Question about Toshiba Portege R100 Tablet PC
Laptop will not go in BIOS or boot up
I work at a pc repair shop and we got a toshiba portege R100.
the problem is it won't boot or go in the BIOS.
the only thing i get is a blinking horizontal cursor at the top left screen.
it stays like that forever.
any help would be apreciated.
thanks
  • Anonymous May 06, 2009
    i got the same problem but pcmcia drive will not help anything here...
    i guess it is a hardware problem like some missing contact the r100 turns on but does NOT do anything after, can't access anything or furthermore boot from any source...
  • Bogdan Robert Marius Jun 22, 2013
    try an hard reset on bios ,open it up and pull the bios batery out for like 5 minutes (with no power source)
We use these and several times I have had to pull the battery, disconnect the power cord and hold the power button for 30 seconds (count slow). After that, it boots fine.
Posted on Jun 05, 2009
Hi there. the only practical way to get the r100 to boot is from a pcmcia freecom drive. hope this helps
Posted on Jan 08, 2009
Portege R100 (Toshiba). I have not used this laptop in over a year and can not rem the bios password I'd set. Tried all I could think of. Is there any way to reset the password on this?
Hi,yes there is but you'll have to open the system up,if you have no prior I.T expertise I'd suggest you take to a qualified Technician,but if you do here is how:First remove the Battery,then uncouple the system taking of where each of the screws go to then locate the CMOS battery(small battery Lithium Ion mostly in the shape of a cent or smaller),it may be underneath the keyboard or just behind once the external cover is open.unplug it from the system for about an hour or two reconnect it,couple the system and boot,go to Bios,reset Date and Time and save,then exit.
Dec 31, 2010 | Toshiba Portege R100 Tablet PC
How i format my toshiba r100 harddisk completely.
when you start the computer up with the install disk of your windows there is an option to format the drive. Your other options are more technical (boot disks etc).
Oct 11, 2010 | Toshiba Portege R100 Tablet PC
Installing Windows XP OS from CD
I have been installing XP on Portege M200 laptops.
I use a usb floppy to install the latest bios update from Toshiba's support site.
After the update the laptop will boot from a USB Cd/DVD drive.
be patient the first part of the up date goes extreamly slowly but it seems to keep working and the install will work.
Apr 20, 2010 | Toshiba Portege M205-S810 Tablet PC
Toshiba R100 suddenly very slow(!)
I'd suggest sending it back to where you bought it, this sounds a lot like a factory problem and it should be covered under warranty.
May 27, 2009 | Toshiba Portege R100 Tablet PC
Toshiba Portege 3500 Win Xp Bios password - How Can I flash bios?
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it and use BIOS / CMOS Tools from it.
After that use the patch
Mar 08, 2009 | Toshiba Portege 3500 Tablet PC
Toshiba Portege R100 CMOS/BIOS PROBLEM at startup.
I'd look at trying to replace the BIOS battery...
Check out this guide for dis assembly instructions :
http://www.irisvista.com/tech/laptops/Toshiba_Portege_R100/remove_system_board_1.htm
Feb 22, 2009 | Toshiba Portege R100 Tablet PC
Usb cd rom will not boot can i boot from sd card
yes you must change the boot order and activate the legacy USB support if exsisted
Jan 25, 2009 | Toshiba Portege R100 Tablet PC
Boot up problem
NOTE: Ususally when computers DO NOT find any startup information on the SELECTED DRIVE (like when you click a key) it goes to the default drive.
WHICH IS YOUR HARD DRIVE.
Meaning it is probably your Harddrive is broken, or your connection from hard drive to motherboard is broken
Burn a Live CD bootdisk of some linux distribution
liek Slax, google it.
Burn it to a bootable CD and put it into your drive, then select to boot from it.
If it boots only using your CD ROM drive, if that works then its probably not your BIOS/rest of computer, which is good.
And while in the live cd, you can see your harddrive and see files, that means its not broken its just your connection to it....either way im guessing youll have to send it in.
Jan 10, 2009 | Toshiba Portege R100 Tablet PC
Toshiba portege r100
I believe if you download the pdf manual contained in the software here it may give you the answer as to what type of drive....
http://www.manualnguide.com/manual-get/6459/
Oct 17, 2008 | Toshiba Portege R100 Tablet PC
Screen problems on Toshiba Portege R100
Right click on the computer's destop and view the display properties. Under the tab where you can alter resolution you can manage multiple monitors, It sounds like your laptop is setup to display through it's external VGA by default. Click on the two squares it shows and try to set your main screen as default.
May 30, 2008 | Toshiba Portege R100 Tablet PC
Toshiba Portege R100 Tablet PC Logo
1,055 people viewed this question
Top Toshiba Tablets & eReaders Experts
micky dee
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
