Question about Samsung LNT4066F 40 in. LCD Television
Broken coaxial the cable coaxial on my tv is loose an spins when i connect the cable its very fuzzy an can barely see channels is the an easy fix an if so what can be done
  • 4 Answers
If you are comfortable doing some small repair work, you might be able to fix this with stuff you have laying around.
All you need is:
1 - 8" piece of coaxial cable with male connector on one end
1 - set of RCA cables (Red/White/Yellow)
1 - coaxial coupler
2 - small wire nuts
electrical tape
Take the back housing off of your TV. You may have to unscrew the small nut holding the threaded connector to the TV. This threaded connector should connect to the motherboard with a male RCA prong that should be soldered to the component on the motherboard. You will need to carefully cut
& remove the old soldering & wiggle the connector off. This is the hardest part, but it WILL come off with a little trying.
Now get your coax cable and strip off about 2" of the black outside housing ONLY. Your solid copper` interior cable should be protected by a small plastic coating which is covered in braided wire. You'll need to be careful not to cut the braiding off. Untangle the braiding down to where your cut stops and try and get it all on one side of the cable so you can twist it all together and make a nice wire. Now strip about an inch off of your interior plastic sheathing to reveal the small solid copper wire on the very inside.
Get your RCA cable and cut about 6" off of the one yellow side. Follow the same process above to get a braided sheathing wire and a solid copper wire. Attach this yellow wire to the coaxial cable by twisting the two braided wires together and the two solid copper wires together. Use your wire nuts & electrical tape to secure your connections making sure none of the wires can touch each other.
Connect the yellow cable's male prong into the component on the motherboard and attach your coaxial coupler to the male end of your coaxial cable. If you saved the small nut from earlier, you can re-attach this new coupler to the housing on your TV. Screw your housing back on the TV and you should be good to go.
Posted on Feb 22, 2009
    Sergeant:
    Champion:
  • 227 Answers
Yes it is,but the thing is that you have to disasemble the tv, so that the only problem
i believe if you open it and be very carefull and take out the tuner board, you can fix it, just need a couple of tools like: screwdrivers, soldering iron, some solder wire from radio shack. just take your time and do not try to rush it.
good luck
Posted on Nov 17, 2008
How do i set up my tv with my sony vcr
Hi Katie.. If you are using a coaxial cable to connect your TV and VCR, the TV needs to be tuned to channel 3 or 4. If you are using the Yellow, red and white cables, your TV should be on video mode to work.
Sep 14, 2015 | Toshiba 24AF42 24" TV
Tip
Watch your SKY channels on a second TV with Magic Eye and remote
If you have Sky Multi-room this will feed a separate SKY signal from your LNB on your dish to a second SKY box if you have the basic this will not cost you anything you still need a card inserted in the front to make this work. I think it costs £5 extra for more channels.
So if you have SKY + you will have 3 coaxial cables coming out of your LNB. ( 2 for the SKY + and 1 for the Multiroom )
To ger the signal for free the easy way is to connect a coaxial cable from the RF2 output on the back of the SKY ot SKY+ box into another TV and use a SKY Magic Eye these cost about £5 and have a range of about 20 meters. You can use a coaxial splitter to feed two TV but you will loose more signal the more you connect.
You will need to turn this function on using the hidden menu to allow you to use the Sky Remote control then LED on the unit will show you that there is a signal.
Press <SERVICES> <4> <0> <1> <SELECT> and goto the RF2 output to turn the signal on you might find that this signal is already turned ON for you.
Note: If you are using a multiplex faceplate unit this signal will not work as it relies on continuity of the coaxial cable with a 12V DC signal being sent out of the back of the SKY Box.
For all setups changing you Box model or adding an extra box SKY must to this for you by having your phone line connected so they can reprogram your Smart Card.
on Jan 30, 2010 | Audio Players & Recorders
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
My insignia tv shows a NO DATA BASE error on screen. How do i fix this.
Try these tips:
Connecting your Cable box through Coaxial to the TV.
1- Turn on the TV and the Cable Box, secure all the coaxial connectors.
2- Press the "TV" button to be sure you are in the TV mode.
3- You need to set the TV in a specific channel for receiving the signal from the Cable Box, usually they are channel 3 or 4. Please press in the TV's remote those channels numbers and check if you are receiving signal about the Cable Box in any of them.
4- If you do, afterwards remember to continue using the Cable Box remote to change the channels instead of the TV one.
Connecting your Cable Box through RCA to the TV
1- Turn on the TV and the Cable Box, secure all the RCA wires.
3- Press the "Input" button to go to AV1 or AV2 depending where the Cable box is connected.
4- You should be receiving signal instantaneously after you have changed the Input and keep using the Cable Box remote for changing the channels.
Jun 21, 2010 | Insignia LCDTV26 26 in. Television
Can i connect my audio and video cable to a coaxial cable? so one side is coaxial cable and the other is audio and video cable one for the the wall and the other audio and video for the tv, this is beause...
U have HDMI ports,order HD from the cable or telicom compannies.Use a HDMI cable for the tv,also get HD channels.Do not have HDMI ports than ur Main signal board must replaced the Antena analog coaxial it broken.Well not able to buy the coaxial input for the antena along for part.
Jan 10, 2010 | RCA HD52W58 52" TV
How do you hook up the dvd player to the tv with a vcr hooked up to the tv
Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Jul 15, 2009 | Televison & Video
    I have the tv and i have the cable channels but they r fuzzy
    Do you have a vcr/dvd player connected to this tv? Make sure it is off. Do you have a cable box? Make sure your TV is on channel 3 or 4 and the same for the cable/satelitte box. Make sure you have good grounds on your cables and rca jacks. Should be easy to correct this.
    May 01, 2009 | Proview PA-32JK1A 32 in. LCD Television
    Fuzzy picture
    You might want to try a new cable, otherwise it might be a loose jack that if your daring enough, you could fix yourself
    Jan 09, 2008 | Zenith D65W25 TV
    Samsung LNT4066F 40 in. LCD Television Logo
    217 people viewed this question
    Henry  Thomas
    Henry Thomas
