Question about Car Audio & Video
Back up camera mirror image setting?
Hello,  I just had a Kenwood 7120 installed into my 05 F350 pick up and I have a back camera on the truck as well. The problem is when I place the truck into reverse the camera shows anything on the screen on the opposite side of the truck they are actually on. So if there is a telephone pole on the right side of the truck backing up the screen in the cab on the 7120 shows the pole to be on the left side of the truck. Is there a setting on the 7120 that I can mirror image this so the back up camera will actually reflect what side of the truck an obstacle might actually be on? Thanks Mark
  • Anonymous Nov 11, 2008
    problem
The Camera itself should have a Image Mirroring Function on one of the cables. Usually for the correct image to show how you need it to show for the back up camera, there is a jumper terminal that should be left or taken off. Or the only other solution would be if your unit had a setting where you can switch the image.
Posted on Jan 06, 2009
When put in reverse the image is up side down.
How to Reverse the Image on Backup Camera eHow
EVERYTHING YOU NEED TO KNOW ABOUT REAR VIEW CAMERAS
After installing a backup camera on your vehicle, you need to reverse the image so that the image on the screen matches that of your rear-view mirror. The orientation must match so that the driver doesn't get confused with two conflicting images. The nature of the camera's technology is that its image will be recorded un-reflected, but the mirror will display a reflected image. Fortunately, the engineers who designed back-up cameras thought of this and created simple controls for you to change the orientation.
Read more : http://www.ehow.com/how_6641139_reverse-image-backup-camera.html
Jan 12, 2016 | 2011 Lincoln MKX
Kenwood KVT-617DVD - Rear Camera Option Not Working
Since "...everything else is working..." indicates that there is no blown fuse or chances are nor any hardware is at fault.
When the battery was disconnected, the Kenwood KVT-617DVD may have suffered a memory failure and would require a reset.
Have you tried doing a reset? It's a small recessed button near the bottom right side of the font panel underneath the protection panel (right of the Joystick Track/Station Key & above the Eject Disc Key). Pressing the reset button should restore the Kenwood KVT-617DVD to default factory settings. Of course this will also remove any special programming that you may have such as favorite stations, etc.
You also posted "...Parking brake requirement...bypassed..." this is only to allow the display to be always ON. This is the green wire that must be grounded
You need also to check that the "Reverse" wire/trigger is also bypassed that is to set the "...camera...full time...rear view mirror and back-up monitor for the truck camper..." This is the pink wire that must be attached to the ACC of the vehicle's Ignition Switch. Alternately, it may be connected to the red wire of the Kenwood KVT-617DVD.
If the reset does not correct the problem, you may need to run the setup menu again following the user's manual. Should you need a copy, it is available on line here. Pls verify that you set R-Cam Interruption to ON & R-Cam Mirror to Reverse. This is better explained with appropriate illustrations in page 69 of the User's Manual.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 10, 2007 | Kenwood KVT-617DVD Car DVD Player
Back up camera image has reversed, how do I correct it
Inverted image on back up camera - JK-Forum
www.jk-forum.com/.../jk.../inverted-image-back-up-camera-245590/
Aug 26, 2012 - One was a normal image, which was for front or side cameras. The other is a reverse or mirror image, which makes the backup camera look like ...
backup camera image flipped - Nissan 370Z Forum
www.the370z.com > Tech Area > Audio & Video
Jun 10, 2012 - 15 posts - ‎7 authors
With some of the camera there is a connection that is either made or broke to reversethe image. I would check the connections near the ...
Nov 01, 2015 | Cars & Trucks
My camera upside on my pc asusk501
WEBcam image problem
Most WEBcams have a setting tomirror or turn the image upside down etc. Go to your WEBcam setting to set yourimage back to normal.
Apr 03, 2012 | Computers & Internet
How to replace the electronic interior rear view mirrow on 2004 Envoy SLT. I have a new one to install and need to figure out how to remove the old one on the truck...
Hello lindleyjl,
1. You will need to disconnect the wire cove from the upper mirror base. (See image below)
2. Use a flat blade screw driver to disconnect the electrical connector from the mirror. Number 1 in the image.
3. Use a torx driver to loosen the set screw that holds the mirror base to the windshield button.
4. Slide the mirror upward off the the rear view mirror button; number 1 in the image below.
To install, reverse the above outlined procedure.
I hope this helps.
Regards,
netvan
Jul 24, 2011 | 2004 GMC Envoy
How do i change to mirror image
If you mean changing the image produced by your web cam to a mirror image, then this is what you should do.
Though, the process may vary as a result of what camera software you have installed.
Start your web cam.
Go to the settings.
Select camera settings.
You would see the options to flip the image horizontally. Do that to set the mirror image.
Some software might not indicate the flip option, rather, it would ask to select 'mirror image'.
Select whichever is appropriate.
I hope that this helps.
Success.
May 20, 2011 | Acer Aspire 5610-4648 Notebook
The view finder darkens every time i take pictures
That's how a DSLR camera works. When you are setting up the shot, the image through the lens is reflected by a mirror up to the viewfinder. When you snap the picture, the mirror flips out of the way so the image can be registered on the sensor and then the mirror flips back. So, for that time, there is no image in the viewfinder.
Jan 07, 2011 | Olympus EVOLT E-500 Digital Camera
Mikomi dc-7120 not working on skype
Mikomi DC-7120
Install software first>>then restart PC>>Connect camera to USB port>>the restart PC. Then do the test call to Skype. All should be OK. Skype was already installed when I did this.
I too had problems initially because I did not follow the above procedure.
Sep 15, 2009 | Microsoft LifeCam NX-6000 Webcam
Mikomi dc-7120 webcam on Skype
Problem solved:
by shutting down all other programs including the webcam itself, this enabled the webcam to be accessed by Skype and all worked fine!
Jun 17, 2009 | Computers & Internet
I just installed a kenwood navigation system in my lincoln mark lt and hooked the factory backup camera to it. The image is reversed. What do i need to do?
Im not 100% sure but i beleive it is in the system set up. Go there and on one of the pages there is an option to have the rear cam mirrored or not. If you can't find it let me know ill tell you for certain where it is.
Jan 31, 2009 | Kenwood DDX-512 Car DVD Player
Car Audio & Video Logo
102 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
