Question about Marantz SR-7200 Receiver
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
Unit just shut off - standby/power light starting blinking rapidly.
Unplugged unit to see if it would reset - to no avail. Standy/power light still blinking rapidly.
Any ideas? Marantz SR 6001Power and StandBy Light came on and is blinking Rapidly. There is a review at CNET that slams this receiver. Do not Buy. Actually looks to be discontinued. Marantz is requesting we send in for repair and we will be lucky to get it back in 6 - 8 weeks
  • 6 more comments
  • Rick n Mini Nov 11, 2008
    Can anyone tell me how to reset the protection circuit WITHOUT sending it in for repair? If so I will happily pay the $9.99. I Know my way around a circuit board and a VoltMeter. Is there a way to disable the protection circuit? The nearest repair facility is quite some distance and I do not want to go there
  • Anonymous Dec 04, 2008
    same exact problem. I have requested help from Marantz
  • angshumand Dec 25, 2008
    I have the same problem that got triggered due to a short speaker cable. But I have already removed the shorted wire but not able to find a solution to reset the protection circuit..
    If any one have a solution to reset the protection it would be great as in India, Delhi there is no direct support for Marantz even.
  • Anonymous Apr 08, 2009
    the same probl with sr7001
  • Anonymous May 02, 2009
    Same problem after electrical storms although was on a high dollar surge protector. No remedy with the suggested fixes. I think I am screwed!!
    AM, Dallas
  • jason May 11, 2010
    the protection circuit has kicked in because there is a dc overflow or there is a short
    I would start looking on the power amp for the problem
    you cannot disable the protection circuit , it is protecting the rest of the circuit , if you did bypass the protection circuit you will just burn somthing else out
    look for a short in the power amp , that is the most likely cause of the protect circuit but other components need to be tested to make sure , like an electrolytic capacitor , bad resistor , thats where the problem is most likely going to come from
    this is the protection circuit, it needs repair
  • Jan Klinkspoor
    Jan Klinkspoor Sep 19, 2013
    I have found a standby mode reset code for another Marantz receiver and it worked fine for my Marantz SR4003. Just press Surround mode + Exit + Clear simultaneously and the receiver should perform a hard reset. You will lose (part of) your setup settings, but it should at least come out of its standby mode in this way.
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
Posted on Apr 06, 2012
  • Leny
    Leny Nov 15, 2015
    B I N G O ! ! ! Yes That worked ! I got my receiver back ! Thank You-Thank you-Thank You ! Finally, someone who really does know how to save people money !
I have a SR7001 with that problem. I found 2 shorted amp NPN & PNP transistors. Part #'s SAP17NY & SAP17PY.
Posted on Feb 08, 2011
Did you got any solution? please post it here
Posted on Dec 07, 2010
  • Winston Stainback
    Winston Stainback Feb 08, 2011
    I have a SR7001 with that problem. I found 2 shorted amp PNP
My sr5004 marantz receiver has gone into standby with the indicator is blinking how do i get ride of it
If the red led is blinking fast (8x/second) the power supply is likely damaged and the unit will need to be serviced. If blinking slow, the most likely cause would be a shorted speaker connection. To help find the cause, unplug everything including the power and speakers. Connect only the power and try to turn the unit on. If the light doesn't blink, you know you have a shorted connection. Power off and connect the inputs and then power back on. If the light is not blinking, you know the problem is with an output connection. Just find the bad connection by process of elimination.
Manual: http://us.marantz.com/DocumentMaster/US/SR6004-5004_U_EN.pdf
Sep 27, 2014 | Marantz SR5004
Marantz SR7400 AV Surround Receiver wont switch keeps converting to standby and reading check pow5
try a hard reset
leave the unit unplugged for one night and then switch it ON
Oct 07, 2008 | Marantz Televison & Video
What can i do to stop the red light blinking for marantz sr5007?
Turn off the power using X.
2 Press X ON/STANDBY while simultaneously pressing PRESET CH + and PRESET
CH -.
3 Once the display starts flashing at intervals of about 1 second, release the two
buttons
Aug 09, 2014 | Marantz SR5007 Home Theater AV Receiver
Marantz sr5600 reciever click and goes to blinking standby
I have the same problem. Earlier it got sorted out itself and now it has started coming up again.
Feb 26, 2012 | Marantz SR-5600 Receiver
SR5004 amp on standby mode (red light blinking twice a second) / cant get it out of stand by mode
I am having the same issue as well. If you press "clear" "exit" and "surround mode" all at the same time, it will come back on. It seems to be an overheating issue. If you put a fan on it, it helps, but does not fix permanently. Anyone have any ideas for a permanent fix?
Sep 20, 2010 | Marantz SR5001
Power light blinking
Send it for repair. The receiver has a problem with power supply or a bad channel.
Oct 05, 2009 | Denon AVR588 Receiver
I have exactly the same problem! Sometimes when I turn the input dial it comes back on but this time it is out for good. I have tried re-wiring and unplugging etc. nothing seems to work.
Jan 21, 2009 | Marantz SR6001
Try pressing the power, and multi speaker button at the same time. But first turn the unit off...then press the above buttons at the same time...This is for the SR6001... GH
Feb 16, 2008 | Denon DRA-395 Receiver
Reciever not working
Are all the speakers GOOD and all connected right?
If so then you have at least one blown output amplifier module.
Feb 16, 2008 | Sony STR-DE345 Receiver
Marantz SR-7200 Receiver Logo
3,375 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
