Question about Hoover H120M Front Load Washer / Dryer
Washing machine say NO!
Hi, my washing machine has a few problem. It fills up (all) with water and doesn't do much else. I've tried to manually advance it but.. it works a bit and then loads up water again and then spins a bit and then.. but nothing more. I checked the belt it's OK (it spins fine but because there is too much water it feels like exploding). What else can I check... the program? Thanks Burro
  • Mar Silves Nov 10, 2006
    Any IDEA anyone??
    Please I cannot effort to buy a NEW ONE.
    Cheers
    Burro
    President:
  • 1,462 Answers
Because of what you say about it feels like it is exploding on spin cos too much water, suspect it may be drain pump. check filter is not blocked. check no foreign object stuck in pump - bits of bra wires are the favourite
Posted on Apr 19, 2007
Hi. I’ve got a HAAS deluxe HWA140SNN too loader washing machine. It’s coming up with a E1 code after about 3 mins during the water filling. What is that ? How can I fix it ?
This is a 'fill error timeout'. Can be caused by low water pressure from blocked filter cups, low mains pressure, faulty isolation valve, or blocked hoses. Can also be a faulty water inlet solenoid which is not opening far enough for a good flow of water. In normal circumstances you hear it RUSHING into the machine rather than TRICKLING.
Haas washing machine E1 code Google Search
Nov 18, 2017 | Washing Machines
Home Comfort HCWP1201 Portable Washing Machine doesn't spin...
Sounds like the belt is either broken or slipped off,or the pulleys on the motor or basin are not turning. Most likely it will be the belt. If you can open the panel you should be able to see the problem. If it is the belt,you may find the part at any appliance shop and fix it yourself. If the pulleys are not turning the belt,there could be a few different reasons for this. You would have to look at them and find out why. They may be fixable but it would depend on the specific problem. If the machine is still under a warranty,it would be best to take it to the dealer.
Feb 18, 2013 | Home Comfort HCWP1201 1.7 cu. ft. Portable...
My frontload washing machine fills water but then it will not turn.
I would check the motor. Sound like it may be at fault.
Nov 04, 2012 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Washing machine not filling
yes your problem is up the line somewhere. you have to have water coming out of the fill line when the washing machine is unhooked.
you will have to locate the valve to turn on the water.
good luck
Jul 05, 2012 | Russell Hobbs RH1042 Frontload Washing...
Washing machine doesn't fill with hot or clod water.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jul 05, 2011 | Maytag Washing Machines
Washing machine fills, but won't agitate
sound like the lid switch is open, if that doesn;t fix it try the water level switch
Mar 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Hoover H120M Front Load Washer / Dryer Logo
126 people viewed this question
Top Hoover Washing Machines Experts
shaun taylor
Hjalmer Lamminen
Hjalmer Lamminen
Steve F
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
