Question about HP Photosmart 2710 All-In-One InkJet Printer
I have a HP Photosmart 2710 All in One with jammed paper.
I cannot completely remove all the jammed paper. Large pieces are stuck underneath the four "plates" inside, just under the metal rod that goes across. Is there anyway to make this area more accessible??? Thanks so much for any help!
    Scholar:
  • 121 Answers
The only option is to open up your printer to get access .....try using tweezers to pick on it and slowly removing....
Posted on Nov 10, 2008
Keeps saying carriage jam but don't see a jam. was on earlier carlesann@yahoo.com
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
Aug 25, 2010 | HP Photosmart 3210 Printer
Tip
Paper Jam Error on HP Printer
Paper Jam is the most common issue in all the HP Printers ( Officjet, Photosmart, Deskjet Printers )
What Causes a Paper Jam ?
  • Paper thickness.
  • Room temperature OR due to Dust in atmosphere or the room.
  • Paper pulled out in a hurry and paper pieces stuck in Rollers or Carriage
  • Could be Hardware Failure
NEVER PULL THE PAPER STUCK IN THE PRINTER FROM FRONT SIDE OF THE PRINTER ( unless the paper is 3/4th visible in front view if you open the printer front panel door )
Follow the instructions below to resolve Paper Jam issue.
  1. Turn off the printer.
  2. Open the rear access door ( or duplexer )
  3. Check for any bits of paper stuck, if so, remove them.
  4. Open the front access door where you see the cartridges.
  5. Check for any paper pieces, if so, remove them.
  6. Take a lint free cloth. Little bit Damp ( use water )
  7. Clean the Rear rollers pushing it upwards and close the door.
  8. Close the front access door.
  9. Connect the power cord and power on the printer.
  10. It should be ready to print/copy/scan/fax.
To clean the duplexer ( 2 - sided printing device ) remove the duplexer and clean the rollers you find inside.
If the above steps do not solve your problem, you printer needs repair. Contact HP. ( 1-800-474-6836 )
If the printer is In-Warranty please contact HP for replacement. HP may charge for repair for Out of Warranty printer.
Find the Video below for paper jam cleaning
Regards,
Ron
Your rating will help us improve the service we provide
on May 20, 2011 | Office Equipment & Supplies
How do i fix a carriage jam
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
May 12, 2010 | HP Photosmart C4150 All-In-One InkJet...
My hp photosmart 8250 keep showing paper jam but there's no paper jam anywhere. How can I get it to function properly?
Make sure there is no paper stuck inside in the paper. may be there is small piece of paper stuck inside
Just unplug the power and open the cover and remove the toner or cartridges from the printer and manually try to roll the roller and remove the paper.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 17, 2010 | HP Hewlett Packard Photosmart 8250 InkJet...
An error message keeps coming up to clear a carriage jam. There is no paper jammed. I have checked the front and opened the back door, unplugged and replugged, and pressed OK. Same message keeps coming up
Hello there This is only a try it may or may not work.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 12, 2010 | HP Photosmart 2710 All-In-One InkJet...
How do I remove a torn piece of paper that got stuck in my HP All-in-One 6180 printer?
Dear,
Open it from Back side. There you will see a removable plate. From there u can able to remove the piece of paper.
Cheers
Jaggu
Oct 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
Won't turn on
When removing jammed paper from a printer you need to be very careful as printers have a paper sensor which is very sensitive and it can be damaged if you pull the paper to hard. I first need to know, the printer doe not turn on or it does not print ? What brand of computer is it ?
Aug 25, 2009 | HP Photosmart 2710 All-In-One InkJet...
Paper jam
,lTake a paper clip and carefully remove it from the sensor where it jammed then power off wait for 30 mins and power on. This will shore up this issue.
May 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
I want to purchase a power supply for a HP 2710 four in one printer
visit the below weblink
https://wimpro.cce.hp.com/ChatEntry/Chat.aspx?productOID=420428&productLine=5M&productSNI=hppsc2710a391140&productName=HP+Photosmart+2710+All-in-One+Printer&productCategory=421635&SCOID=238445&h_cc=us&h_lang=en&lc=en&PSOID=391138&lang=en&cc=us
Dec 31, 2008 | HP Photosmart 2710 All-In-One InkJet...
HP Photosmart 2710 (Wireless)
Introduction
The flashing error code that indicates a jammed printer is the digital-age equivalent of a
flat tire. Sooner or later it happens to everyone, so you'd better know how to get things
moving again if you want to finish your print job.
Instructions
Difficulty: Moderate Steps
1 Step One Turn the printer off and on to see if it can automatically clear some or all of
the jam. Many printers provide an error-code listing on the front panel display for the area
where the jam occurred. If your printer shows an error code, be sure and check the printer
manual to see if that identifies the area of the printer where the jam occurred.
2Step Two Turn off the printer.
3Step Three Remove any paper trays. Inspect them for wrinkled or damaged paper.
4Step Four Open any other doors that give access to the printer's paper path and to the
toner or ink cartridge.
5Step Five If necessary, remove the toner or ink cartridge. Place it in a bag or away from
light to avoid damaging it.
6Step Six Click to enlargeIf you find a piece of jammed paper, remove it by holding it with
both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If
several pieces are jammed together, try pulling out the middle piece first to loosen the
jam. SEE PICS http://www.imagehost.ro/pict/0104361047293b9a4006c.jpg
7Step Seven Click to enlargeIf the paper does tear, try rotating the roller gears manually
to free the paper (see B). Don't force anything, though.SEE PICS
http://www.imagehost.ro/pict/0104365847293bcaa9870.jpg
8Step Eight Replace the toner or ink cartridge and paper trays, close any doors you opened
and turn the printer back on.
9Step Nine If the printer paper jam message still appears, then there is still some paper in
the printer.
 Reinspect the paper path.
Oct 31, 2007 | HP Photosmart 2710 All-In-One InkJet...
HP Photosmart 2710 All-In-One InkJet Printer Logo
65 people viewed this question
Ben Johnson
