Question about Maytag PAV2300 Top Load Washer
Amana washer not agitating and does not spin all the time
We have ale956eaw amana washer think it was made in 2000. We replaced the brakes a year ago and also replaced the Idler Pulley Wheel. about a month ago is stopped agitating, now it is not spinning well. the blet looks ok. but is not that tight. there is also a black film on the bottom of the washer under the motor. Help please.
  • paulamy Nov 10, 2008
    that was the dryer # the washer is lwa90aw
    Scholar:
  • 121 Answers
"Its not spinning well" that means it is spinning but at a relatively low speed .....if this is so try having the motor serviced.....or replaced.......also have the capacitor checked...
Posted on Nov 10, 2008
Amana nav5805aww washing machine won't spin
You will need to replace the thrust bearing kit. Here is the part to order.
It comes with the instructions and is an easy fix.
Oct 30, 2012 | Amana NAV5805A Top Load Washer
My Amana NAV2330AWW (S/N12279742EP) has been in service for six years. It has begun making a loud squealing, friction-like noise at the spin cycle. I removed the agitator assembly after being told it...
Firstly i want to apoligize for the quesionable advice,some on here or elsewhere on the net fixed their washer and suddenly their are experts!!
Now Then as you know your washer is made by Amana/Speed Queen and has no agitator dogs(a quick search of parts breakdown will show anybody that) it also has no spin tube (aka basket drive),the brake pads which it does have would squeal only when washer stops spinning if they were bad just like squalling brakes on or vehicle the are quite till applied if bad,what the most likely cause of the noise is going to be the tub bearing,it is on the bottom of the outer tub. The inner and outer tub must be removed,it is advisable if replacing the tub bearing that you also replace the tub seal since it may not seal correctly once taken apart and leak badly.The hub taht connect inner tub to transmission must be removed so ya can remove the outer tub it requires a special wrench which is not to expensive but nothing else will work. IF ya want to go ahead and repair this the part numbers are;
TUB BEARING 40004201P
TUB SEAL 35-5655-1
SPANNER WRENCH 306P4
PROCESS TO REPLACE BEARING;
unplug power
remove front panels
remove screws holding top to cabinet
remove plastic tub cover by down slightly and lift tabs
remove agitator
remove bolts from hub under agitator and remove inner tub
use that spanner wrench and a hammer on nut on hub and remove nut in counterclockwise direction by hitting wrench w/hammer
lift off hub
remove rubber tub seal
remove all springs from outer tub by locking on vise grips and pull springs off
remove bolts holding outer tub to the to tub support
pull off outer tub and set down so bottom is facing up
remove old bearing and install new old
reassamble in reverse order
this is a link for parts breakdown http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Washer-Parts/Model-NAV2330AWW/1268/0153200?pathTaken=&prst=0&shdMod=NAV2330AWW
to order parts order from sears or for a cheaper price by a little rearsch from
apdepot.com
assuredparts.com
appliancepartspros.com
repairclinic.com
Good luck, if you have any question reply and ask away.
Gene
Aug 07, 2011 | Amana NAV2330AW Top Load Washer
Amana Washer LW4303W. Tub spins much to freely while the agitator agitates. Could be coincidental but this problem seems like this all started after I replaced the drive belt. Washer cycles like it...
Yes, there is a brake that holds the tub while the machine is agitating. I don't have a manual handy for that model, but you probably have a plastic pulley in the center bottom of the machine. The brake is above that. There is a cam arrangement inside the pulley that will disengage the brake when in spin.
May 10, 2011 | Washing Machines
Whirlpool extra large capacity washer. Does not agitate or spin. I hear the motor running trying to spin/agitate. I checked the motor coupling as I had to replace that a couple years ago and figured it...
I would replace the clutch and the bakes on the machine. It could be that the bakes did not release and then the clutch is going to burn up, and in that case the brakes are bad anyways so replace both of them.
Jan 04, 2011 | Washing Machines
Agitates but won't spin
either bad clutch / brake or bad transmission
Jul 19, 2010 | Whirlpool GCAM2792LQ Top Load Washer
Washing machine will not agitate but it spins.
The brakes are shot,so the tub spins in agitate will also cause it to leak part number R0000014 run about $25.
Look straight up from the bottom pulley you will see the brake assy looks kinda like a clutch plate,look around the outer edge of that you'll see the Pads they have two 3/8 inch bolts in each one,to get the new ones in you'll have to use a screw driver to open the plate.
Sep 23, 2009 | Amana ALW480DA Top Load Washer
Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
Aug 10, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Amana Washer LWA50AW doesn't spin
Ifi t does not spin it may be the timer. Try it in the delicate cycle to see what happens. Actually try all teh cycles to see if it spins in one of them. IF so it most likely is the time and is a 15minute job to replace.
Feb 26, 2009 | Amana ALW480DA Top Load Washer
How do you diagnose a bad washer pump vs a cloged line?
Amana ALW480DAW seems to be not completely draining. When I start a new load water in basket becomes dingy and smells. Washer smells when it has not been used for a couple of days. We have checked the outflow and inflow drain tubes found no problems. It seems to spin and agitate normally, it drains to a point and leaves water in it, not visible in the basket. When we blow on the outflow tube when it is done draining there is still water present, we can hear it bubble.
Feb 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Maytag PAV2300 Top Load Washer Logo
119 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
