Question about LG LRTN19314 Titanium Top Freezer Refrigerator
Re: Lg Lrtpc1831t
Why does this happen & how can I resolve this? Whenever I close the refrigerator door, the freezer door props open.
  • 878 Answers
Shirlee, you might not have the refer leveled right. The doors should close by themselves when released. Have someone bring the front levelers down so it is pitched back a little. This should eliminate the freezer door staying open. This is caused by the rush of air from the lower compartment to the upper compartment during closing.
Posted on Nov 04, 2006
Why does my refrigerator short out when I open the left door?
Something in the left door is shorting to ground. The constant movement of the door has worn thru a wire/wire bundle and that wire is touching metal.
Dec 07, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
I have top freezer LG refrigerator (I have it for a week, so it's a brand new). When I close refrigerator door the freezers door bounces opens and closes). Hoe to fix this problem?
When you close the door, the air pushed in by the door has to do somewhere, so it may momentarily pop the other door. As long as it closes right away by itself, no problem.
Apr 19, 2011 | LG LRTBC1825T Top Freezer Refrigerator
I have LG Bottom Freezer Refrigerator for 5 years. I noticed that yesterday that a funny motor sound came from the back of the refrigerator. When I open the refrigerator or freezer door, the sound would...
The problem could be a bad bearing in the condenser or evaporator fans...more likely though is that the evaporator fan is hitting an ice build up on the coils...this can be caused by a bad defrost timer...
more closely check on the sound... you will find it....
a few drops of oil on the fan shafts just ahead of the motor will not hurt either...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Sep 17, 2010 | LG LRDC22744 Bottom Freezer Refrigerator
Freezer is working but refrigerator is not
My Maytag (side by side) had a similar problem, turns out to be the damper door. The freezer does the cooling, there's a damper door between the fridge and freezer that opens and closes to control fridge temp. Find the damper door and prop it open. If the fridge temp drops overnight, you'll need a new damper ***'y.
Oct 01, 2009 | Frigidaire Refrigerators
I have a top freezer. Whenever the refrigerator door is closed, the freezer door pops open. There appears to be a good seal around each door... How do I keep the freezer door from poping open, when...
Replace the seals. It may appear to be in good shape but what is happening is the compressed air from closing the refer door is going up and releasing the seal on the freezer I would replace the freezer seal first as that should solve your problem.
Aug 22, 2009 | GE PTS22LHR Top Freezer Refrigerator
Bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
Dec 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Frost inside freezer door
there is a small electric heater along the door gasket where you see the frost building up, this heater has apparently stopped working. this will also cause the door to pop open due to a poor seal. feel around where the door gasket contacts the refrigerator and it should feel a little warm. if not then a service company can replace those heaters. should not be too expensive.
Jun 28, 2008 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Freezer Door Popping Open
Look at the bottom of the freezer door, there is a little plastic stopper there. It may be worn out or broken. When you close the door this is what holds it there. Start there first.
Sgt 48
Jun 17, 2008 | LG LRSC-26922 Side by Side Refrigerator
Freezer door
You may have a door alignment problem and requires a qualified LG technician to find the problem.
May 18, 2008 | LG LRBN22514ST Bottom Freezer Refrigerator
LG LRTN19314 Titanium Top Freezer Refrigerator Logo
168 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
