Question about KitchenAid KESC307 Electric Kitchen Range
Oven Door off kilter
I have a kitchen aid gas range/stove. The oven door has become partially dislodged as the right hinge has come about half way out of the slot. The door opens and closes but is out of alignment. I can't get the door back in place. What do I do.
  • dcummings1 Jan 20, 2009
    My KitchenAid oven door came off the pegs or whatever holds the hinge in the slot. Now I have taken the door completely off trying to get it back in. How do I get the hinge back into the slots and hooked on the pegs?
  • is that the door that you can take of by lifting the door so that it will come off?
  • 833 Answers
SOURCE: kitchen aid stove problem
Peter,
First...be sure you cut power to the stove before you do anything. This is 220 volts and it can kill you. 220 Volts is based on two different lines of power coming to the stove, each of which is 110 volts...but opposite each other in phase. This may mean that some power to the stove is on and some is not. Let's go on.
I suspect a few things: First, the coil control for the burner is probably finished. What I also suspect is that it opened one of the two breakers (they are usually tied together in the panel and are either 40/50/60 amp units) causing some lights but no action.
What to do: Reset the breakers as a pair by turning them off and on. If one snaps off, you have a problem at the stove. If not,...which I doubt...you're in business.
Let's look at replacing the control. Shut the breakers. Now, take the burned control and remove it. Note the wiring positions if they are not on a plug. If they are terminals, tape the ends. Now, reset those breakers. If the other burners work, replace the control. Take the old one to the parts store. If it doesn't work, look around the burned area for broken wires. Repair and tape them up. Try again. Oh, and don't let anyone touch the stove while you're working with those breakers.
Posted on Dec 03, 2007
  • 338 Answers
SOURCE: Kitchen Aid oven does not get up to temp.
you can only calibrate the oven + or - 35 degrees. if you are over 35 degrees off you will need to ohm your temperature probe to see if you get about 1280 ohms if you do then you need to replace the clock control. if you ohm the temperature probe and you are off by more than 10% then you will need to replace the probe. in most cases both the control and probe would need to be replaced.
Posted on Feb 02, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: kitchen aid stove oven shutting off reading error
Electronic range clock failure. You will need to replace this part. It is located where your keypad is. You will need to get behind it and pull the part out and replace it with the exact kind from repairclinic.com
Posted on Feb 21, 2009
mark_37388
  • 100 Answers
SOURCE: I have a kitchen aid flat stove top. The glass on
I don't know who can change one there but I know the tops for those unit run between 350.00 and 500.00 just for the top have you tried cleaning with a razer blade like creaning the paint off glass it works great
Posted on Mar 30, 2009
  • 25 Answers
SOURCE: Cannot shut off the kitchen aid stove with the "Off" button, model # KESA907PSS01
i had the same problem with mine.. i overboiled some water and it leaked down the front onto my panel (inside).. i had to replace the whole thing.. (i did it so i added a silicone bead inside so water cannot get to that same panel area)..
3 years and it still works..
replacement panel is about 120.00 CAD
Posted on Jul 22, 2009
Kitchen aid Supera oven door help
I can't speak for this model but all stove doors are relatively the same:
1) Open the door all the way
2) On the right and left door hinge there is a little latch that will most likely pull up towards you to lock the hinge open
3) Make sure this latch is all the way in the lock position
4) Lift the door as if you were closing it, except this time the hinge will not move and the door will start to lift off
5) Keep "closing" the door and gently pull away from the range to remove the door. Sometimes it gets a little stuck but just be patient with it and jiggle it gently.
Reverse this process to put the door back on.
Apr 05, 2013 | Kitchen Ranges
How to remove a Maytag gas stove oven door (Maytag Model # MGR5755Qwd)
Hi.
Before removing the door you need to release the lock on the oven door hinges. Door hinge locks are slide mechanisms or pins located on top of the hinges Once lock is released you will be able to pull out the door by opening it a bit, then lifting it up and pulling out.
Here parts and diagrams for your oven: MGR5755QDW.
Regards.
Ginko
Sep 09, 2011 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Remove oven door on kitchen aid gas stove for cleaning
Usually the doors just lift off.
Keep your fingers away from the hinge region as they can release and whack your fingers
Jan 03, 2011 | Ovens
I have a Dacor ERD36, How do I remove and replace the oven door hinges?
most ovens , you open the door half way, then pull straight up the door will come right off, then you have full view of hinges and bolts
Oct 19, 2010 | Dacor Epicure ERD36 Dual Fuel (Electric...
Dislodged oven door, can't re-attach.
All oven door hinges have small grove or tooth that must be engaged to opperate correctly.
Reinsert hinges one at a time, noting there is a small "tooth" or "gap" on each hinge.
This gap must engage with the lower part of opening in which you place door hinges. When you engage one tooth, do same on opposite hinge. Door now works correctly.
Apr 17, 2009 | Kitchen Ranges
Oven door
replaced oven igniter without removing oven door
Jan 08, 2009 | Tappan TGF657 Gas Kitchen Range
Oven Door Hinge Squeaks
its not the hinge,,its the sping in the hinge,,you have to replace it,,,be careful with ludes on stove...onthejob
Dec 20, 2008 | Magic Chef 31000 Gas Kitchen Range
Stove handle/door
need strong fingers and a helper... lay the door on the floor push open the hinges and there is a hole on the side of the hinge have your helper slide in a small nail only about 1/4 " in to the hole this will keep the hinge out do the same on the other side then reinstall the door open up and remove your nails
Feb 26, 2008 | Whirlpool RF315 Dual Fuel (Electric and...
RE: f5 fault code; kdrp407hss
Solution!!! The hinges that Kitchen Aid uses are the problem. If the door is opened quickly & bottoms out, the steel in the hinge bends a little. So when you go to close the door it won't close all the way.... which causes problems with the latch , latch switch, oven cleaning, etc.
After taking apart the door several times I realized the hinge can be "fixed" without even removing the door. Follow the directions in the user manual for door removal... after inserting the little metal hinge stops (a drill bit or nail will work) Close the oven door till the stops won't allow it to close any further.....then gently but firmly, push forward. This will bend the hinge back to original shape. Remove the pins...Voila!!!
I wish kitchenaid used hardened steel or a thicker hinge....then this wouldn't happen.
Nov 11, 2007 | KitchenAid KDRP407HSS Dual Fuel (Electric...
KitchenAid KESC307 Electric Kitchen Range Logo
47 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
