Question about Sharp Wizard OZ-590A
Sharp OZ-590A USB Cable Problems
I keep receiving an error that says "this program could not detect USB cable." I tried a different port, tried turning off all programs that were running, and everything in users manual. Can someone give me some advice on how to fix this. Thanks
  • 1 more comment
  • Jay T Dec 10, 2007
    Cannot detect the USB cable on Dell Laptop running Vista. Tried uninstalling then reinstalling and plugging cable into different USB ports. Same result, "Program cannot detect the USB cable."
  • Anonymous Feb 09, 2008
    Same exact problem. I tried several times to uninstall/reinstall, in the proper sequence (as instructed in the one solution here), and nothing works. Keep getting the same message.
  • Sherri803 Aug 26, 2008
    Same thing with the message cannot find usb. Then it tells me to insert a USB diskette, what is that about?
Uninstall all the software you just installed and do not connect the usb device until you again run the install from OZ-590A CD. When it does not find a USB device then connect USB and it should detect it. If you don't do it in that order you won't get a connection. It should come up on COM7.
Posted on Mar 22, 2007
SOURCE:
Computer doesn't recognize garmin
Your computer uses USB Mass Storage Mode to detect your Garmin unit. If your computer does not detect your Garmin unit, you can try these troubleshooting steps:
Unplug the USB cable from the computer.
Turn the unit off and then back on again.
Plug the USB cable into your computer.
The unit either automatically goes into USB Mass Storage Mode or displays USB Mass Storage Mode as an option on the screen.
Note: If your computer still does not detect the unit, make sure that you plug the USB cable directly into the computer USB port and not the USB hub. If the cable is already plugged directly into the computer, try plugging it into a different port.
If you still experience problems, please contact Product Support.
Garmin car gps
Sep 23, 2012 | Garmin nuvi 1350 Car GPS Receiver
Is there any way to interace with USB
You will need 3 items to interface your Wizard with a USB port.
1. A generic USB to RS-232 adapter cable (with 9-pin serial connector, to match the connector on the OZ-730 interface cable).
2. A USB to RS-232 driver for the above cable. (If you have Windows XP: HL-340.EXE, contained in 111.rar, which can be downloaded from www.usbserialdrivers.com. If you have another version of Windows, or if you have Linux, you will have to consult the documentation on www.usbserialdrivers.com to find the correct driver.
3. Software to communicate with the Wizard. You should be able to use the software that came with it, or purchase RuppLynx, or download Microsoft ActiveSync or a similar free program.
I used a cable I purchased on ebay, the HL-340.EXE driver installer, and RuppLynx software to connect an OZ-730, an OZ-570, and a Zaurus 5800 to my Windows XP laptop without any problem.
Nov 13, 2010 | Sharp Wizard OZ-730
I have a sharp wizard oz-590a with pc Sync. I don't have the installation disk and I'm trying to find a free download for it. Can you help me?
For some reason I have a CD that is labeled "Sharp Software CD-ROM OZ-590/ZQ-590". Could this be what you are looking for?
PS - I never owned one so I dont know why I have it.
Jun 18, 2010 | Sharp Wizard OZ-590A
Where is the usb port on the the sharp wizard OZ-590A
Your phone would have came with all the associated cables it needs to connect to a PC. It's not necessarily going to have a 'USB' hole in the phone, there is an 'options' cable slot on the right hand side which will match one of the cables you received in your box, and the other end will be USB for the computer side. Make sure you install all relevant software BEFORE you plug the phone in. If you have windows vista or windows 7, make sure you run the software as administrator. Don't let the disc autorun, close it down, go into Start>computer> and right click on the disc, select 'open' or 'explore' on the disc, right click the phone software and select 'run as administrator'
Apr 16, 2010 | Sharp Wizard OZ-590A
Why can't my PC detect Garmin 255W when I plug it via USB?
First makre sure that the usb is working. Just plug anythign into the usb port and if it detect it we know that is working.
Now with the GPS plug the usb cable into the port you tested then plug the gps on the other end. Watch your screen (PC) and see if it detects the gps. It should say one of two things. One will be device discovered Garmin GPS (something along that line) or it may show USB storage device. You can plug it in and look under my computer for these if you missed what it said. Some versions of windows are better than others at detecting whats connected. And some hardware is better than other at detecting something on a connected usb cable.
You should also plug the cable into a differant port if you had left it connected and were getting this problem. And you should try plugging both into a differant computer if you can. Doing these can tell you if the problem is the gps, the cable the port or the computer itself. Usually just changing the port is all it takes.
Apr 03, 2010 | Garmin nuvi 255W GPS Receiver
Error 0x80040707
installation program error, remove and reinstall the game, maybe you will have to contact your phones vendor worst case- good luck!
Aug 18, 2009 | Sharp Wizard OZ-590A
I need the drivers for the sharp wizard OZ-590A
you can try this http://www.sharpusa.com/products/TypeSoftware/0,1086,79,00.html
Jan 18, 2009 | Sharp Wizard OZ-590A
USB auto detect
you might want to try other usb cable because there are a lot of usb's that are not following the revisions code.
Jan 14, 2008 | Sharp Wizard OZ-290
How do I change the date on my Sharp OZ 590A PDA
Menu > clock > edit on the bottom of your screen, scroll through and alter from there
Jul 17, 2007 | Sharp Wizard OZ-590A
Names transfer, nothing else (phone,add,etc)
I found some similar problems which led me to this site: http://www.outlookcode.com/jumpstart.aspx also read: http://www.fixya.com/support/p372380-sharp_wizard_oz_590a "You are not alone"
Jun 02, 2007 | Sharp Wizard OZ-590A
Sharp Wizard OZ-590A Logo
181 people viewed this question
Top Sharp Computers & Internet Experts
Jason Harris
Jason Harris
Ekse
Siul Oyaratgam
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
