Question about Tally T2250 Matrix Printer
Tally 2155 feed tractors
I'm looking for information on how to replace the feed tractors on a Tally 2155. The right front tractor is broken. Is there a service manual anywhere for it?
3 Suggested Answers
SOURCE: How do you print a
Press online while powering up printer.
Posted on Nov 11, 2010
  • 169 Answers
SOURCE: how to run tractor1 and tractor 2 Tally T2250 ?
The first thing you would need to do would be to ensure you have two sets of tractors. The second set of tractors is an option not on the standard printer.
You can fit the second set of tractors to the front or rear of the printer
You can select either of the two tractors in the following ways;
  1. Via the control pannel menu
  2. If printing from Windows by selecting the appropriate paper path when printing
  3. If you are able to insert control codes into your data stream you can use escape commands to change the paper path
Posted on Dec 12, 2011
How to replace belt model 2155 cub cadet engine pulley to deck?
Download the owners manual from Cub Cadet using model number 13A-244G100.
Customer Service Cub Cadet
Sep 16, 2014 | Cub Cadet Garden
Tally 2250 gives eject error single
The paper path on the 2250 has changed to the single sheet feeder, I guess you are using tractor fed paper loaded into the standard front tractors, if this is the case you can change the paper path to Tractor 1 in the following way;
1.Power the printer off and disconnect the printer from the computer system.
2.Press and hold down the SETUP button, and power the printer on. Keep the SETUP button held down whilst the printer initialises (this unlocks the printer menu)
3.When the printer has finished initialising release the SETUP button.
4.Make sure that the printer is in Offline mode; press the Online key, if necessary.
5.Remove any paper that may be loaded into the printer.
6.Press the SETUP button
7.Press the button under PAPERPATH (button 3)
8.Press the button under TRACTOR 1 to select the tractor feed
9.Press the ONLUE button to exit the menu.
Dec 13, 2011 | Tally T2250 Matrix Printer
How to run tractor1 and tractor 2 Tally T2250 ?
Nov 30, 2011 | Tally T2245 Matrix Printer
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
1989 JD 2155 2WD tractor, cannot start engine, have replaced starter switch, nothing happens, battery good. What should I check next?
Have you tried crossing the large post of the starter with the small terminal that has the engagement wire going to it[with the machine in neutral and the range lever in neutral if course].If this will make the tractor turn over then the problem is likely the neutral safety switch located under the panel that is covering the transmission just rear of the sticks.
Jan 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Printer screen message reads turn paper lever then online single Can't get it to print
I guess you are using tractor fed paper, the type of paper with holes down the side.
The problem you have is that the paper path has been changed on the printer to the single sheet feeder rather than the tractor feed, you will need to change this back again via the control panel, this is done something like this;
  1. Put the printer Offline
  2. Press Setup
  3. Press the button under PaperWay
  4. Change this to Tractor 1
  5. Press SET
If the above steps do not work disconnect the printer from the computer then try again.
For more info see the Dascom web site;
http://www.dascomeurope.com/support2/technical_notes/serial_matrix/T2240/T2240_tn007.htm
And look for the Online Single & Load section
Oct 14, 2009 | Tally Serial Matrix T2130 Printer
Printer is bleeping for delivery note to be inserted, however, screen says turn paper lever?
  2. Press Setup
  5. Press SET
Oct 14, 2009 | Tally Serial Matrix T2030 Printer
I have a Tally T2245 with load error. ASF-R
Sounds like the paper path has been changed I guess you are using the front Tractor (tractor 1) to load continuose paper.
You need to go into the menu and change the paper path back to Tractor 1.
Disconnect the pritner from the computer system, and power the printer off and back on again to clear the buffer.
  • Take the printer off-line by pressing the Online key
  • Press the Setup key
  • Press the key under "Paperway" in the display
  • Select Tractor 1 (or Tractor 2 if fitted/required)
  • Press the key under "Set"
  • This should change the paper way back to Tractor 1
    Jun 23, 2009 | Tally T2245 Matrix Printer
    Papaer out error
    Paper detection switch on tractor feed unit is probably faulty. Replace the tractor feeds.
    Jul 15, 2008 | Epson DFX-9000 Matrix Printer
    Tally T2250 Matrix Printer does not pull up paper to be printed
    I would guess you are getting error messages on the diplay to tell you what the bleeping noise is about....Please read this message.....
    I would guess the message is something like LOAD SINGLE, and you are using tractor feed paper. If this is the case the paper path on the pritner has changed and needs to be changed to Tractor 1 again.
    To do this;
    • Stop any prin jobs gong to the pritner
    • If the printer has data in its buffer, power the printer off and back on again to clear this data
    • Ensure the printer is OFFLINE
    • Press the SETUP button
    • Press the button under ADJUST
    • Press the button under PAPER WAY
    • Use button 2 or 3 to change this to TRACTOR 1
    • Press SET
    • Place the pritner ONLINE
    You should be back in action, if not post the message you see on the printers LCD display.
    Dec 18, 2007 | Tally T2250 Matrix Printer
    Tally T2250 Matrix Printer Logo
    75 people viewed this question
    Top Tally Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
