Question about Samsung CLP 300 Laser Printer
My samsung clp 300 won't pick up the paper - Samsung CLP 300 Laser Printer
  • Anonymous Dec 29, 2008
    I had a problem with the paper jamming in the heated rollers, but cured this by cleaning the chromed strip in front of the main roller. Now it will not pick up paper and cuts out when warming up. I cannot get the cut-out from operating.
  • soc967 Jan 03, 2009
    The printer won't pick up the paper, and the printer is telling me it has a paper jam at the exit area. I can't see any paper and there is a lot of heat coming from the top of the printer?
Have you try to clean the pick-up roller? May be that there is some powder on it or it is consumed... I normally clean it with cream soap and water (no alchool or glass cleaning products!!). You can also unmount it from its base and rotate of 180°: so you use the side not used.
For unmount the pick up roller, remove the paper tray and open the rear cover: you see the pick up roller and two little plastics "teeths" that blocks the roller... with two screwdriver you can unblock the roller, so you can exctract it.
For me this ha worked fine!!!
Posted on Feb 10, 2009
    Problem Solver:
  • 5 Answers
I had same problem and lifting front part of paper tray helped resolving it. I put a spare USB drive under front part that keeps paper tray pushed a little upwards. Now it is working fine.
Posted on Dec 25, 2008
I used to have the same problem.
Levelling the paper tray helped to solve it.
Make sure the printer + paper tray stands on an equal levelled surface (on which the tray doesn't hangs over the surface)
Posted on Nov 26, 2008
Samsung CLP-300 printer not printing, the paper tray will not pick up the paper.
Often the rubber pickup roller is either worn or dirty. It is located just above the paper tray. Use a damp cloth and try to cleaning it, sometimes that helps. Otherwise you will need to replace the roller.
Jun 16, 2011 | Samsung CLP 300 Laser Printer
Samsung CLP-300 paper does not seem to be catching when printing?
Hi. Kelly,
I think the issue is the due to paper pick-up roller. When the rollers get dirty or worn-out, the printer fails to pick the paper, which results in paper jam etc.. So, remove the paper tray and toner cartridge and locate the paper pick up roller in the middle. Clean it with damp (with luke-warm water) and lint-free cloth. I hope this would fix the issue. If the Roller is damaged or worn out, it needs to be replaced.
Hope this helps! Good Luck!
CreativeTECH
Feb 15, 2011 | Samsung CLP 300 Laser Printer
I have samsung printer 1600. The printer not pick
http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=06010200&model_name=CLP-300
The above is for the clp-300 laser printer.
You say you have a samsung print 1600 but when I searched I found a blue ray player with that number.
Is this the right link?
Jul 20, 2010 | Samsung CLP 300 Laser Printer
Hello, My Samsung CLP-300 won't feed the paper from the tray. I found that the soft rubber pad on the rotating barrel that picks the paper from the tray has broken off the drum. How can it be repaired?
Well it's a $30 part, and a bit of labor to change the part:
http://www.iteminconline.com/itemdesc.asp?ic=JC97-02647A
Some hint at the replacement procedure:
http://www.fixyourownprinter.com/forums/laser/57238
Nov 02, 2009 | Samsung CLP 300 Laser Printer
Samsung clp 300 paper jams after feeding about 5cm. Tried more paper, less paper, printing black only, printing colour, no change. Help
Clean up the Pick Up Rubber.
When you are able to get the Pick Up Rubber out of the maschine rotate it 180 degrees an reinstall it. then the problem would be fixed.
Oct 14, 2009 | Samsung CLP 300 Laser Printer
My Samsung CLP-300 won't pick up paper (it goes 1 inch & stops)
No oil on rubber rollers! You must gently clean the rubber roller with isopropyl alcohol and a soft cloth. Let it dry and it should work again. Make sure to get ALL of the oil off of the paper paths surfaces.
Sep 10, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP-300 picking up too many pages
Hi
Thanks for using FixYa. Paper jam is a very common problem with the printers.
First of all clean off the rubber piece that pulls the paper into the printer from the tray with rubbing alcohol, and also take a knife to the rubber piece to rough it up to create more traction.
To clear the paper jam problem you need to remove the back roller mechanism to get at paper. If still the problem persists, then check the following to resolve the issue--
1. Please check all interlocks, electrical and signal connections are seated properly.
2. Front cover, back cover and lid are closed properly.
3. Power plug and USB cable are connected.
4. Printer is turned on with switch on the back.
5. Toner signal lights sequenced, with yellow overall led on.
6. There is some noise of paper roller movement.
7. Toner signal lights all out, overall status light turned to red
8. No visible paper in paper tray or anywhere else.
9. No paper in tray---added paper
10. Waste toner container is full or not installed ---empty, installed properly.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Samsung CLP 300 Laser Printer
The printer will not pick up the paper!
Suggest you clean the pick-up rubber that lifts the paper.
And also lift up the front of your CLP-300 by about 3 inches. I put a box under the front. The paper will fed slightly downhill into the printer.
It works for me.
Richard
May 04, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP-300 paper feed
Clean the feed roller.
Remove the paper tray, from the bottom there is a grey rubber semi wheel in the middle front of where the paper tray would be. Use a cloth with WD-40, brake cleaner, or lighter fluid to lightly wipe the rubber clean. Put the paper tray back in and it should print.
Jan 24, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
276 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
