Question about HTC G1
G1 touch screen not working
Every time I charge my phone, the touchscreen stops working. I will try and touch something at the top and it will click on something down at the bottom. Also, when i try to move it to the other screen it will get stuck shaking. And, the icons will sometimes go on, like i had selected them to go into the trash.
  • 8 more comments
  • kristen_kumm Nov 13, 2008
    I have this problem when sometimes my screen doesn't work. I press on an icon at the top of the screen and it opens up an application on the bottom, and then some of the applications open when I haven't even touched my phone.
  • Anonymous Nov 22, 2008
    I've seen the same issues. Been trying to find a heatmap / touch application, it looks like it's picking up touches in the wrong spot or extra touches. I've also noticed that the main menu key may be ignored.
    Sometimes it is corrected for a short time when I power off the device for a moment.
    New problem for me, I'm traveling and using the USB charger a lot, and it's doing a lot of wifi scanning. In case those are related.
  • Anonymous Dec 06, 2008
    it touch stuff on it own wen im not even pressin on and wen im texting it start going to otha message and bringing up the menu buttom
  • KraZyGoOse Dec 06, 2008
    I have exactly the same problem. I live in Spain and I don't have a USA to Spanish charger adapter, so I'm using a standard USB plug.
    If I use the standard USB cable with my computer, it works fine, but if I use it with my USB charger... boom! The screen turns unusable :(
  • bradbuzzi Dec 21, 2008
    same as nadinelemons
  • Anonymous Feb 07, 2009
    I use OEM chargers, usb cords plugged directly into computers, a no name car charger from china and they work swimmingly.
    But! A travel charger I bought from china makes the touchscreen go haywire. The only usable button then becomes the End Call, and scroll ball. Oh, and I complained and they sent me a replacement car charger, same problem!
  • Anonymous Feb 18, 2009
    my g1 is doing the same thing.
  • Anonymous Feb 27, 2009
    I have exactly the same problem. A hard-reset solves it but as soon as I recharge - wham...
    I have the same issue exactly.
  • Anonymous May 23, 2009
    I have the same problem, even it is not charging, the screen do some strange things, dancing around, click some buttons...
My workaround is to charge with a different power source, or stop charging. i think it's the power source. for me, the touchscreen goes crazy when i'm charging via usb with this old computer, but it's fine when i stop charging. it's probably an unclean power source messing with the capacitance sensor.
Posted on Dec 16, 2008
My ipod touch touchscreen has stopped working. ipod is fully charged and all buttons work but i cannot unlock. touchscreen is not responding
Try and press the top button and the home button at the same time for about 7 seconds.
Hopefully your Ipod closes down and you will see the Apple logo on your screen.
Just let it initialize and syncronize.
This will hopefully help. If not you might need go to your Apple retailer and leave it for repair.
Good luck
Jun 24, 2011 | Apple iPod touch
LG touch phone. Touch screen keeps blanking out, it that the touch screen will not work. Screen shows everything but the touch of the screen does not work. I have took out the battery and replaced it. It...
when phone is idle, the auto lock feature locks out the screen. you can set the time when lock engages or disable completely. To unlock, press top right corner button or use touchscreen options by sliding finger up from bottom to top or press unlock button on bottom of touchscreen
Feb 19, 2011 | AT&T Cell Phones
G1 got little wet but it dried out and screen shows all but now triangle and cant get touchscreen to work....what do i do?
If it got wet it might still be wet from the inside and that is why your touch screen wont work, You would need to open it and clean it from inside. Or it could have a bad digitizer and that is a second reason why the touch screen wouldnt work. You can try doing a hard reset if you says it just shows a triangle on the screen.
Turn the G1 off. If it’s frozen on, take the battery out and put it back in the unit.Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle
Now to wipe the device clean:
Press Alt+L. Press Alt+W for a factory reset.
Press the Home and Back keys again for about 25 seconds.
The device should then reset again and the hard reset is complete.
Jun 15, 2010 | HTC G1
Touchscreen not working properly
I agree. I'm on my 2nd G1 right now because my first one had touch screen problems. But the problems only started after I started using a different charger (it's been so long I can't remember whether it was just my blackberry mini usb charger, or whether I charged it from my computer; I think it was the computer). However, once it started spazing out it wouldn't stop, it was permanently damaged. So if your touch screen seems a bit finiky after charging with an odd power source, Stop ASAP or you risk permanent damage
May 14, 2010 | HTC G1
Screen works but dosent respond to any touching?
Check that the "touch screen lock" is not engaged. To avoid accidental activation of the touchscreen, many models use some kind of "security" so that after a fixed time, the touchscreen will stop responding unless you (e.g.) click an unlock button. Verify this on the user manual.
Nov 05, 2009 | Samsung Instinct Cell Phone
G1 touch screen stop working cant use the phone without the touchscreen
the screen needs to be replaced take it to a mobile service center and have that done there.
Aug 01, 2009 | HTC Touch Cellular Phone
I have water damage on my G1 but it still works however the touch screen doesnt. i did a hard reset and unable to bypass the welcome screen without the touch screen is there a way to bypass it without the...
There is no way to bypass the touchscreen step of the setup process. I repair phones, including the T-Mobile G1. I can replace the screen for you if you would like for $60. Please email me at IGcomputerservices@gmail.com for more information.
Jul 14, 2009 | HTC G1
G1 TOUCHSCREEN
Hi there, You are lucky that it is on... try one thing.. put the fun under the sunlight for half an hour or may be 15 min if its too hot there and try it again...
if this will not work then try to open the phone if you can clean the top screen area and put it back (try at your own risk) and it will do..
Mar 23, 2009 | HTC G1 Smartphone
Ds wet...
hi, this SHOULD be an easy fix. Just set it out to dry somewhere, but seeing how you dont have a screwdriver, this may take a few days, try a hair dryer on low, or a fan.
Have a happy new year
Dec 29, 2007 | Nintendo DS Lite Console
HTC G1 Logo
6,179 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
