Question about Bosch 8.72 cu. ft. / 247 liter Chest Freezer GTA26900
Deep freezer not getting cold enougg even with temp. all the way
My freezer runs fine for about 3 or 4 weeks after i defrost it then it gets only partial colf it't about 7 years old
  • firstplum Dec 16, 2008
    My freezer is only freezing at the top not working at the bottom what can the problem be?
    Problem Solver:
  • 8 Answers
Sounds like a stat problem, is it running all the time or does it shut off, put something warm on the stat if it comes on its the stat
Posted on Nov 11, 2008
Hi sense deep freezer light turning ng on but won't run, no sound, nothing?
You only have 1 or 2 things to check.
1. Cold control off or not set to a temp. desired position
2. Compressor overload cutout on side of compressor.
If it's a self-defrosting unit, a timer, heater, thermal cutout could be an issue.
This site may help in diagnosis and carries parts
https://www.repairclinic.com/RepairHelp/Freezer-Repair-Help
Dec 12, 2017 | Freezers
Is my defrost timer broken or my thermostat? The freezer was holding -30 temp but now is at +30.
Is the compressor running? If not - the timer could be stuck in defrost mode. If it is ruinning, then the freezer coil should be cold. If it is choked with frost & ice - then the defrost heater isn't getting powered (bad timer or defrost terminator - or is getting powered but has burned out.
You should allow the ice and frost to melt completely before turning back on again. Typically ice and frost don't build up so bad in a few days time to cause the temperature rise you're describing If getting cold - the compressor and refrigerant is likely OK, if not the defrost circuit is suspect. If compressor running but not getting cold - a refrigerant leak / charge level may be causing the problem.
May 18, 2015 | Arctic Air 22 cu. ft. Commercial Freezer...
Not Cooling Fridge Or Freezer keeps Freezing up (New Defroster)
There are 3 parts to the defrost system,Which did he replace? You should ask and don't name the parts for him,Let him tell you what he replaced.Here are the 3 parts to listen for.
Improper installation,a faulty part,or a short could cause it to fail in that short time.
  1. Defrost timer
  2. Defrost element
  3. Defrost thermostat.
Any other question, feel free to ask
Please rate this a fixya
May 18, 2009 | GE Freezers
Whirlpool side by side fridge not cooling
Yes, only part that gets could is in the Freezer. If block by ice (usually) this will not allow the cold air to go into the ref., if so, defrost problem. Check amount of ice on coils in back of Freezer. Should only be a thin frosting.
May 02, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
Fridge not getting cold
you have a defrost problem.when you open your freezer door and look at the back panel look and see if their is frost built up.if so that means you do have a defrost problem.you will need to pull panel off and defrost coils.then you can check your defrost thermostat which is round and has 2 wires that go to it.it sits at the top of coils.see if it seperated.if so that is your problem also check defrost heater see if any breaks in it.if those check out then could be defrost timer which is located in ref.side.it would help to know what brand it is.it sounds like a side by side ref,but dont know what brand.
Mar 24, 2009 | Freezers
Upright freezer
sounds like your freezer isn't maintaining a constant (cold) temp. A variation from cold to warm would cause your problems. Normal opening the door and looking for the ice cream over and over would cause a gradual increase in glacier activity in the freezer. I don't know of any quick easy fix-but wait, how about checking the door gasket? Get a piece of paper, close the door on it, move the paper all around the door, testing to see if you can pull it out easily (bad gasket), or does the paper not want to come out?(good gasket) If the gasket seems ok, it may be time to retire the global ice cream warming freezer countrycurt0
Aug 04, 2008 | Freezers
Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Not Freezing, but cold
The thermostat should be a close circuit when requesting cold temps. or when asking the compressor to come on. The exterior surface on some freezers warm when asking for cold inside. Yours has a condenser coil on the back and that should warm when cooling. If compressor is runningit should be wrm if no freon has leaked from freezer somewhere.
The defrost timer should rotate clockwise during the day and give approx. 3 defrost daily or about every 8 hours. Until the thermostat is resolved and asks for a closed circuit the compressor will not come on. Unplug freezer from outlet,remove thermostat wires, then turn the thermostat to its coldest setting and check again. If no closed circuit the thermostat will need replaced first. Hope this has helped you, Sea Breeze
Nov 01, 2007 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore Freezer Model 23041
I have an upright freezer which temp was unstable. The coils were frosted up, and the circulating fan was unable to pull air across the cooling fins.I defrosted the unit, cleaned it up, and turned it back on. Worked fine until it frosted up again. The unit was a no frost model. I had to have it serviced, and one of the defrost sensors was bad. No problems since this was fixed.
Aug 13, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Bosch 8.72 cu. ft. / 247 liter Chest Freezer GTA26900 Logo
1,166 people viewed this question
Top Bosch Freezers Experts
Charles T Nevin
Charles T Nevin
Victor Nwachukwu
Victor Nwachukwu
Are you a Bosch Freezer Expert? Answer questions, earn points and help others
