Question about Relisys RLT1720 17" LCD Monitor
What is max resolution for this monitor
Ive just plugged n played it has always performed as a monitor and with a tv card but I am selling it and would like help with this query
  • 685 Answers
1280x768 pixels
Posted on Nov 10, 2008
Not able to set the required resolution (1920 x 1080) for my new LG E2240S monitor. Computer is Advent T9002 on Windows XP
Advent T9002 is using a Sis Ultra256 video card that can't offer you such a big resolution. Your monitor is ok.
You can try to install a more performant graphics card.
May 03, 2011 | Computers & Internet
1920x1080 resolution-entire screen not viewable
This also happens to my vga connection to my TV.
I used my tv remote "auto" button to re-size it to fit correctly.
If your monitor/TV does not have the adjustment, you may need to
supply your vga compatible device with your monitor's driver software.
This tells your computer what monitor specifications you have.
Mar 16, 2010 | ViewSonic X Series VX2260wm 21.5"...
16:9 resolution problem
You don't specify your machine type, or the operating system, but let's assume a desktop computer and Windows XP...
Was the monitor recognized properly by the video driver?
Go to Display Properties, settings, advanced, monitor and see if Plug and Play monitor is installed. All modern graphics cards talk to the monitor to discover it's capabilities and should adjust the available resolutions so that the monitor's native resolution is available for choosing.
If some other monitor is listed there, change it to Plug and Play monitor. If still having troubles, you can do two things:
- update the video driver for your graphics card
- find the monitor's .inf file (it should be on a CD that comes with the monitor, or can be downloaded from DELL site), and install this instead of the Plug and Play monitor or whatever you have in your monitor setup (as above, go to monitor - properties - update driver).
Nov 08, 2009 | Dell Computers & Internet
Monitor say Input not supported. What does this
Your graphics card is set to a resolution of refresh rate that your monitor cannot handle, This can sometimes be one of the normal settings - there is not much you can do. Each monitor has a native resolution which the monitor should always be set at yours is:- 1280X1024
Nov 03, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
Samsung 27'' lcd tv for Pc Monitor resolution max is only 1024x768
Use a DVI (female) to HDMI (male) cable to connect your PC video card to the LCD TV. You will then be able to use the full resolution of the LCD TV. You will always be limited to the max resolution of the TV though, not matter your video card.
Jul 14, 2009 | Samsung Televison & Video
GRAPHIC CARD PROBLEM
Hi, I noticed you posted this same problem again. Here's the answer from the first post which should answer your question.
The maximum performance of your video card is limited by the hardware you attach it to. In the display properties of Windows, your highest resolution is 1280x1024 because your monitor is not able to go any higher than this. This resolution is a typical maximum for a 17" monitor. Some 15" can do this, and some 19" can do this. In order to get a higher resolution, you'll need to get a bigger monitor with a higher native resolution. For example, a nice 24" monitor can only do 1920x1200. The video card can go higher, but it's limited by the monitor. 32bit color is your highest setting - that's 16 million colors. Your video card's 1GB of RAM only determines how much rendered data (usually 3D) it can store and move at any given moment, which is related to but not determined by your screen resolution. That's a very nice card - you should be able to get very good frame rates, color, and performance out of 32bit color and 1280x1024. If you want a higher resolution, you'll need to get a bigger monitor.
May 13, 2009 | Computers & Internet
Nvidia geforce 9400gt 1gb card problem
Cannot set resolution 1640x1050
To answer your question in short: If your video card and monitor drivers are installed correctly and you are able to adjust the resolution to 1640x1050 in your settings then your card and monitor are able to handle that resolution.
Remember that at higher resolutions your display card performance might become very slow.]
This is due to your BIOS shared memory being only 64Mb.
To get better performance you will have to upgrade your display card to one with more memory. ie. 256Mb. or more.
Best of luck.
Regards,
Graemevm
Apr 22, 2009 | Biostar P4M80-M7 Motherboard
Video cards
The 260 gtx is a nice card but ATI just came out with their new cards and the Radeon HD 4850 is faster for about $100 less than the 260GTX.
But WOW uses an older graphics engine and low poly count models with that cartoony look. WOW will run great on some fairly old hardware so if he is using that computer for WOW only and is running SLI then there is no reason to upgrade. He probably has the resolution maxed out and the detail settings maxed out. If he is playing on a 32" 720p widescreen TV then the resolution should be set to a maximum of 1280X768. The rest of the settings should be adjusted to maximize the experience to your liking.
Some LCD TVs to add lag because of the image processing that is hapenning behind the scenes, some TVs have a gaming mode that minimizes this lag. Also your internet connection could be the culprit causing your lag.
In the end you do not need an new video card to play WOW. If he wanted to play Crysis with high detail then that would be a different story.
Jul 08, 2008 | Computers & Internet
Monitor resolution
when you increase considerable resolution windows will ask you do you want to keep these settings? you select yes then that will be saved
Feb 15, 2008 | ViewSonic VX2235WM Monitor
Relisys RLT1720 17" LCD Monitor Logo
29 people viewed this question
Top Relisys Computers & Internet Experts
Samuel Konger
Samuel Konger
giarcnameloc
Level 1 Expert
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
