Question about Sharp Notevision XG-P10XU Multimedia Projector
Missing remote control and projector keylock is on
Is there some way to override the keylock feature so I can get the power to work with the projector's power button?
  • hippiegroove Nov 29, 2008
    the keylock is on , so i can not get anything to come up , and i dont have the wired remote. Does anyone have a solution ? hippiegroove@hotmail.com if u do
  • Anonymous Mar 30, 2014
    Using publisher (microsoft) program and sharp projector and can't make remote work to advance pages
  • 10,594 Answers
I think you need remote for above said process.
Get original Sharp remote for XG-P10XU from Sharp Accessories.
Posted on Nov 10, 2008
I have 1.5" LEDTV3228T that keylock on. I have no remote I use only the key button however the button are not functioned because of keylock off. How to keylock off unlock the TV without a remote?
Without a remote control, you can't. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Nov 17, 2016 | Televison & Video
How to unlock the keylock pensonic led TV model led-1624 manually with out remote?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
May 08, 2015 | Televison & Video
Lh d6240. Not receiving signal from the remote control, the technician checked the remote and said has no problem
test this steps and fix it. God bless you
The batteries are dead.
Replace the batteries.
There is something blocking the receptor on the main unit.
Remove any obstructions and clean the area in front of the receptor.
The remote is too far from the receiver or at too extreme of an angle.
Move closer to the receiver (within 23 feet) or change the angle (within 30 degrees) to the receiver.
A fluorescent or other bright light is shining on the receptor on the main unit.
Turn off the light or shield the receptor.
The device has a keylock or lockout feature turned on.
Check the display for a key or lock symbol, then follow the instructions in the device's user manual to turn off the keylock or lockout feature.
Either the remote or the receptor on the device is not functioning.
Use an Intraed Sensor to see if the remote is sending a signal.
If the remote is sending a signal, it used to control that device, and no other solution works, you should have a service center look at the device and remote to determine the problem and if it can be fixed.
If the remote is not sending a signal and you have replaced the batteries, you will need to repair or replace the remote, depending on cost.
Nov 01, 2013 | Televison & Video
My remote is locked how ti open?
follow this steps and fix it. God bless you
My RM-36E remote is locked. how to unlocked?
Nov 01, 2013 | Universal Remote Control Remote Control
REMOTE CONTROLE DID NOT WORK
Use an Infrared Sensor Card (Cat. No. 276-1099) to see if the remote is sending a signal.
Jul 22, 2013 | Televison & Video
Control panel key locked and remote lost
Hello
To relsese the key lock, set keylock of OFF, using remote control.
Pressing the [RETURN] button on the porjector for 10 seconds will release the 'key lock'. OK.
Nov 15, 2011 | Toshiba TDP EX20 Projector
Miss operation to launch "Control
When the control panel lock ON of the projector so that the projector can be operated only with the REMOTE CONTROL.
If you loos your remote control then keeping the POWER key on the projector control panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you press and hold the MENU key for about10 second when the power is on the lock will be released and "panel key lock" is automatically set to "OFF"
Feb 23, 2011 | Sony VPL-CX70 Multimedia Projector
How do I unlock the buttons on the projector
Hold down Enter button for 5 seconds it will unlock
Aug 09, 2010 | Sharp Notevision PG-B10S Multimedia...
Unlock Sharp XR-10X-L Notevision Proj. says keylock function on
According to pg. 45 in the owner's manual, you turn Keylock function ON by holding down the ENTER key on the projector for about 5 seconds while the projector is being turned on.
To take the Keylock off-- Hold down the ENTER key on the projector for about 5 seconds. If the projector is in standby mode, you can release the keylock by holding down ENTER and STANDBY/ON keys simultaneously for about 5 seconds.
Apr 27, 2010 | Sharp XR-11XC DLP Projector
Sharp Notevision XG-P10XU Multimedia Projector Logo
447 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
