Question about Harley Davidson 426290 AM/FM Radio
Can't set clock on 2006 ultra classic
When you push set on the clock it says PST on and Newfoundland at the bottom, you cannot make any adjustments from there
I have a friend who had a simular problem he pulled the maxi fuse out of the bike for 5 min , this is suppose to completely reset the radio
Posted on Dec 20, 2008
How do I change clock from PST to Eastern time...?
sadly without knowing what your clock is . we have no idea other than setting the time 4 hours earlier than what PSt is .no clock I ever had had a time zone button .
Jan 02, 2016 | Audio Players & Recorders
My Seth Thomas radio controlled clock will not reset to the proper time. I've had it for many years, and this is the 1st problem. I changed the battery, I pushed the button for Pacific time ( I'm...
Hi lufberg,
I see you need help with your radio controlled clock.
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1REo5s6T9
I hope this will help.
Thank you for choosing Fixya,
mvincentc
Jul 04, 2011 | Vacuums
How do i set a radio controlled clock seth thomas hd 1688
  • Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
  • 2
  • 3
  • 4
  • Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1GyAcVHP2 hope this helps you
    Mar 17, 2011 | Seth Thomas Radio Controlled Wall Clock -...
    How to set
    Hello
    Mar 15, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    Oregon Scientific Stark clock resets itself to PST.
    -Press SELECT once and time number should flash.
    -Press and hold SELECT and it will enter settings mode for the clock.
    -At the bottom of the screen next to the moon phase you should now see PST time zone.
    -UP and DOWN keys will change the time zone.
    -Press SELECT and other clock settings can be changed.
    Jul 26, 2009 | Oregon Scientific Starck Large Music...
    Starck clock wrong time zone
    -Make sure clock is in radio sync mode. This is in the manual so won't repeat here.
    -Press & release SELECT. Clock time numbers should flash
    -Press & hold SELECT. It should enter clock settings mode
    -Bottom of screen next to moon phase you should see the current time zone. PST after reset
    -UP & DOWN will move through time zones.
    -Press & release SELECT when done.
    -Each time SELECT is pressed will move to a new setting like 12/24 hour etc.
    -Press SELECT until clock numbers stop blinking or leave it alone to return to normal mode
    -This should also work on the other Oregon Scientific Starck models.
    Feb 08, 2009 | Oregon Scientific Starck Large Music...
    Accuwave DS Clock
    The radio may not be able to get a strong enough or clear enough signal to process (night is best away from TV, computers and radios).  To regain "control" of the clock, take the battery out, wait 30 seconds and then reinstall it.  This will reset the clock.  You can then manually set the clock.
    Press SET for a few seconds until the hour starts flashing in the display.  Then press the ADJUST button to set the hour.  Press SET to move to the different functions (Hour -> Minutes -> Seconds-> Month -> Date -> Year) each time using the ADJUST button to correct the setting.  Finally press MODE to exit the setting mode.
    If the time zone is incorrect for your area (default is PST), press MODE to enter the Alarm Time Mode; then press SET to flip through the time zones; then press MODE again to exit.
    The little "reset" is for use if the LCD display doesn't come on when the battery is changed. It doesn't affect any of the clock settings per se.
    Nov 02, 2008 | Audio Players & Recorders
    Clock
    Push the small button beside the 1.
    scroll through the options with the volume dial until you get to "clock adjust" hit enter (top button) then adjust the hour with the volume knob. Hit enter again and adjust the minutes.
    press ret (bottom button on the left to bring you back to the main confirugarion screen (should see clock adjust again) then press and hold esc. (middle button between ret and ent) until the regular playback screen comes back.
    Nov 09, 2007 | Alpine CDA-9883 CD Player
    Harley Davidson 426290 AM/FM Radio Logo
    298 people viewed this question
    Top Harley Davidson Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
