Question about Canon PowerShot A70 Digital Camera
No image - vertical, grainy,lines
When you look thru the lense, it only shows horizontal, grainy, lines and records only the lines as the image. I can view pictures taken previously to the problem from the memory card just fine.
  • Kristenfrank Nov 13, 2008
    Awesome advice and very fast response time! Thanks for all of your help! Cannon is sending me a shipping lable and is reapairing it free of charge. Thanks again!
  • mjloup Dec 14, 2008
    I have the same problem., vertical, grainy, lines problem
  • 10,594 Answers
Its known problem of CCD Imager in Canon A70 camera and CCD Imager needs to be replaced.
Canon offers Free of Cost repair for such problem in A70 model.
Click Canon CCD Advisory for details.
Posted on Nov 10, 2008
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
Tip
Yea.. its a great tool.. And there is another way around..(As many line as you...
Have u ever tried the Measure tool which is located under the eye dropper tool. Its really a cool tool to transform a image. Suppose an sccaned image is not straight u can use the measure tool to draw a line on the top of the image slanting area and then goto image Rotate canvas - Arbitary and apply Colock wise or anti clockwise according to the desired side the image should be corrected. Thanks
on Sep 17, 2007 | Adobe Photoshop CS2 for PC
How can I measure a sunglasses frame?
A frame has 4 basic frame sizes.1. Eye Size - refers to the horizontal width in millimeters of one of the frame's lenses.
2.Bridge Size - measurement is the distance in millimeters between the two lenses. It is measured between the two closest points of the two lenses.
3.Temple Size - is measured along the length of the temple, from one end to the other, including the bend.
4.Vertical Size (B) - refers to the vertical height of an eyeglasses lens, and is measured from the tip to the bottom of the lens aperture of the frame. The measurements are taken from a horizontal line intersecting with the top of the lens, to the horizontal line intersecting with the bottom edge of the lens. The B measurement is only important when ordering multifocal lenses; follow this link to read more about progressive lenses.
Nov 07, 2010 | Clothing Accessories
Quality of pictures when printed are very grainy,
the problem must be because of the resolution dpi value. it does not matter if your image is BIG and looks great on your comp, but if the dpi value (which can be found by Image->properties thru the right-click option) is lower than say 300, the image won't look good on print.
Dec 11, 2009 | Canon Cameras
The projection lenses vertical and horizontal lines are off level
Your convergence ICs have failed. replace both STK392-110 ICs
May 23, 2009 | Toshiba 50HDX82 50" Rear Projection...
Distorted image
Sounds like you may have a faulty CCD Sensor or the wiring came loose. My Camera did the samethimg. Email carecenter@cits.canon.com and explain to them the problem.
I
Aug 06, 2008 | Canon PowerShot A75 Digital Camera
Horizontal lines
sometimes I encounter vertical lines below..... when i tap the sides it clears for a time being  but after a few moment again appears
Dec 06, 2007 | AOC 19LVWK LCD Monitor
The image turned very colorfull and grainy
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor
Aug 01, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
What is the focusing screen display?
There are two display modes newly added for the DiMAGE 7i, grid and scale. The grid mode is to show a grid over the entire screen. This makes it easy to align the camera to objects vertically or horizontally. In the scale display mode, horizontal and vertical lines cross at the image center to divide the view to four sections, and each axis is scaled. This function is useful for close-up photography. The grid or scale on display is not recorded.
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Canon PowerShot A70 Digital Camera Logo
150 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
