Question about Labtec Spin 70 Computer Speakers
S-0082a speaker noisey when plug in - Labtec Spin 70 Computer Speakers
Changed oil now lifters are noisey changed oil again still noisey
Are you sure it is not "plug knock" from bad gasoline? You may need to add a can of octane to the gas if that is the problem. If you are convinced it is the lifters then first check to make sire you are using the right oil. Different oils for different cars. If you are using the correct oil - try a product called "Rislone". You'll have to drain a quart of oil before you add the quart of Rislone so you do not overfill your engine. They drive your car for 30-60 minutes and see if the noise goes away. I like to drain the oil immediately after I return home after the drive - and you'll probably find the oil to be black.
Oct 06, 2014 | 2003 Pontiac Sunfire
Noisey initial installation
I would suggest this is just the HDD chugging over and the fans going while the processor works its brains off nothing to worry about. Dell are known for noisy HDD
Jan 01, 2013 | Dell Piano Black Studio XPS 8100 Desktop...
It as a noisey hum and we can't figure out how to take it apart. Picture is fine. Thanks for any ideas. Tom
Have you got this plugged into a surge protector? Try plugging it into a socket without the the surger protector, see if that cures it. Check also that you do not have too many devices plugged into the protector.
See also if there are any other devices near the monitor (speakers, TV, anything with a magnet in them), try moving the monitor away from them, see if that helps.
After that, the signs are that it may be a capacitor overloading, you need to get this checked professionally, do not try to do this yourself, as the capacitors retain their charge for a looong time and can give you a shock if you touch them ( as I found out...)
Feb 12, 2011 | Medion MD 7317 17" Flat Panel LCD Monitor
Noisey cooling fan on graphics card.
Pretty much you are looking at replacing the entire card. Fans can be found but it is difficult and it is not worth the time generally to find them. http://www.newegg.com/Product/Product.aspx?Item=N82E16814127368
Oct 15, 2009 | Dell Inspiron 530 PC Desktop
Noisey tappets on citroen c5, just fitted new silencer.
WELL NOISEY LIFTERS CAUSED BY DIRT TRAPPED INSIDE THE LIFTERS OR NOT DOING OIL CHANGE OIL IS DIRTY.LOW OIL PRESSURE CAUSES LIFTER NOISES.WORN LIFTERS ALSO CAN CAUSE NOISEY LIFTERS.
Sep 18, 2009 | Peugeot 405 Cars & Trucks
Oil for yardman lawn mower
Only 30wt DETERGENT HIGH QUALITY oil, never use NON detergent or 10-40. Takes approx. 20 ounces to fill
May 27, 2009 | Mtd LAWN MOWER PART # 782-0082A-0638 DECK...
Noisey gearbox
Check the oil level in the gearbox. After that the process will be looking for a probable bad bearing or gear.
May 19, 2009 | Garden
Quiet Noisey feedback out of speakers
The speakers are not hooked up correctly. I don't know if you still have the instructions but it is a hardware problem and not software. Try to figure out how to hook them up correctly.
Dec 27, 2008 | Dell Inspiron 1521 Laptop
High pitched buzzing...
noisey yoke? Listen thru an empty paper towel roll cylinder to isolate---
Nov 17, 2006 | Sanyo DS27910 27" TV
Labtec Spin 70 Computer Speakers Logo
149 people viewed this question
Top Labtec Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
