SkyScan 86742 Digital Atomic Wall Clock Logo
Posted on Nov 10, 2008
Outside temp on skycam atomic clock
After changing bateries in the outside temp. the temp still does not appear inside it has been about 30 to 45 min since i changed the batteries
  • 1 more comment
  • Anonymous Nov 22, 2008
    outside temp does not work? Battries have been changed
  • Anonymous Dec 02, 2008
    Same problem. Installed new batteries in the remote temp transmitter and now no outdoor temp display. Removed and re-installed batteries several times, waiting each time they were removed for an extended period of time. I've had this unit several years, and it always does this! There should be a "sync" button somewhere that forces syncronization!
  • longwave160m Dec 02, 2008
    syncronization! I have a scanner, and can hear the transmitter working,
    my receiver just will not pick up the signal (in spite of being placed
    right next to the clock!).
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Jan 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6177
Points
13
Try changing the battereis in the CLOCK. When the batteries in the clock start getting low, the clock does not pick up the outside transmitter.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2410
Points
  1. New batteries in transmitter.
  2. New batteries in clock.
  3. Wait for temperature reading from outside appears.
  4. Set time zone.
  5. Leave the clock alone, from 10 minutes to 24 hours. It will set itself.
1helpful
Outside temp on La Croose atomic clock says HH.h everything else works fine. Changed batteries in sender, it is sending signal.
Remove both the battery in the sender and the home unit. Insert the outside unit and then the inside unit. Make sure the inside one is new. If that one is at all low, it won't pick up the signal.
La Crosse Model W86111, Setting
an atomic clock ........ no user manual ?
1 Digital Atomic Wall Clock Model: W86111 ' Quick Setup Guide
pdfstream.manualsonline.com/0/0a0678fd-f9df-4e8f-8c98-0b4794c5453c.pdf
User-Manual
content.etilize.com/User-Manual/1031159306.pd
Oct 19, 2016 • Home
2answers
How to set a Model:WT-8005 atomic cllock
download the manual from here: http://www.manualslib.com/manual/533191/La-Crosse-Technology-Wt-8005u.html
After changing batteries in both the outside sensor and the inside clock I no longer receive a reading for outside temp.
I have a thermometer with an outside sensor. It's necessary to remove both batteries, wait a few minutes, then replace batteries - sensor first. It may take a few minutes for the inside clock to pick up the signal. If it doesn't, try again with new batteries.
3helpful
Skyscan atomic wall clock 87315. Changed battery
Press and hold the set key until time zone appears, then + or - to your zone.
My skyscan model 87800 will not show outside temp. i have changed batteries but still get nothing on outside temp
Look in the manual, There should be a section on remote sensors, they usualy have a "sync" button on them. and hit main unit first then remote.
3helpful
2answers
The outside temp sender won't work. We put new batteries in it, but it does not send a signal. It will not put an outside temp on the clock.
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
Outside temp not measuring correctly
I keep the outside unit of our in/out set under a coffee can shaded under a bench; one could argue the aesthetics but shielding it from wind and sun is mandatory otherwise one can get record temps pretty often.
The outside units generally transmit to the receivers only every few minutes to keep battery consumption down so moving them won't necessary gie you an immediate change.
Top SkyScan Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a SkyScan Home Expert? Answer questions, earn points and help others
