Question about Jet 3 Ultra Power Chair
Jet 3 Ultra won't charge
The batteries charged fine last month. For some reason when we need it this month the batteries won't charge. The ammeter never registers above 0 after charging. The power lights will come on but when removed from the charger the chair won't turn on.
Any ideas why it quit? where I can find a repair? I have a problem with the chair not turning on after charging. The yellow lights on the botton line flash but the chair will not do anything. no dealer will help me.
Indeed, you need to find a repair shop. Try a google search for power chair repair, or ask your local hospital or if you can find one a power chair store. Most likely, you have a mechanical failure of the wiring, the battery themselves, or corrosion on the battery posts. Since the chair lights up when the charger is in, it is unlikely that the charger is broken. You may have a failure of the controller board, but that is also unlikely. And batteries do not usually suddenly fail completely; they typically fail slowly, losing the ability to completely charge.
I assume that you did not see a great deal of fluid leaking out of the battery container; you might look in the container and check to see if a battery is cracked or missing fluid.
Posted on Nov 10, 2008
2 Suggested Answers
  • 37 Answers
SOURCE: Jet 3 Ultra won't charge
You can find the Fuse behind the foot rest. Take the pin located under the foot rest, and the casing will come off exposing the fuse.
Posted on Jun 24, 2009
Battery light on and off
The battery light means the alternator is not charging the battery. The charging system would need to be checked out when the light is on.
Feb 07, 2014 | 2001 Pontiac Montana
The car soulds like the battery is low but when it starts the flashers come on.
Often an alarm system will register a low battery voltage and presume the vehicle's battery is being removed to prevent the alarm from going off. They will then begin flashing and or sounding the horn.
In your case, I would presume that the battery voltage is too low which may indicate either a failed battery, or a parasitic voltage drain.
First, get the vehicle started, and run the vehicle for a good twenty or so minutes to get some charge to the battery. If you don't want to waste fuel however doing this, then I suggest using any battery charger, as all we want to do is get some voltage back in the battery. If you are using a charger though, then charge on a lower voltage setting overnight.
Once you have the battery charged, run off any surface charge by turning the vehicle lights on for a minute, then turn them off again.
You need an ammeter for this next part:
Disconnect the battery positive terminal and connect the ammeter in series with the battery and positive lead.
DO NOT ATTEMPT TO START THE VEHICLE!
With all vehicle systems off, the key out, doors closed and alarm 'OFF', bonnet close switch depressed, or bonnet/hood clasp closed (need a screwdriver), take a reading from the ammeter.
After probably no more than twenty minutes, the ammeter should be reading 0.03 amps and not much more. Anything like 0.5 or 1 amp means you have a battery drain.
If this is the case, then start by disconnecting the alarm system. If the alarm system has it's own separate speaker/horn, then disconnect this first. Many of these horns have backup batteries, which only last three or four years before they fail, which causes them to constantly draw from the vehicle battery and then flatten it when parked.
Every time you disconnect an item or system, check that ammeter again to see if the amps have returned to normal. Pull fuses one by one, checking the ammeter each time for any change until you find the system which is causing a drain, then attend to that system.
If your amps are normal however and your battery is still loosing charge when parked for any short length of time, i.e. a few days or so, then your battery is at fault and requires replacement.
Just before changing your battery, do one last check, which is with the vehicle running. You need to reconnect any battery cables, and start the vehicle. Using the voltmeter once more, check the voltage across the terminals with the engine running. This is your charging voltage and it should go up to around 14 volts if revving the engine slightly. If still around 12 volts only, then you have a charging issue, which is probably the alternator.
Nov 11, 2012 | 2008 Toyota Corolla
2003 mazda tribute, occasionally won't start. fuel pump replaced about 1 month ago. bad starter?
Many batteries may only last around three years. Check battery voltage at rest before starting. Any voltage in the low 12v range may be a sign of a faulty battery.If low voltage present, then perform a parasitic drain test:1) Disconnect battery POSITIVE terminal and connect ammeter in series, between battery positive terminal and positive lead.
DO NOT START THE VEHICLE!!
2) With all vehicle doors closed, alarm off, lights off, radio off, and all other accessories off, wait for around 20 minutes and then read the ammeter. A healthy system should read about 0.03 amps and little more. If reading more, then the vehicle could be suffering a parasitic amp drain, and you will need to locate this issue.
3) Reconnect battery when finished.
If no major parasitic drain present, yet low battery voltage then:
4) With vehicle started, check the voltage charge from the alternator. Connect voltmeter to battery terminals and take reading. A healthy system should be charging in the range of 14volts or down to around 13.5 volts. If reading around 12 volts only, then check and replace alternator.
Nov 03, 2012 | Cars & Trucks
The batteries will not charge. The ammeter does not move,just stays at 0 all the time. I pulled the connectors off the ammeter and there is 24 volts going to the ammeter.Not sure if the meter is bad or the...
It is an AMP Meter (Amperes) and AMP's are relative to CURRENT, not Voltage. Voltage measurements are read by a VOLT Meter. W=Watts or work units. Like a 40 Watt Bulb. R=Resistance. If the Battery fails to charge, it is due to the cells degradation as they only last so long. From what you wrote, I assume you need to replace the Battery.
Feb 11, 2018 | Pride New Jazzy 600 Power Wheelchair by...
My camera will not charge. It was purchased just short of a year ago, so here is no reason for the battery to be broken. It will not charge at all when the memory card is inserted and when it is, the...
Hi, It almost sounds like the battery won't hold a charge anymore which means you need a new battery. Since the camera isn't quite a year old yet I'd suggest contacting Nikon and seeing if they'll do anything for you before you buy a new battery.
May 12, 2011 | Nikon Coolpix S4000 Digital Camera
Jazzy 1103 will not charge. Power cord and electrical outlet verified good. Plug in chair for charge, the ammeter indicator bar remains at 0, even after several minutes. If chair is powered on (while...
The battery charger is only made to last 1 year if you
re lucky. They are all made in China very cheaply and some only last a matter of months. If you are on Medicare they will replace the charger if necessary after a year. Good luck, hope this helps
May 15, 2010 | Pride Jazzy 1103 Ultra Standard Power...
We purchased a Rascal 300 two months ago that worked just fine. We seen proof that new batteries had just been purchased. It has a built in charger and we have kept the batteries charged. The charger now...
Here's a link for the owners manual for the 300 model. Click on it and it will open as a PDF document that you can print. http://www.rascalscooters.com/manuals/300_manual.pdf
The ammeter back in the trunk should be registering when you plug the scooter in. If it isn't, this doesn't mean that it isn't charging as the meter itself may be bad. Put it on charge for a few hours and see if the "fuel guage" on the top of the tiller comes up to full. If it does, than your charger is okay and you just need to ignore the ammeter not working until it doesn't charge at all anymore, then the charger is bad. Note too, that later on when the batteries get weak and you can only go a little ways, that it still means your charger is okay, batteries not. Even bad batteries well show a full charge, but they won't take you far at all. If the batteries don't show a full charge after a few hours, then you need to replace the onboard charger.
Good luck
Jul 10, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Jan 17, 2009 | Computers & Internet
Check the fuses may have a Blown fuse
Regards; Aaron
Sep 16, 2008 | Jet 3 Ultra Power Chair
Jet 3 Ultra Power Chair Logo
700 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
