Question about Philips Televison & Video
Tuning problems with philips 26pf5520d on the normal analogue settings it will only pick up chanel 5 which is quite good also on digital it will find all the digital chanels however I can not get any of the other terestrial chanels and sometimes it comes up with a message poor signal quality I have tried another tv on the aerial and this works fine.Any help would be appreciated
ctf1800
  • 4402 Answers
SOURCE: Getting a yellow to blue double image
Convergance ic are bad.
there are some resisters that should be checked
heres some diy sites.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hometheatershack.com/forums/manufacturers-service-support/5600-crt-based-rptv-convergence-repairs.html#post43725
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Posted on Dec 14, 2007
SOURCE: tuning TV onto AV chanel
unplugged every cable and then reconnected them - Bob's your Uncle - it worked!!!!
Posted on Apr 02, 2008
How do I get the TV screen back to an AV chanel?
I cant get a slide show to view on the TV screen.
Posted on May 19, 2008
Benimur
  • 6966 Answers
SOURCE: NO Signal on TV but Foxtel works
I am assuming that you have confirmed that your Foxtel works in another TV but not with the Toshiba 37WLT66A and that you are using a single feed from the cable provider and split into two (or more). Additionally, this is a standard cable connection.
If the unit is new, then perhaps it is a matter of programming the Channels using Cable not Std or Air in the menu. If the Toshiba has been used before in the same setup, then possibilities are:
1. cable/connector leading to the Toshiba;
2. splitter or distribution amplifier (if present);
3. worst case scenario, tuner block of the Toshiba.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 10, 2008
SOURCE: I`ve set up my philips
I actually moved my tele to the other side of the room to see if it would work in a different spot and it took me ages to get some signal by moving my aerial around. The signal still wasn`t strong and i didn`t have alot of the channels and then i turned it on a few weeks after and it was working perfectly. Don`t ask me why! :s
Posted on Aug 10, 2008
Cant seem to tune in after digital switch over not got any chanels
If your TV is an older variety that wasnt set up for digital signal you will need a set top converter box.
Jun 22, 2011 | Toshiba Televison & Video
Cannot pick up all freeview chanels. no chanels above 68?
68 is the highest analogue channel there is in the UK. Digital freeview is around the mid frequencies usually, 28 to 40 ish.
Mar 31, 2011 | Televison & Video
I need a user manual for a Techwood LVD2263D flatscreen tv. I cannot install & re-tune to view TV channels
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service and Installation Instructions as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 23, 2010 | Televison & Video
I have a Sony Bravia KDL-40V3000 but I cannot get any sound on the analogue channels. digital channels are fine. Only cables plugged in are ariel and power Please advise any solutions thanks
(1)Reset your tv from setup menu then auto tune analogu chanel.
(2)if still no sound then update your tv softwear from sony site.
(3)If still sound not then need to replaced main board problem.
Oct 20, 2010 | Sony BRAVIA KDL-40V3000 Television
Panasonic tv no signal?on any channel
Akai model LCT2715 will not pick up any chanels
Mar 07, 2010 | Akai LCT2715 27 in. LCD Television
Trying to retune Sony Trinitron KD-28DL10U for digital channels. The auto set up is greyed out and I am only able to tune in the analogue chanels.
If I remember, press the blue text button to break in to the digital menu, come back to me if I'm wrong
Oct 01, 2009 | Televison & Video
Can't get digitall channels
I have the same problem, If anyone could help it would be appreciated.... I have the coaxial cable plugged in which on another TV had all 85 channels, and I changed the TV from analog to digital and reprogrammed it but I still only get like 4 or 5 local channels?
Jul 09, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
May 17, 2009 | Philips 37PFL5332D 37 in. LCD Television
Problem with chanels on Magnavox LCD 20in TV/Monitor
check the tuner or the IF circuit they could be defected.good luck.
Apr 19, 2007 | Philips 20MF605T Television
Televison & Video Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
