Question about GE DVL223GB Gas Dryer
Drier Belt Replacement on GE model DDG7580
Please advise me on the replacement process of the belt on this model.
Thanks in advance, Ian
  • iderbyshire Nov 13, 2008
    Thanks for the tip. Took me less than 1/2 hour to fix the drier.
    I saved about $100 on service call.
    You are a great resource.
  • Anonymous Dec 06, 2008
    belt replacement
  • 1,543 Answers
Open the door and remove four screws which go into the dryer top. Swing top back. Take out the screw on each side holding the dryer front to the side panels near the open top. Tilt the dryer front forward and lift it off the bottom pegs, then swing it to the side. Leave door switch wires connected. Lift up slightly on drum to allow the belt to be placed around drum. (grooves of WE12X82 belt touch the drum) Belt goes down from the left side of the dryer directly to the grooved motor pulley, then around the belt tensioning pulley and back to the drum. Your model has a removable panel at the bottom side of the back which will allow easy access to the motor pulley area.
Posted on Nov 10, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Nov 14, 2008
    Glad to hear that I was able to help you fix your dryer and save you some money. Most of us on FixYa give our expert advise for free the grater majority of the time, and your feed back and FixYa ratings are our main reward. Don't forget to rate my solution. Thanks.
Replace belt on maytag dryer lde8824ace
If it is a model where the belt goes around the drum rather than a separate pulley the drier must be dismantled far enough to allow the belt to be freed from the drum.
Belts need to be replaced so infrequently manufacturers make little provision for in-service replacement and generally the drier must be taken back to the stage in production where the belt was originally fitted.
This can be a rather extensive process with many models and in the absence of dedicated model information we often must resort to simply keep removing screws until the thing falls apart. By the time a belt needs replacing the drum bearings and/or seals are often generally in need of attention in addition that the extra work, though inconvenient and dispiriting, is rarely wasted.
Feb 08, 2015 | Maytag Dryer Drive Belt - Y312959
GE washer belt 7 PJE 1303
Please check with the site : wwwespares.com for spares
click this link for tips on replacing belt: belt replacement
Jun 25, 2012 | Beko Hutchinson Poly.v Dryer Belt 9phe...
To replace the belt on GE Dryer DISR473DG1WW, we will need to open the back of the cabinet, right? Is there a repair manual showing the process? Does this dryer ship with a spare belt inside?
Hello, W/D here.
I'm not aware of any dryers shipping with a spare belt on board, but this may vary by region.
You are correct in that the back is removed to gain access to the belt. Disconnect the power first. If there isn't a spare in the cabinet (probably not), take the old belt with you to your local appliance parts supply house and get a replacement, or it may be ordered on-line. The belt number will be on the belt.
Here's a good website showing how your model is assembled. This site also has parts descriptions and prices; useful for comparison shopping. There is also usually a button-link to a free downloadable manual. Here 'tis: http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Dryer-Parts/Model-DISR473DG1WW/0432/0151200?pathTaken=&prst=0&shdMod=DISR473DG1WW
Another good site to check for parts is: http//www.appliancepartspros.com.
Armed with these items, replacing the belt will be child's play for you!
Best regards, (and please rate this solution), --W/D--
Apr 02, 2011 | GE Dryers
I have a Roper drier, Model # EL5030VW0 Recently we put too much into the drier and it stopped tumbling, but there is still heat. We suspect the belt went wrong. How to open the cabinet and examine the...
here is a blow up of that model you might have to copy and paste link hope this helpshttp://www.partselect.ca/ModelFrames.aspx?ModelID=586816&ModelNum=el5030vw0&mfgModelNum=&ManufactureID=3&Selected=6QLYC5ZY&Position=0&mfg=Whirlpool&Type=&Mark=0
Feb 27, 2011 | Roper Dryers
Model # DBSR453EB2WW; sounds as if belt needs lubrication when operation dryer, high pitch sqeeking. Please advise.
The belt is attach only to the motor pulley and a tensioner pulley one of which is most likely in need of replacement...you could oil or grease them but that probably wouldn't last very long or work at all...??
Apr 19, 2010 | GE DBSR453EBWW Electric Dryer
Need to get replacement belt for washer. where to
If the model number you have this question listed under is correct, the part number for a replacement belt is WH08X10024. You can find it listed at appliancepartspros.com for about $37.
If you have never replaced a belt on this type of washer before, the following link explains how:
http://www.fixya.com/support/r3059652-drive_belt_installation_whirlpool_duet
The link is for Kenmore Elite and Whirlpool Duet, but the GE model listed is identical in design.
If you have any questions, please let me know. I hope this helps you.
Oct 15, 2009 | GE Energy Star WCVH6260F Front Load Washer
Dryer belt replacement
facing the drier get a small putty knife come about 1 inch from the edge of the drier and push in with the putty knife to release the plastic clip some times this can be difficult pull up on the top at the same time do that on either side till you get the top up then tilt the top back against the wall disconnect the door switch wires look in the drier to the front panel on either side you will see two 5/16 screws remove them tilt the front panel toward you and remove the panel put the belt around the drum slide it back to where you can see the old one has been running pull the idler wheel back hold tension on it and put the belt around the motor pulley let the idler pulley up till it engages the belt and reverse dissemble don't for get to plug the door switch back upimage3.gif
Jun 17, 2008 | Dryers
GE DVL223GB Gas Dryer Logo
360 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
