Error writing application data - Computers & Internet
  • 2 more comments
  • f1rz3n_0028 Nov 10, 2008
    every time I turn on my computer, if I leave it for a certain amount of time before I log on, it comes up with an error message sayin' "error writing application data".
    also, after I click the ok button, I have to press ctrl+alt+del to get the log on screen
    thx
  • JDTec
    JDTec May 11, 2010
    More info please......
  • 4,338 Answers
If it does it while you are away or no actually using the PC, I would suspect a Trojan or spy ware. Run you Anti-virus and download and instal WinPatrol, CCcleaner, SpyBlaster. all are free and dependable.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 10, 2008
Google search
hi there.
try this.if this does not work go to the link at the bottom and see if it helps you out more.
Symptoms: When you open Google Chrome, you receive a pop-up error message that says "Your profile could not be opened correctly. Some features may be unavailable. Please check that the profile exists and you have permission to read and write its contents.
Problem Cause: You have corruption in your Google Chrome profile data.
Solutions:
Mac OSX
  1. Quit Google Chrome.
  2. Open Terminal.
  3. Change directory (cd) to /Users/{user}/Library/Application Support/Google/Chrome/Default
  4. Delete Web Data and History files: rm -rf History*; rm -rf Web\ Data;
  5. Start Google Chrome and the error should be gone.
Windows 7
  2. Open Computer.
  3. Navigate to C:\Users\{username}\AppData\Local\Google\Chrome\User Data\Default\
  4. Delete the file named "Web Data"
Windows XP
  2. Open Computer.
  3. Turn on Show Hidden Files and Foldesr in Folder Options in Windows Explorer.
  4. Navigate to: C:\Documents and Settings\{username}\Local Settings\Application Data\Google\Chrome\User Data\
  5. Delete the file named "Web Data"
  6. Start Google Chrome and the error should be gone.
Linux
  2. Open a shell.
  3. Change directory (cd) to ~/.config/google-chrome/Default
  4. Delete the file named "Web Data": rm -rf Web\ Data;
NOTE: If the problem repeats itself after every reboot, then there is most likely corruption is your user profile, so you will have to delete the profile and start a new one. In order to do that, follow the above steps, and replace step 5 and 6 with the following. Make sure that you backup your bookmarks before doing this, as they are a part of your profile and will disappear after doing this:
5. Locate the folder called "Default" in the directory window that opens and rename it as "Backup default."
6. Try opening Google Chrome again. A new "Default" folder is automatically created as you start using the browser.
your profile could not be opened correctly chrome Google Search
Nov 17, 2017 | Computers & Internet
When attempting to burn project in MY DVD8 an error appears 800402007 while encoding. I am therefor unable to burn disc
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
  1. Go to Start--> Programs --> Accessories --> System Tools --> Disk Defragmenter.
  2. When the Disk Defragmenter window opens, choose Defragment.
If defragmentation doesn't resolve the issue, burn your project as a data file, and then burn your project as a data disc using Disc Copier or Creator Classic. To create a disc image/data file:
  1. After clicking the Burn button, the Burn Project window opens.
  2. You have two data burning options:
    • Image file - this option will save your project as an .ISO file. To burn this file you will need to use the Burn Image option in Creator's Copy section.
    • Folder Set - burning a folder set will create a Video_TS folder that you can burn using Creator Classic. Burning a folder set to DVD will create a fully functional DVD. Do NOT rename the Video_TS folder other wise it will not play! Simply place it in a folder that is the name of your project if you need to keep track.
      Tip: Either of the above options are a great way to not only back up your projects, but make multiple copies to reduce encoding time!
Mar 03, 2008 | Televison & Video
Error Writing Data (551-00000310 41329c5c)
Read only Means it may not burn a DVD but only CD-RW
Maybe the problem is the dvd is only rom not RW(read write)
Oct 24, 2013 | Computers & Internet
Error 49.4c02 comes up whenever i want to do duplex printing
Hello thanks for using FixYa
This is a critical firmware error that occur which cause the processor on the formatter to abort operation.This type of error can be because of invalid print commands,corrupt data,or invalid operations. Sometimes electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables or poor connections,
To solve this try this solution step by step
  • Turn the printer off and then back on.
  • Try printing a job from a different software application. If the job prints, go back to
  • the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance.
  • f the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or PC.
  • Turn the printer off.
  • Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
  • Remove all EIO devices from the printer.
  • Turn the printer on.
  • If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each
  • device.
  • Replace a DIMM or EIO device if you determine that it causes the error.
  • Remember to reconnect all cables that connect the printer to the network or computer.
  • If the error persists, final option is replace the firmware
    I hope this solution will helpful 4 u
    Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
    THANKS & Keep Using fixya
Jan 21, 2011 | HP LaserJet 4250dtn Printer
I use buffalo 1 TB external power hard disk on IMAC, it was work fine but now suddenly, when i copy any thing to it one error message came ''unexpected error--(error code 0)'' can't copy. please give me...
First when you attach it to your USB port it should come up as an external drive in any Finder window. If not then you need to run Disk Utility, found in Utilities in the Applications folder or just search in Finder for it. Select the external drive and make sure it says or and Partition Map Scheme : Apple Partition Map if it was formatted in 10.4 or earlier (you didn't say) or Partition Map Scheme : GUID Partition Table if formatted in 10.5 or later. If not formatted so, for example, it's Fat32, then it is set for a PC.
Assuming the last and that this is a new drive, you will need to format it for a Mac to be able to write. Select the Erase heading and for Format select Mac OS Extended (Journaled) in 10.5 or later or Apple Partition Map in earlier versions. Name the disk. Press Erase, knowing that the drive will be cleared of data. You can also choose to partition the disk, usually not needed nor desireable.
You can then return to First Aid and Repair Disk and after that Fix Permissions. If your disk had data already (you seem to say so) then this is where you would start making sure it says Write Status : Read/Write.
If the Partition Map is not as given above and thus the disk is read-only, then you will need to transfer the data to your internal or another external with the right map. -Ken
Apr 13, 2010 | Drive Computers & Internet
My phone has an error that say device error 400 reset. it wont even let me use it or nothing
When adding, deleting, or updating applications on your BlackBerry smartphone, you receive the following error message:
Device error 400
OR
your BlackBerry device resets itself and stops responding.
CAUSE
An unspecified error has occurred with an application on your Blackberry smartphone.
RESOLUTION
NOTE:The following procedures will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the data on your BlackBerry smartphone before performing this procedure.
  1. Disconnect your Blackberry smartphone from your computer.
  2. Open BlackBerry Desktop Manager.
  3. Open BlackBerry Application Loader.
  4. Reset your Blackberry smartphone.
  5. When the LED indicator has turned on, reconnect the BlackBerry smartphone to the computer.
  6. Click Next.
  7. On the following screen you will see either USB:Unknown or USB:; click Next.
  8. Select the required applications from the applications list and click Next. The firmware is loaded to your BlackBerry smartphone.
Jun 11, 2009 | RIM BlackBerry 7290
Cd rom wont write to disc,can this be fixed?
Its not a terminal problem but an issue with your CDWRITER or the application you use in performing CD Writing
CHECKLIST
1. Make sure you are using a Blank Empty CD
SOLUTIONS
1. Try formating the Blank disks from Windows Explorer and not from the utility software
2. Check your CDWRITER settings (usually problems do not arise from here) you could set the settings default.
Are there any error messages when trying to write data on the CD?
May 21, 2009 | Dell Inspiron 1501, Turion X2 TL-60 1GB...
Memory card is write protected
Take your memory card out of the camera and switch the position of the little "lock" tab. That should fix it and you can start saving images.
Nov 10, 2008 | Nikon Coolpix L11 Digital Camera
Seagate 300GB USB 2.0, read write error
Hook it to another computer do see if the drive is the issue.
Oct 04, 2008 | Seagate 300GB USB 2.0/FireWire Hard Drive...
Computers & Internet Logo
396 people viewed this question
David Payne
David Payne
