FixYa.com
Tags:
LG LRMM1430 1200 Watts Microwave Oven
Where is the light bulb located? (by 5 users)
posted by wendishea on Nov 03, 2006
My microwave works just fine, but the inside light bulb is not working. I can not figure out where it is located to change it, or what kind of light blub I have to get to change it. Any help will be greatly appreciated.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by Guest, posted on Jun 27, 2008
i need to change the light inside of my microwave cant find the bulb r1610
Comment by George31, posted on Apr 19, 2008
Were is the bulb located so I can change please everything else works fine on unit
Comment by Guest, posted on Feb 26, 2008
Jenn-Aire JMV8208AAB
Microwave is working, but suddenly the inside light is not. I removed the exterior top strip, but the light bulb is not visible, so I cannot determine if it is burned out or otherwise malfunctioning. On the upper left, to the left of the filter, there is a recessed area where the bulb should be - probably - but there is a black piece about 3" by 1.5" that is blocking that area, and I can't get it out to see if the inside light is back in that cavity. Should I risk damaging that block piece by pulling is vvv
Comment by Guest, posted on Dec 16, 2007
How do I change the Light Bulb?
Best Solution
posted on Nov 05, 2006
Helpful (85)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2617 votes
If there is not an access panel inside the cooking area (cavity) or on the back, then the outer cover will have to be removed to access the lamp.
For help on that, you can find my safety info and disassembly text files by doing a search on Yahoo for this term: microwave oven disassembly.txt
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE Spacemaker (JVM1640SJ) Microwave Oven GE JVM2050 1100 Watts Microwave Oven GE JVM1840 1000 Watts Microwave Oven GE JVM1640 1000 Watts Microwave Oven GE JES1290 1000 Watts Convection / Microwave Oven GE JES1358 1200 Watts Microwave Oven GE JES1851 1100 Watts Microwave Oven
Can you Help with these Microwave Ovens problems?
Microwave Ovens
sharp carousel
just plugged in my sharp... Answer This...
Microwave Ovens
Our Sharp Microwave Model...
Our Sharp Microwave Model... Answer This...
Microwave Ovens
Model #JES2251SJ02 trips...
Model #JES2251SJ02 trips... Answer This...
Microwave Ovens
MICROWAVE NOT WORKING PROPERLY
turn table dose not turn and... Answer This...
microwave oven still running...
I personally do not have a... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
