a bearing is bad.If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
May 08, 2009 | Washing Machines
I moved my washer cause of relocating and now when on spin cycle it makes a howling noise, what can i do to fix the problem, its a front loader gallery series??
Picture1 - Picture2
May 05, 2009 | Frigidaire Washing Machines
Water doesn't drain
water discharge drain $50 part, easy installation. google the lg model to locate part.
Nov 19, 2008 | LG WM-3677HW Front Load Washer / Dryer
Hotpoint wma54 washing machine
Being fairly mechanically adept - I tried this on my old Hotpoint WMA31 -- it took around 90 mins to get the drum out (virtually everything had to come out) and 1- mins to split it in two - then another 30 mins to knock the bearings out. I then ruined one new bearing trying to knock rather than pull it in and had to order a second set - then whatever I tried I could not get the drum fully back on the spindle (which was rather pitted) so ended up scrapping it !
As an aid to putting it back together I took 32 digital photos of different stages of getting the drum out so that is a measure of complexity...
Nov 07, 2007 | Washing Machines
Intermittent hot water valve not opening
problem may be low water pressure. try putting in a y-piece so cold water is supplied to both valves. only effect will be that wash cycle will be a bit longer
Dec 17, 2006 | Miele Novotronic W1918A Front Load Washer
Hotpoint Aquarius WMA56 Front Load Washer Logo
50 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
freddyfox
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
