Question about Kenmore 22622 Top Load Washer
Stoppeed Working during agitation
Doesn't do anything and is full of clothes and water.
    Genius:
  • 1,122 Answers
Have you checked the lid switch?
Posted on Nov 11, 2008
Why is there no water in tub during wash cycle?
Check water feed pipes, taps/fawcets possibly the pump not working.
Jul 21, 2014 | Kenmore Washing Machines
One piece agitator wraps cloths
When loading the machine, load towels, sheets or jeans with an accordion fold instead of putting the laundry in a circle around the agitator. It helps to put the clothes in at the twelve o'clock position, then six o'clock, then nine o'clock and then three o'clock. Repeat this sequence until the washer is full.
The laundry can circulate much better and get cleaner too.
Feb 08, 2014 | Washing Machines
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Hi, The water comes into the load, but then their
the agitator shaft could be stripped out. does it sound like the motor is working during the wash cycle or is it just idle? This is a common problem with ge washers the agitator strips out on the transmision and needs to be replaced.
Jan 02, 2010 | GE WJSR2070B Top Load Washer
Washing machine will not agitate but it spins.
The brakes are shot,so the tub spins in agitate will also cause it to leak part number R0000014 run about $25.
Look straight up from the bottom pulley you will see the brake assy looks kinda like a clutch plate,look around the outer edge of that you'll see the Pads they have two 3/8 inch bolts in each one,to get the new ones in you'll have to use a screw driver to open the plate.
Sep 23, 2009 | Amana ALW480DA Top Load Washer
Agitator doesn't turn during wash / rinse cycle
top the top off the agitator,remove cap inside,you have 4 plastic dog ears you need to replace,your local appliance store has them for $2,let me know how you do-mike
Mar 24, 2009 | Kenmore Washing Machines
Inglis Washing Machine agitator not working right
It appears your motor controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 17, 2009 | Washing Machines
Kenmore:Noise; agitator not working; drum full of water...HELP!
Sounds like you have a broken motor coupler, check the tutorial at www.shop.washermd.com dave
Jan 12, 2009 | Kenmore 15944 Top Load Washer
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Tub shakes back and forth during agitation
it could be the inner tub thats loose , check for a broken screw at the center mast that holds the inner tub. hope this helps.
Apr 28, 2008 | Hotpoint VBXR1070W
Kenmore 22622 Top Load Washer Logo
29 people viewed this question
Sal De
fordexpert
Robert Rankin
