Question about RCA F38310 38" TV
Is the f38310 digital ready or do I need a converter?
The TV was bought in 2002 by my father-in-law. Does he need to hook up a analog/Digital converter? He does have a dish hooked up, but it is not in service. He just uses it as an antennae. We did try to install the converter, but did not get a signal.
Thanks.
Cris
    Problem Solver:
  • 4 Answers
No you do not need a converter box your television is digital ready. I use mine with a regular antenna and recieve many channels mostly High Definition and some analog you should notice that when your hooked to a quality HD antenna and assuming you are within broadcast distance you will be very surprised at the quality you will no longer have blury or faded pictures they will be crystal clear. This is because digital broadcast is either there or it's not. no inbetween although you can get what is called speckling thats where little dots pop up randomly the best olution to this problem is buy an additional antenna and run both antennas in through a splitter and this should clear that problem up redundancy is the answer
Hope this helps
Posted on Mar 01, 2009
With Sony KP-46WT520 46 in. Rear Projection HDTV-Ready Television, does it receive digital signal over air? Do I need the separate digital converter box? What do I hook up where to get channels? and how do...
Hi Gwen,
This TV set doesn't have a digital tuner and you will need a digital converter box to receive over the air channels.
You still an antenna to receive the signal and then to connect it to your digital converter box. The programming should be easy.
The converter box should come with the user's guide on how to hook it up and program it.
Jan 13, 2018 | Sony KP-46WT520 46" Rear Projection...
I have a RCA D52W20 rear projection HDTV. This TV was purchased in2005. I cancelled my cable and I just hooked up a digital antenna but the TV isn't finding any channels. What do I need to do? I was...
HDTV indicates the number of lines that are shown by the TV. (HD means that at least 720 lines can be displayed in a given picture.) To receive OTA signals, you need an ATSC tuner (digital) of sufficient power (with a clear path to the transmitter) these days. The RCA D52W20 was released in 2002 and only has an NTSC (analog tuner). You will need a digital-to-analog converter to receive OTA TV (unless any low power analog stations remain in your area).
Please note that the basic digital-to-analog converters that were available with the government coupon back in 2009 were SD (480i lines of pixels used) units. HD d-t-a converters exist but are more expensive.
I hope this helps.
(the phrase "digital antenna" is meaningless; check with tvfool.com or antennaweb.org for the direction of local transmitters. TVfool.com will give more information on the type of antenna (indoor, outdoor, amplifier) that you will need to receive channels in your area. Antennaweb assumes an external antenna but is very conservative in the stations that it will indicate that you can receive. Antennas are given a color rating based on how far away the transmitter can be to get a watchable signal. Since digital signals are either enough for the tuner to interpret or you get a "no signal" message, you often need a stronger signal than was needed to receive a watchable analog channel.)
Sep 27, 2011 | RCA Televison & Video
Hi, I have a sony bravia tv ( klv20G300A) which was bought in Hong Kong about3 years ago . I haven't been able to get it to work with the uk digital signal. I am wondering about it's compatibility-...
This tv has analog tuner and you need digital tuner in tv to get digital signal in UK, alternate way is to hook cable box with this tv that will convert digital signal into AV output that will connect to AV input of tv to get cable channels.
Aug 03, 2011 | Sony BRAVIA KLV20G300 20 in. EDTV-Ready...
All ready used box once. Now going back to antenna. Not receiving display or menu on T.V. screen.
All TV over the air is transmitted as a digital signal now. In order to see it on an older TV (read Analog), you must have a signal that you can receive(antenna hook up) and a digital to analog converter box. That box allows you to see your digital signal on older TVs. The signal is sent from the antenna to the box via a RF connection, and decoded to channel 3 or 4 (your choice). for further information see Consumer Report at:
http://www.consumerreports.org/cro/electronics-computers/tvs-services/non-digital-tvs/digital-converter-boxes/digital-tv-converter-boxes-first-look-3-08/overview/digital-tv-converter-boxes-first-look.htm
Jan 09, 2011 | Insignia Digital-to-Analog Converter for...
Have Problems with getting Channels?
You've not given us the manufacturer, make and model number, but I see 3 analog inputs on the left and the usb on the right. This tells me the analog audio and video signals must come from a dvd or vcr or tv-tuner. You say getting channels, so I'm assuming you've not hooked up to a digital ready tv hooked to cable or dish or digital converter. THERE ARE NO MORE ANALOG SIGNAL CHANNELS ANYMORE. Everything went digital in June 2009. So there you have it. If you don't have usable information going in, you can't get it out. try it with sterio audio and video from a digital tv that is receiving channels, and I think you'd then see sterio and video out of your pc. Regards --- GooseBay_Camper
Sep 28, 2009 | RCA Analog (RCA) to Digital (USB)...
Built in tuner not working since digital transition
I do not know if you will get this message but if you do. Here goes. The protron PLTV3250 does indeed have a digital tuner that can be used with an over the air antenna. You need to push "source" on the remote until DTV is selected. With this selected and your coaxial cable from your antenna hooked up to the digital connector (not analog) on the back of this tv you can then press Menu and you will see a totally different looking menu that you are probably not used to seeing and then from there you can do an auto scan for the digital channels and it works great. I have rabbit ears hooked up to this Protron PLTV3250 and this has a beautiful picture. Far better than the picture I get from just the standard digital Directv receiver. You do not need a seperate digital tuner box to use with this TV. It does indeed have an ATSC digital tuner and it works great. You probably are selecting Source "TV" in the menu and that is not what you select for this TV to use the Digital Tuner. You need to select DTV from the source menu. Good luck and please let me know if you already knew this or if this helped you. Thanks, Tom
May 27, 2009 | Protron PLTV3250 32 in. LCD Television
No HDTV reception with Jensen JE3269 LCD tv
Looking at the manual, the specifications indicate that this is an NTSC TV. You would need an ATSC tuner (a digital converter box) to convert the digital signals into the analog ones that this TV can receive. You may also need an antenna designed for DTV signals to get a good reception.
Nov 11, 2017 | Televison & Video
Do you need a special antenna to hook up a dtv digital to analog
You need a TV antenna, nothing special about it. Hook the antenna up to the converter box, the box up to the TV.
Jan 10, 2009 | Insignia Digital-to-Analog Converter for...
Digital TV flunked the digital test
you will most likely need a box to convert the signal from the antenna to digital . the problem is the signal not the tv
Dec 14, 2008 | Sylvania LC370SL8 37 in. LCD Television
Analog or Digital?
This TV is analog and will need a converter box when Analog TV is turned off in 2009.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 10, 2008 | Panasonic CT-20D11 20" TV
RCA F38310 38" TV Logo
183 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
