Question about Nintendo NES Console
Help!!!- Power Light Blinks on original Nintendo
Hello. We have an original Nintendo (1985) and the power light blinks when we are trying to start up. We have just recovered our Nintendo system out of the garage yesterday and of course it was dusty. The Nintendo system has turned on once since we have tried to make it work and it lasted for about 25 minutes, then cut off and started blinking again. What can we do to make the system work again but this time for a LONGER period of time??
  • 37 Answers
I had an original that did the same thing and the problem is that
1. it's really dirty on the inside and needs to be clean or
2. the thing that "reads" the cartridge isn't tight enough
if it's problem one then:
The connecter on the inside needs to be cleaned so just use a brush to clean out the big chunks and an compressed air to clean out the little pieces. If the connecter looks rusted go to ebay and buy another one (get a gold or silver one because they work the best.)
if it's problem two then:
Open the system and GENTLY press the two sides together so when you put the game in it is "tighter" and it can read it better.
if you don't know which is the problem, try to do solution one before two. Good luck!
Posted on Nov 11, 2008
L246WH blinking light problem
Probably the power supply is failing but periodically recovers briefly.
Jan 05, 2014 | LG L246WH-BN Monitor
99 olds will not start
What have you checked so far ?
Jul 15, 2013 | Cars & Trucks
Low toner warning light always blinking
maybe the toner t1810c is not original...try this code turn off the machine then press 0 and 2 at the same time then a value of 3 digit will appper just press start button...dont turn off the power other wise this toner warning will show again...repeat this procedure the next time u off then on the machine...hope this can help...
Apr 05, 2013 | Office Equipment & Supplies
Does the original Nintendo NES-001 require a certain AC adapter. Cause I doesn't have the original ac adapter with same spec. My console power light is blinking on an doff. can that be the issuept
As long as it's 9 volt and about 500mA it should be ok. Just seen an original that says 9 volt and 400mA.
The current (mA) can be higher than the original but not the voltage that has to be 9.
1000mA = 1 Amp. So anything over 400mA is fine, but not less.
Feb 05, 2012 | Nintendo NES Console
I just want the Function key No. to do a System Recovery back to factory original
Hello, use the button next to the power-on button, or follow these steps"
1. Power off the system and press the recovery button (small round button next to the power button)
2. The system will start and the OKR (one key recovery) application will load
3. Select System Recovery from the menu and then select option to Restore to factory default
4. Click the "Start" button to recover your system partition
Hope this is helpful, thanks for using FixYa
Jul 31, 2011 | Lenovo G550 Notebook
Battery? console has no charge when plugged into wall outlet I push power button blue LED comes on briefly , then red flashes 3 times, and the yellow LED lights up along with the health warning on the...
What color is the power light when the system shuts off?
    Red: If the power light is red, or flashing red, when the system turns off, then the system's battery needs to be charged.
    Blue: If the power light is blue when the system turns off, then there appears to be a problem with the system and it will need to be repaired.
    If the orange recharge indicator light blinks while the system is plugged in and charging, then it is likely that the battery is not installed properly.
    If you have ensured that the battery is installed properly but the orange light still blinks, check to make sure that the battery is a licensed by Nintendo. The only licensed Nintendo DSi battery will have the model number "TWL-003" (Nintendo DSi) or "UTL-003" (Nintendo DSi XL) and will display Nintendo's logo.
    Call 1-800-255-3700 if you still need help.
Jan 27, 2011 | Nintendo DSi Matte Blue Console
Turn on power hear it come on then turns it self off and power light starts blinking
Blinking light may be a error code----look closely and see if blinks in a sequence---3 blinks, pause 3 blinks or 5,5.
The blinking light means set is in protective shutdown, Do you see a sequence to the blinks?
I am here to help.
If needed, unplug set and plug it back in and try to turn on---watch for likely error code.
SD TECH
Sep 17, 2010 | Panasonic PT-56HX41 56" Rear Projection...
Trying to reformat my ibm think pad from safe mode any thoughts on how to do this with out the disc?
Hello.
Often, IBM systems have a partition that restores your system to its original state (factory restore / recovery).
Power off your Thinkpad. Power on and press the F11 key repeatedly when the Thinkpad begins to start up
You should be able to access the partition and the instructions should take you through the process of recover.
Hope this helps.
Sep 05, 2010 | IBM ThinkPad T23 2647 Notebook
Power light comes on for about 30 secs, something clicks and both power and ocp lights start blinking contineously. the screen does not light up
I have this model of the sharp tv.Happen to me very often the Power and OPC LED light indicators blink continueosly.Not the power supply board,it the Tuner board that take in the comming broscast signal that have the problems.You still can used this tv.Push the power button sometime the tv it will work right away.Not,each time POWER and OPC lights continueosly blinks.Just push the power button again each time the POWER and the OPC continueosly blinks.Just have push power button again about 4 times each time Power and OPC blinks recycles,it will finally show the backlight and picture come on.My guest,if u do this by pushing power button to recycles about 10-12 times each time the POWER and OPC blinks it time to change the Tuner signal board.
Jun 03, 2010 | Sharp LC-C4655U 46 in. LCD TV
NES Console: When ever I try to turn my NES on, the POWER light...
72 pin game cart adaptor needs replacing. they can be purchased for around £10 and make it work like nes
May 16, 2010 | Nintendo NES Console
Nintendo NES Console Logo
3,463 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
