Question about Brother HL-2040 Laser Printer
Paper Jam! Everytime I start to print it seems to get wrinkled up and stuck. What do I do?
  • 1 more comment
  • santisteban Nov 10, 2008
    When it's already coming through.. Basically as it's coming out it start to wrinkle up and get stuck.
  • jnd0151 Nov 12, 2008
    It will print one page everything looks good but after that the red paper light starts blinking I opened the back and seen the paper was jammed. My printer is a reconditioned one and was give to me with no instructions on how do do anything on it . So what do I need to do & how to fix the paper jam. jnd01@cox.net
  • Asish Sharma
    Asish Sharma May 11, 2010
    Where does the paper get stuck..in the tray as soon as paper is picked...where the cartridge is...towards the end where the fusser unit is(hot unit).....or near the output tray.......
    Scholar:
  • 121 Answers
The paper is getting stuck near the fusser unit......Normally you can
(Caution this unit is hot leave the printer off for a while)
remover the fusser unit from the back of the printer...view to check that due to heat the plastics may have bent a little where the paper hits and gets stuck...check both the inlet and the out let path on the fusser itself...and the rear surface where the fusser sits......try to forcing it to place... not over doing it as it may break,,just a little pressure
Check to see that the Teflon the cover inside the fusser is intact and not torn....if its torn you will need to change the fusser.....
resit the fusser
close and test print
if this doesn't fix the issue you will need to change the fusser unit
Please do not forget to vote or if you need further clarification feel free
Cheers!
Posted on Nov 12, 2008
I have a hpj6480 printer. It says paper jam. I've done everything, turned off removed every piece to clean out, pushed every imaginable button...still paper jam it reads....
Below are the causes of paper jam
  • Paper loaded incorrectly in the paper tray.
  • Damaged or dirty paper rollers.
  • Torn, wrinkled, or damp paper loaded in the paper tray.
  • The rear access door or two-sided printing accessory (duplexer) might not be closed or is not locked into place.
  • Paper was added to a stack already in the tray while the HP product was printing.
  • The tray contains more than one type of paper.
  • The paper is jammed inside the HP product where you cannot see it.
  • An obstruction is blocking the paper path.
  • Torn pieces of paper from a previous jam are stuck in the product.
  • The tray is too full.
  • If printing on an envelope, the edges of the envelope are bent.
Try steps provided in below link and check if paper jam is resolved.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c01312792
GuruAid.com
Oct 30, 2014 | Office Equipment & Supplies
I have an imagerunner 2800 and it only seems to jam in the tray loading area, just bends the long side of the paper randomly. It changes it's performance just like the weather, sometimes I can get multiple...
A couple of things to consider:
Do not load the following types of paper in the paper drawer. Doing so may cause a paper jam.
- Severely curled or wrinkled paper
- Heavyweight paper
- Transparencies
- Paper on which color images have been copied.
- Paper which has been copied on using a digital full color copier (do not copy on the reverse side
either).
- Paper which has been printed on using a thermal transfer printer (do not copy on the reverse side
either).
Also, what # paper are you using?
Oct 12, 2013 | Canon (6981A002AA) for imagerunner 2200,...
Every page printed has a wrinkle pressed into the paper
Its or moisture issue or wrong pressure between fixing roller and press roller.
Jun 30, 2010 | Office Equipment & Supplies
HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Jan 27, 2010 | HP LaserJet P3005n Printer
Says there is a paper jam everytime i try to print
Hello
Check within your paper feeder rollers there might be something stuck inside it like paper clips, coins or anything small and solid. If you can find way to open the printer without braking it, that would be nice.
Hope this helps.
Jan 12, 2010 | Canon PIXMA MP180 All-In-One InkJet...
Wrinkled Paper
Check paper path,especially near fuser.If all ok fuser is faulty.
Jul 10, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Paper jamed or wrinkled
Dear
this is the problem of hot roller replace it paper jam problem will be resolved.
Nov 25, 2008 | Samsung ML2251N Laser Printer
Paper jam 11
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 07, 2008 | Copystar CS-1815 Printer
Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Sep 10, 2007 | Xerox Phaser 7700 Laser Printer
Paper problem
At this point, you my wish to try feeding a slightly thicker piece of paper or light card stock through the printer. If that fails and there is no obvious paper jam then I'm afraid there is nothing else and the printer would need to be serviced or replaced.
Sep 09, 2007 | Epson Stylus CX5200 All-In-One InkJet...
Brother HL-2040 Laser Printer Logo
103 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
