To change the settings of keypad auto lock of your Nokia E71 and to make it automatic. Follow the given steps: Go to Menu >> Tools >> Settings >> General Settings >> Security Settings>> Device and SIM card security >> Phone and SIM card >> Keypad auto lock period Here you can set your keypad to lock automatically after a defined period.
I hope this solution helps you Feel free to let me know if you have any questions Thank you for using FixYa
DESCRIPTION OF SPECIAL FUNCTIONS Toner save mode Reduces toner consumption by approximately 10%. Power save modes The unit has two power save modes of operation: preheat mode and auto power shut-off mode. Preheat mode When the unit enters the preheat mode, the power save indicator will light up and other indicators will remain on or off as before. In this condition, the fuser in the unit is maintained at a lower heat level, thereby saving power. To copy from the preheat mode, make desired copier selections and press the start key using the normal copying procedure. Auto power shut-off mode When the unit enters the auto power shut-off mode, the power save ( ) indicator will light up and other indicators except the ONLINE indicator will go out. The auto power shut-off mode saves more power than the preheat mode but requires a longer time before starting copying. To copy from the auto power shut-off mode, press the start key. Then make desired copier selections and press the star key using the normal copying procedure. Auto clear The unit returns to the initial settings a preset amount of time after the end of copy, or scanner job. This preset amount of time (auto clear time) can be changed. Stream feeding mode For description of the stream feeding mode, see "Stream feeding mode". Resolution of AUTO & MANUAL mode You can set the copy resolution used for AUTO and MANUAL ( ) exposure mode.
Hello
You can try to do a hard reset to restore it back to factory settings. All your contacts, messages, calls, applications, themes > everything will be gone. So BEWARE. Backup your important stuff first. Your memory card will be fine, so anything there will be saved. However, if you have applications installed on the memory card, I recommend deleted those as well.
I always tell people to install applications and themes on the phone memory always! Your phone will run faster, as will the applications. Leave the memory card for your media.
Anyways, to perform a hard reset on the Nokia E71 you do this...
Type *#7370# from the standby screen while your phone is on.
It will ask for the lock code which is 12345 unless you have previously changed it. Make sure you do this right, because if you do it too many times the wrong way you can lock up your phone.
And that's it. Have fun re-installing all of your applications and themes.
Hopefully this helps you out if your having problems, or if you just want to clean out your phone.
Hope this helps.
Hi, I've scoured the 3 page manual and come up with this.:- There is nothing wrong with your camera. The camera has a built-in power saving feature that turns the camera off after 30 seconds of inactivity (default setting) to conserve battery power. The auto off time setting can be changed in the set up menu. Changing the Auto Off Time Setting: 1. Set the camera to Camera Mode. 2. Press the Menu button to display the main menu. 3. Press until the Setup is highlighted. 4. Press to enter the Setup submenu. 5. In the Setup menu, press to highlight “Auto Off Time”. 6. Press to enter “Auto Off Time”. Press to highlight the time you want. 7. Press the OK button to save your selection. Hope this helps
You have to save all your data first , then you have to format the handset by switch off and then pressing * and 3 and green button and the power button all at the same time un till it asks about country setting and time etc
First, do a power cycle. By turning your phone off for 10-20 seconds. Turn back on, follow these steps: . Put the auto key lock as fast as possible, so that the phone would turn off it's screen faster.
# Phone Settings > Security > Auto Key Lock > Change your time from this menu. It maybe saying 10 seconds now.
The reason this was set this way, was to conserve battery life. You can view: http://rukikenishiro.com/2008/04/how-to-save-battery-life-on-lg-ku990.html to TIPS & TRICKS on conserving battery life, w/o having to jeopardize your screen.
press the keey on the left side of shift key. it will change the entry into num mode. press 112 and press dial button (green phone button). It will show connecting press end call button. Now the set should be in normal mode.
