Question about Nokia N96 Smartphone
Low ringtone tried every thing within phone,it plays ringtones when i am going through the tones menu but when someone calls it is very faint.
  • 4 more comments
  • Anonymous Nov 22, 2008
    when sum1 rings ist very low
  • n96fury Nov 25, 2008
    i have the same problem, set a ringtone, but when someone call it is very faint with nokia tune!
  • JoshyJo Dec 09, 2008
    Same problem, no matter what ringtone I set, always plays Nokia tone very low & miss all my calls!
  • Anonymous Dec 11, 2008
    I have same problem as well, and I tried everything to solve it. It must be a bug...
  • palmtalk Dec 15, 2008
    I have the same problem! Phone is +- two weeks old!
  • Anonymous Feb 04, 2009
    low ringtone
You might try this:
Menu>Tools>Utilities>3-D tones>3-D ringing tone effects>Off
On my N96 it works.
Posted on Dec 11, 2008
How to change call ringtone on nokia e63
Hi Violin,
I have this steps for you for work around setting up call ringtone. Hope it helps.
--- there should be no prob to set a custom tone if you go to the tone and select options you should get an option to select from a list from the menu otherwise go to profile and select edit then when you come to ringtone select options and you will get options you should be able to select a tone from the gallery
---I discovered something about this problem. It appears that if you have the same phone number assigned to two (or more) contacts the ringtone plays the default ringtone. Once I deleted one of the contacts with the same number, it played the correct custom ringtone. What is strange is that both contacts had the same ringtone. BTW, the reason I had done this was to simplify the voice command to make a call to this contact.
Apr 25, 2014 | Nokia E63 Cell Phone
The User Manual does not explain how to change the ring tone, can you help please?
Hi gary468780 There are two ways by which you can change your samsung mobile phone ringtone . For changing ringtone of your cell use one of the following methods : 1} Go to Music option from main menu then you will get music library files to play and listen music if you like any song then you can set it as your ring tone by selecting option menu and then select set as Ring tone 2} Go to setting option from main menu and then select profile setting and then edit the profile setting after editing profile you will get another menu from which select Vice call ringtone option and then change ring tone and save it
Jun 06, 2011 | Samsung GTC3300 Cell Phone
How to set mp3 song from memory card as your caller tune
I think that there have been some mistake.....Caller Tune means the ring-tone which is hearing by someone who is calling you.So you cannot set the caller tune yourself, it is provided by the Sim service provider.Here However, Ring-Tone means the tone which you are hearing when someone is calling you.We can easily set this tone by using....Menu......>Profile...........>Ringing tone setting....Set the tone what you wish............................
Aug 10, 2010 | Nokia N73 Cellular Phone
I want to change my ringtone on my samsung C3050, but i don't know how to.
Change your ringtone
1. In Menu mode, select Settings → Phone profiles.
2. Scroll to the phone profile you are using.
3. Press <Options> → Edit.
4. Select Voice call ringtone.
5. Select a ringtone category → a ringtone.
6. Press <Save>.
Jan 25, 2010 | Samsung C3050 Cell Phone
HOW DO I SET THE RINGBACK TONES?
phonezoo.com or go to rhapsody.com and make your own.
Jan 10, 2010 | LG enV Touch VX11000 Cell Phone
I would like to change text message ring tone but can only find how to change ringtone and not for text messages
I found the answer!! Go to Menu>Settings>Profiles, then go to Options>Edit. Push the right side of the square (that you use to navigate the menus) so that you're working with New Messages, not Incoming Call. Go down to Message Alert Tone, then go to Options>Change>Use Effect Tone. If you were trying to use an .mmf that you downloaded, or any of the preloaded ones that can be used as incoming call ringtones, you'd go to Use My Alert Tone here. There are 4 tones under Use Effect Tone, and you can play them and choose one, just like you do to play and choose your ringtone.
Jul 23, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Using a file in MY Rintone file as my call ringer
When Your Ring Tone Is Highlighted Click on it then click Menu And Select Set As Ringtone. That Will Now Be Your Defaullt Ringer.If You Want It To Be A Custom Ringtone i can't help you with that sorry.
Jun 24, 2008 | Pantech Duo Smartphone
6600 ringtone
go to Profile in Menu
select outdoor
options- personalise
set to------
Ringing Tone-  any ringtone u want
Ringing Type- Ringing
Ringing Volume- Full
Message Alert tone- any tone u want
Vibrating Alert- on
keypad Tones-__________
Warning Tones-_____________
Alert For-_________________
Profile Name-_____________
Mar 25, 2008 | Nokia 6600
Ringtones
hi, before applying tone, play it & listen, if it plays sound. Resent ur mobiles master setting & apply now. bye
Oct 01, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
K1M Ringtone PLAY function not working
This same thing just happened to my today after I went to the store to get the phone updated.  When I took the phone in, it wouldn't play different ringtones from different contacts.  The update fixed that, but now you cannot preview the ringtones from the sounds menu.
Aug 09, 2007 | Motorola Mobility MoroKRZR K1m Cellular...
Nokia N96 Smartphone Logo
124 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
