Question about Mag Innovision InnoVision 996PF (White) 19 in.CRT Conventional Monitor
Mag monitor signal cable faulty
I have a MAG innovision 986FS monitor and I am trying to find a diagram for the pin configuration for the signal cable (the end which plugs into the graphics card) as my cable is damaged an I need to install a new connector on the end of the cable.
  • 348 Answers
Look into the 15 pin vga connecter care fully you will look numbers 1 to 15 which is very small it configration is as follows
1)red
2)green
3)blue
4)gnd
5)gnd
6)r return
7)g return
8)b return
9)5v from vga card
10)stand by
11)sync gnd
12)Sda(serial data)
13)Hsync
14)Vsync
15)Scl(serial clock)
at another end same letters will see take continuty and join new cable
Posted on Nov 11, 2008
No signal on monitor
Dear Brother,
  • Check your Monitor Cable
  • Check your Cables PINS Broken/Damaged
  • Check Properly Plugged in the Cable to both PC and Monitor
  • Check your Display Card
  • Check your Motherboard Connection With Display Card
  • Unplug the Cables end From PC and Monitor
  • Unplug From Power too and Then Correctly Plug in
  • Connect CPU to another PC(for making Sure problem is for Monitor)
Your Problem can be Solved...... Hope This HELPED YOU Thanks For Using FixYa
Apr 06, 2010 | Mag Innovision InnoVision LT765 17" Flat...
Mag LT2219 monitor has a grey/white picture
Have you tried replacing the video cable?
Jan 07, 2010 | Computers & Internet
My apple mini mac (no intel) hook up mag monitor 780
The Mac Mini has an adapter plug, DVI to VGA.
If you use the adapter and a VGA cable to the monitor there is not a noticeable difference.
Just be sure to know the resolution maximums of the MAG monitor before you think its the Mac.
Feb 15, 2009 | Mag Innovision LT776s 17" LCD Monitor
Mag 17
it is a problem signal cable of the monitor open the monitor test the continuty of 15 pin signal cable
if pin no 13 & 14 (hsync & vsync)are open then change the cable problem will be solved
Oct 25, 2008 | Computers & Internet
Need a driver and users manual for mag innovisionLT576s
42905439-177x150-0-0_.jpg ViewSonic (HASU05F) Information: Product details Price Range: $25.00 - $40.00 at 3 stores This AC Adapter is ideal for use with your Flat Panel Monitor or LCD Display. The High performance AC Power Adapter pictured here provides consistent and continuous power at the specified Voltage and more
this is what else u need to power the monitor it is plug and play compatible
make sure your video card has the right software to run monitor
Where can I get drivers for my video cards?
Answer ATI – http://www.atitech.com/
Nvidia - http://www.nvidia.com/
Matrox – http://www.matrox.com/
Pinnacle – http://www.tridentmicro.com/
Trident - http://www.tridentmicro.com/
Diamond Multimedia – http://www.diamondmm.com/
Cirrus Logic - http://www.cirrus.com/en/
http://www.opendrivers.com/driver/214283/mag-lcd-monitor-drivers-windows-95-98-2000-xp-me-nt-free-download.html
heres the driver that you needed for your monitor
I can’t find where the AC power cord plugs in on the back of the monitor. Answer There are two places where the AC connector could be found.
1. Look at the back of the monitor right next to the signal cable connection.
2. If the signal cable does not detach from the monitor, follow the signal cable to the end, and you will see the 15 pin D-Sub connector (blue connector). There you will find a small hole with a pin inside (in between the two notches).
May 26, 2008 | Mag Innovision LT576s 15" Flat Panel LCD...
Mag Innovision product # LT765s model #780
monitor is looking for the video signals--move mouse and try power on
Jan 07, 2008 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision LT776s Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Nov 23, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision InnoVision 996PF (White) 19 in.CRT Conventional Monitor Logo
209 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
