Question about Acer AL1512BM 15" LCD Monitor
Monitor cycles through various colors
The problem is that whenever someone walks across the floor, my monitor fades from white to blue to green. I have checked and double checked all the connections thinking it might be that one of them were loose, but it still continues to cycle through the above mentioned colors.
    President:
  • 2,961 Answers
Sounds like some sort of static effecting it but i doubt it, youve checked your'e wires but if it's a graphics card have you checked the card it may need re-seating, also check connectors for bent pins.
Posted on Nov 03, 2006
SOURCE:
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
Can't red and green colors
This usually means the red or green or both primary color module is bad. Monitors come with 3 primary color module controllers and they use them in various combinations to make the other colors. The primary colors are blue, green, and red.
Sep 17, 2010 | NEC AccuSync 900 19" CRT Monitor
My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again... (More) My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again during...
well that could be because the screen is going bad. you might want to get another one or take it in to get it fixed, no more than 100 to fix your screen.
Feb 13, 2010 | Dell E176FP 17" LCD Monitor
Monitor keeps going blank, then once this a.m. it cycled in colors, white, red, green, blue, grey- very weird... what's up with that?
it's doing testing in color codes to refresh the color on the screen, if it keeps going blank, that's usually a sign of monitor going bad.
Oct 16, 2009 | Westinghouse L1928NV Monitor
ViewSonic VA912b monitor fading out during boot
It is probably the power supply, or the inverters.
Similar problem with solution, though it requires you to know something about electronics.
http://www.badcaps.net/forum/showthread.php?t=6876&highlight=*va912*
Jun 12, 2009 | ViewSonic VA1912wb 19" LCD Monitor
My flatscreen dell monitor fades out to dark gray, sometimes pink
Its definetely the monitor thats having a problem. when it blacks out during th monitor self test. i suggest you can ask for a replacement monitor.
Mar 19, 2009 | Dell E193FP 19" LCD Monitor
Lcd monitor
maybe someone pushed on the screen if so it is not fixable, probably not anyway take it back to store and tell them it was like that when you bought it
May 28, 2008 | Compaq Computers & Internet
Dell P1110
Hi, The part where you see some color bars and blinking green led is what we call MONITOR SELF TEST. A diagnostic pattern consisting of four colors (red, green, blue and white) appears, and the LED flashes slowly. this happens when signal cable from the monitor is disconnected from the tower and leaving the power chord for the monitor plugged in. If the monitor works properly on a different computer. then its a problem with the computer's video card sending out signal. im 85% sure that its a problem with your video card.
Oct 02, 2007 | Dell UltraScan P1110 21" CRT Monitor
Colors flashing no picture
Did you have another monitor to verify the problem whether it is related with the Video card or the monitor itself?
Jul 29, 2007 | Xerox XG-71D 17" Flat Panel LCD Monitor
Acer AL1512BM 15" LCD Monitor Logo
387 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
